Question about Philips Televison & Video
Repair hints i met audio problem of the philipstv 20pt2005 model actually hissing noise coming but no audio in speaker i also check the audio system its bg thats ok and i also replace the memory ic , could u please guide me what is the problem
Its a memory problem
re enter the eprom data ie.
enter the code 062576 and followed by menu the service chart appear
you have to enter the
correct data rate of op 1,op 2.......op7
main thing is data will different for different models
thanks u all, bye.
Posted on Jun 16, 2008
    President:
  • Philips Master
  • 1,779 Answers
I hope you have a scope? then I can fix your set over the net!
Posted on Jun 14, 2008
There is disturbance in sound in speakers. Some kind of hissing noise comes from the speakers. But when i connected the speakers to laptop the sound was clear. Please tell what the problem is and what...
before anything update your sound drivers
Hissing in speakers is generally due to noise in the system somewhere getting amplified. There will always be a certain amount of noise, but what you can do is check to be sure your input gain is set on the high side. That helps ensure there's maximum signal to the (sadly, generally fixed) amount of background noise. Then adjust overall volume from the master.
The other thing is to try and isolate the cause of the noise by switching around between various end sources. So - If the noise is tehre when the DVD player is on, but not when it's off, then you know it's either the player or the interconnects to/from the player. Same on a computer - Try to mute and unmute various sources.
Onboard audio is typically not high quality, it's possibly your problem, it's also possible you've got a component in your system that's injecting more noise than usual (maybe something that's close to failing... or that isn't intended for consumer use). I have Realtek onboard audio on my HTPC but I replaced it with an Audigy card a couple years back, using the optical output to my audio rack keeps everything digital in the PC where you're most likely to get noise.
Jun 17, 2011 | Computers & Internet
HISS from Numark DM1200 mixer. Not present in speakers (self powered) when mixer off. Using XLR cables with telescoping ground lifts on each line. Monster 3500 power filter. Ideas?
All interconnected equipment MUST be powered from the same receptacle or source. The XLR to the speakers should NOT have ground lift. The power for the mixer should come from where the speakers are and be routed alongside the XLR cables. All the other connected items should also be powered by the same source. The ground bounce within a building cannot only cause noise, but can rupture the input circuits of equipment. As an electrical engineer I don't know why manuals supplied with the equipment doesn't go into this more. The professionals at the big venues all know this as they have had to pay to get equipment repaired.
Now to get down to "hiss" once you get the other stuff straightened out, there are two things to know at the start: The first is that due to the statistical nature in electronics "noise and hiss" are among the laws of physics that we can't completely get around. The level of the hiss should NOT be objectionable however. The second thing is that proper level setup is important to minimize the effects of noise and hiss. You should be sending the levels to the powered speakers at near full line level into the line inouts, never mic inputs that some have. Using excess gain at the speakers will amplify any noise pickup on your audio lines. Next, at the mixer, try to keep all the level controls around 10 to 2 0'clock for rotaries and 70% for faders. Excess gain at certain stages will cause hiss to be objectionable.
Mar 19, 2011 | Numark DM1200 DJ Mixer
Hissing from computer speakers and they are new
Hello
A hissing sound indicates the speaker amplifier has no input from the computer sound card, check to make sure the speakers are hooked up to the correct port for audio out to the speaker input, the Audio output to the speaker is the GREEN mini RCA jack on the back of the computer.
Dec 30, 2010 | Bose Companion 2 Series II Multimedia...
Audio works, but lots of noise (hiss) in the audio
Some lifecams need additional software or specific browsers according to your OS
Visit the microsoft website - enter the details of your cam and check out the 'readme' link also 'breaking and known issues link'
http://www.microsoft.com/hardware/download/download.aspx?category=ICE
It may even be feedback from the incoming voice being picked up on your mic - headphones would prove that.
Finally you may have a laptop with a built in mic - check this
TEST SPEAKERS
Right click on speaker icon in System Tray
Select "Playback Devices"
The speaker icon ( checked as working) and volume level graph should be visible
Right click on the volume graph and click "Test"
Left hand speakers followed by right hand should be heard
SET DEFAULT & TEST MIC
Click "Recording" tab.
To set required mic as default - click on mic font to highlight and click "Properties"
In lower dropbox display "Use this device enable" click OK
Click "Levels" tab and ramp up sliders ( adjust to suit later)
Return to "Recording". Test mic by speaking and make sure volume graph displays
Restart computer
CONFIGURE TO SKYPE
On the 'Tools' menu, click 'Options'.
In the navigation pane of the Skype 'Options' window, click 'Audio Settings'
Run down the list setting your defaults
Select your webcam as the default microphone.
Make the test call
Click 'Save'
Jan 14, 2010 | Microsoft LifeCam VX-3000 Web Camera
Green light on speakers and sub. No sound - only hissing noise
open volume control & remove check from mute button.
start-program-acessories-entertainment-volume control.
Sep 17, 2009 | Audio Players & Recorders
SOUND KEEP COMING IN AND OUT,LOUD HISS FROM SPEAKERS
theres a short in the wires either inside the box where the speakers are or the channels are blown.
Jun 07, 2009 | Panasonic SC-AK78 CD Shelf System
Hissing Noise
this is a common problem and all you really can do is to turn the speakers off when you are not using them which is also good for your energy bill!!!
Jun 11, 2008 | Sony DAV-C990 System
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
I have no sound coming from home theatre system
I would check see if you can hear any hissing coming from the speakers if there's no sound then check to see if this product has output protection fuses and if so see if they are in tact if this doesn't solve the problem you may have dead outputs. If there is hissing coming from the speakers check your audio source to make sure it is feeding sound to your amplifier without looking its hard to say in these case's there's a lot to go wrong
Nov 26, 2007 | Wave Audio CS801 Speaker
Static or hiss noise
I have the same problem. Only one speaker is hissing and only for analog sources. No hissing when I select Coax.
Nov 14, 2006 | Harman Kardon AVR 340 Receiver
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
