Question about Hoover Washing Machines
My washing machine has stopped working; all the water did not go out of the machine although I can clear the water out manually
    President:
  • 1,294 Answers
Check your exit hose spigot, it may be clogged. This is if your filter is all clean(ref manual). There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
If these don't work examine your pump.
Posted on Jun 14, 2008
Washing machines problems
please check if the water outlet pipe is clear by blowing down it to see weather the pipe is clear as the machine wont move on until the water is emptied from the last cycle it needs to empty the wash water first before spin cycle can start, its worth a try eric
Dec 09, 2017 | Washing Machines
Bosch washing machine fills with water throughout any cycle
Just a guess but could the fill valve be defective, not shutting off completely when it should?
Nov 21, 2013 | Bosch Washing Machines
Machine keeps overflowing during wash cycle
Your pressure switch stops the water and allows it to start the next cycle. It's a switch either in the control panel or at the top of the tub with a small tube connected to it which goes down between the inner and outer tub. As the water level increases the air in the tube is compressed until there is enough pressure to make the switch stopping the water from filling. This tube can get clogged and the switch won't work. Remove the tube and clean it out. Blowing on the tube when it's still connected to the switch will make the switch if it's working and clear.
Water inlet valve
If it fills with water and starts the cycle and the water keeps running in then your water inlet valve on the back where the water supply comes in is sticking. It needs replacing.
May 20, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer stop in middle of rinse cycle
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine overflows when filling , will not start agitating, had to set on spin cycle to drain water , what do you think the problem is ? Please advise. Thank you. Mike in alabama.
Sounds like overfill due to faulty pressure switch/ tells water valves to close stop filling/ although could be hole in feed tube feeding pressure switch/ thus drop in pressure take off tube and test if clear also clean under parts its connected to..good luck,gerry scotland
Oct 31, 2009 | Washing Machines
Washing machine won't complete cycle
If it is a hot and cold fill washer, yes, then it could be a hot water problem related to the valve, or the water supply., if it is cold fill only, then the problem is elsewhere.
Pleas rate my solutikon.
Thanks.
May 13, 2009 | Whirlpool AWM5125/1 Front Load Washer
Smart drive washing machine not filling properly?
sounds like you do have a solenoid problem undo hoses from back of machine check the filters are not blocked also check at the tap end to see if filter are cleare if all filters are clear most likely you will have to replace you inlet valves assuming there is no problem with pcb board.
Mar 29, 2009 | Fisher and Paykel GWL11 Top Load Washer
Front Load Washer - Error F30
hI I HAVE REMOVE THE TOP COVER. YOU WILL SEE AT LEFT A PLASTIC ACTUATOR WHO MUST BE UNPLUG FROM ANOTHER PLASTIC PIN. JUST PUT IT BACK TOGETHER AND THE PROBLEM WAS GONE!
Jun 16, 2008 | Washing Machines
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
Top Hoover Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
