Machine not spinning - Washing Machines
  • 1 more comment
  • twisted22 Mar 22, 2009
    I have a GE top loader, GBXR1070WOWW, and it does everything but spin. The lid switch is working and the motor is cold (not overheating). I can't figure out the schematic enouh to troubleshoot it properly but I'm thinking that there's no power to it. Where do I check for voltage?
  • Anonymous Mar 29, 2009
    maytag front load machine does not spin
  • iansierra Apr 03, 2009
    Bosch WAS28466GB - not spinning at any speed
    Problem Solver:
  • 12 Answers
Most problems with washing machines that won't spin are either caused by motor brush's being worn out or the machine is not draining properly. Typically your machine should empty out in about 15 - 30 seconds of the drain pump starting, if its not check for obstructions in the filter or the pipework. If thats ok then check the motor brush's. Some machines also have a small circuit board mounted in the bottom of the machine, that is also a possibility but check the other things first...
Posted on Jun 15, 2008
  • 38 Answers
If its a top-load machine, chances the lid switch is bad.
If the motor hums, it could be the belt or the couplin. Cant say for sure unless I know the brand of washer.
Posted on Jun 16, 2008
    Genius:
  • 1,122 Answers
WHAT KIND? MOST OF THE TIME IT'S A BAD LID SWITCH FROM CLOSING TO HARD OR THE MOTOR TO TRANSMISSION COUPLER HAS FAILED,LET ME KNOW-MIKE
My washer won't spin
HI Rhonda.
If your washer pumps out the water but doesn't spin, check these: The lid switch may be defective. ... The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch.4 May 2012
SOLVED: Why won't my Washing Machine pump but not spin during ...
https://www.ifixit.com/.../Why+won%27t+my+Washing+Machine+pump+but+not+spin+...
What causes a washing machine not to spin?If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) ... 1Check the washing machine's spin cycle. If this works, the motor is operating and the belt is not broken.14 Aug 2014Washer Doesn't Agitate or Spin - HomeTipshttps://www.hometips.com/repair-fix/washing-machine-agitate-spin.htmlSearch for: What causes a washing machine not to spin?
Why is my washer not spinning the water out?If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing.16 Mar 2014SOLVED: Why won't my washer spin or drain? - Kenmore 110 Series ...https://www.ifixit.com/Answers/View/.../Why+won%27t+my+washer+spin+or+drainSearch for: Why is my washer not spinning the water out?
What causes a washer not to spin?Over time, the repeated friction of the clutch pads rubbing against the housing can cause the clutch to wear and create a scraping sound. A worn clutch can prevent yourwashing machine from spinning, or may cause a slower spin speed which will leave your clothes wet after a cycle.How to Fix Washer That Won't Spin ' Washing Machine Repairhttps://www.partselect.com/Repair/Washer/Will-Not-Spin/Search for: What causes a washer not to spin?
if you need more help go to this link.
washer won spin Google Search
Nov 23, 2017 | Washing Machines
Kenmore Series 70 Top Load Washer Direct Drive Model # 110.20722991 Serial# CL 1134809 Wet Clothes after Spin Cycle
many machine spin a full tub as they are pumping the water out
this helps to even out the washing load and reduce the unbalance situation
when the water is removed , the machine progresses the program to a high speed spin
call a technician as there may be a problem in the program board
Jun 11, 2016 | Kenmore Washing Machines
Washer does not spin and drain properly
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 15, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...‎Washer Not Draining Water - ‎Washing Machine Service ... - ‎How To Fix A Washing ...
Washer Repair - Not draining or spinning ... - YouTube
? 5:17
https://www.youtube.com/watch?v=k41abYwM9WY
Jul 12, 2013 - Uploaded by ApplianceVideo.com
Washer Repair - Not draining or spinning - Repair & Diagnostic- .... off and my machine spins but it doesn't drain (high spin) does not work.
Dec 19, 2015 | Whirlpool Cabrio WTW5500BW White 27"...
Can't spin. Makes ratcheting noise as it attempts to start spin, can't start spin even w/o load.
What to do when Samsung Washing Machine does not spin ?
www.samsung.com/ae/support/skp/faq/1033383
Samsung Electronics'Washing machine not spinning' is one of the major problems faced by people nowadays with ... If so, the washing machine can't spin and may not function at all.
May 13, 2013 - Washing Machine Service Repair Manuals Online Your washing machine is not working properly. It does not spin, won't drain, can't turn on, ...
Nov 28, 2015 | Washing Machines
Washing machine does not spin on spin cycle,only hear a humming noise.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 27, 2011 | Kenmore Washing Machines
My whirlpool AWOD4606 washing machine won't spin when washing or spinning
heatman101
Apr 13, 2011 | Washing Machines
Wont spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Apr 05, 2011 | Maytag Washing Machines
Clothes are very wet after spin cycle This unit has several spin speed settings, machine does spin but not fast enough to remove water from clothes
heatman101
Sep 16, 2010 | Kenmore Washing Machines
When its time for my washing machine to spin out...it sounds like its spinning, but when you open the lid...the water is out...but the clothes are still wet and the machine is not spinning
heatman101
Aug 29, 2010 | Roper RAS8445KQ Top Load Washer
The machine wont spin when in spin cycle and
try cleaning out the coin trap/drain hose that is underneath the machine
this is also the error code E20 which sometimes the machine will start flashing
Jan 15, 2010 | Frigidaire Affinity ATF7000E Front Load...
Washing Machines Logo
480 people viewed this question
Top Washing Machines Experts
