With is conected dont charge the laptop is ok but the battery is not charging
  • 6,826 Answers
A new battery is required if it won't charge up with the charger.
Posted on Nov 05, 2010
Laptop pluged in but wont charge
your battery is dead, try and replace it with another one and see if it charge.
Apr 11, 2013 | Dell Inspiron M5030 Laptop
My smpk4083 wont charge
It can be 1 of 4 things. 1: the way your charging it. 2: the cable. 3: the battery. 4: the conection on your device.
1: Try charging it different ways. (Different wall outlet, laptop, computer, etc.) (Note: some laptops and/or computers might not have a strong enough charge to recharge certain devices. You'd have to adjust the power setting in the control panel or the manufacturers setings.)
2: Try using a different cable. (If you don't have one try wigleing both ends to see if you get a charge.)
3. Try another battery. (Most people overcharge batteries thus shortening the recharging capabilities.)
4. Check to see if any of the pins are messed up or missing on where you plug the wire into your device. (If any are missing you can open it up and replace the part.) Sometimes people end up pushing them in by accident when they conect there charger, so the wire doesn't make a good conection after a while (another case where wiggleing the wire could work).
Oct 04, 2011 | Audio Players & Recorders
I have a dv6500 and it work only whit te battery. the ac adapter dont charg the battery and the pc dont work and the charger its ok. maybe a fuse?? tks rgds
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 19, 2011 | HP Pavilion dv6000z Notebook
Hello. I do not use my rx330 frecuently,to keep my battery charged may l use a battery maintainer conected directly to the battery car or l have to keep conected to the battery without the car. How can l...
if your battery maintainer(charger)has the capability to charge from a higher charge to lower charge as the battery gets charged up and shut off when proper voltage is attained then you can leave the battery in the car as every time you disconnect it you have to reset everything in the car.some now can detect when to turn off and turn on as the car sits and voltage drops to low.don`t know which ones do and don`t someone may be able to answer that if they know about them.
Jun 13, 2011 | 2004 Lexus RX 330
HI IAM USING SONY VAIO LAPTOP VGN SERIES NR11Z/T WITH MODEL NO.PCG-7Z1M. MY LAPTOP DOESNT USE THE BATTERY WHEN I CAHRGE. PLEASE HELP ME. IAM FACING TROUBLE AS I WILL HAVE TO ALWAYS CONECT TO POWER IF I...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Mar 12, 2011 | Sony Vaio PCG 7Z1M Laptop Universal AC...
New stator cover bike wont start
useing a multimeter set to d.c check your charge at the battery whith out the motor running it should read above 12 volts determine the voltage stored in the battery with the meter stil conected hit the start button if the meter shows a dramatic drop in voltage its almost certain that the battery is shot howevwer if the voltage does not drop & it wont start bump start it conect the meter still set on dc increase the revs asyou do this the voltage should climb to 13.50 if it does & maintains 13.50 to 13.65 the chargeing system can be declared ok & you only need replace the battery however if it goes above 14 volts the voltage regulator is faulty & cooking the battery so you will need to replace both
Apr 14, 2010 | 1998 kawasaki ZX-6R Ninja
I have a compac lap top and when i plug in the wall charger nothing happens it wont charge
check to see if you can hear a hum from the charger it self , push the box hard againts ear if its humbing charger is ok, if you cant hear anything from it check fuse to plug. if this is ok then charger is broken.
If charger is ok check the conection into the laptop if it feels loose and when u move it slightly it goes on and off then possible conection to laptop prob.
If this conection is ok and the charger is humbing and working, could be a possible internal switch gone in the laptop that decides to charge and not charge when battery is full. These are always failling on laptops but hopfully its not this.
If you find the charger is broken search ebay for a new or secound hand one, aint to expensive. hope this helps
Nov 28, 2009 | Compaq Computers & Internet
Battery not charging. Power supply ok
Power socket loose connection most likely. Disasemble laptop take out the motherboard and check the conections of the power socket, replace the power socket if needed. You need fine soldering tool.
Nov 14, 2009 | Toshiba Satellite L45-S7419 Notebook
Toshiba spa40 or a40
check that the power supply is the correct one for the laptop, check that the power requirements of the laptop match up with what is being supplied by the power supply.
if the labels match, for Toshiba the usual supply voltage is 15VDC, if the supplied voltage is 1 volt below recommended the battery will not charge.
If all appears correct then check the output voltage with a multimeter it should read 15V (-0.25V +1V).
If the power supply is a bit low you'll need to buy a new or used one.
Feb 20, 2009 | Computers & Internet
Open Questions:
Computers & Internet Logo
21 people viewed this question
Alun Cox
k24674
