Question about Toshiba Televison & Video
My toshiba sw1000 has an external sub woofer wlt68 on the back. every so often the sub woofer cuts off.also the lead to the sub woofer makes a loud buzzing noise as if it is not functioning correctly.
  • 3 more comments
  • BenBesau Jun 20, 2008
    Thanks Guy, I'll try that as soon as I can.
  • BenBesau Jul 11, 2008
    Thanks Guy for the suggestion, but alas the problem is still there. Sorry for the delay, but have been out of action for a few weeks.
  • BenBesau Jul 13, 2008
    That does happen Guy. I suppose I need to get in touch with the retailer as the tv is less than 18 months old. Thanks for your help. Ben
  • 58 Answers
Replace the lead to the sub.
Thanks Guy9
Posted on Jun 16, 2008
  • Guy Kelly Jul 12, 2008
    Then the socket for the audio lead is probably bad where it goes into the sub.
    wiggle the lead and see if the problem comes and goes.
    if not there may be a cold solder joint from the socket to the amplifier board.
    If you are unable to solder, you will need a tech.
    thanks guy9
I have the infinity rs8a tower speakers and they sound good but when I turn the volume up the subs turn on and off on both towers
When sub-woofers are overdriven (played too loud) they create a lot of heat. You can try using an external fan or improve the ventilation around the speakers. Most good speakers have thermal cut offs that prevent permanent damage.
Mar 17, 2014 | Audio Players & Recorders
Power sub woofer is not working on my pioneer vsx-81txv everything is working all the speakers except the power sub connection at the back all i can hear is the hissing sound when i try to connect the sub...
Hissing? How loud? A sub isn't even capable of making high frequency sounds at normal volumes.
The Pioneer manual would tell you how to enable and test the subwoofer output.
Page 17 and the MACCV procedures on Page 33 (auto) or 43 (manual)
Jun 13, 2011 | Pioneer VSX-81TXV Receiver
I have a subwoofer can i hook up to computer speakers
Yes you can. cut the left speaker lead and splice a wire from it to your sub woofer. If its a powered woofer you may have too much gain going in, You don't say what kind of sub it is or weather or not its a "powered" unit. If its a powered woofer (built in amp) you should take the output directly from the computer output (buy a 1/8 in male to 2 1/8 in female connector, send one output to your original speakers and the left side of the second output to the sub woofer. you can usually adjust the level of the sub (if powered) with a control on the unit. if you need more help, contact me but please tell me more about what you have.
Mar 18, 2011 | Altec Lansing Multimedia Computer Speakers
Mirage LF 150 Sub Woofer. sub not working
within the sub amplifier is an electronic amplifier, that is shorted and blown a fuse. This is all internal. If you can dismantle this module, I suggest do so and any electrical/electronic individual will identify the part needed. you could also check on a replacement module-complete.
Mar 04, 2010 | Mirage LF150 Subwoofer
How do I remove and replace the rear speaker in my 2002 Lexus ES 300?
Hello, I have a 2000 ES300 and while the body style is different believe the newer model still has the rear deck mounted sub-woofer that you are referring to. The process of removing this speaker would start off the same as if you were going to replace the third brake light also located in this housing. Using a flathead screwdriver work your way around prying/popping up all four corners of the speaker grill covering the speaker that have the retainer clips. Once you disengage the clips work/maneuver the grill up and towards you gently and it should slide out. The bulb for the third brae light will be attached to this speaker grill, disconnect the snap wire from the bulb and you should have a clear visual of the speaker and the four bolthead screws securing it. Remove these screws and your almost home free. The next part might be slightly more difficult. If the speaker s simply connected by a clipped on wiring harness, just detach.On my 2000 ES300 i have the pioneer system(Not Nakimichi) and the 2 wires (one black, and one red) are soldered directly to the speaker. You can take a soldering iron(maybe a battery or gas powered one unless you have an inverter) and remelt the solder to remove the wires or you can elect to simply cut the wires. If you choose to cut them make sure you cut them as close as possible to the soldered joints so you have plenty of wire left to install the replacement speaker.Then install replacement either soldering or using crimp clamps and reassemble. ( Note if you simply want to add a aftermarket amplified sub-woofer you don't need to remove the sub-woofer out of the housing. You can tap into the wire leads and run it directly to the amplifier. Just cut one of the wires leading to the stock sub-woofer so it doesn't also come on and potentially blow while the radio is on. This will also prevent any bass humming when the radio is shut off but the aftermarket amplifier is still on because once one of the wires to the stock sub-woofer is disconnected or cut it breaks the circuit. Hope this helps.
Jun 13, 2009 | 2000 Lexus ES 300
2000 lexus es300
This is normal. I also have a 2000 ES300. This became a problem when i tried to run an aftermarket sub off of the wire leads from the stock sub-woofer. When I would switch the radio off there would be a loud, deep, constant bass tone. As far as I know you cannot stop the voltage from continuously supplying the sub-woofer this is the way the factory amplifier is programmed, however, if you cut one of the wires(youhave to cut because wires are soldered to sub-woofer) the humming noise will not occur when radio is shut off. Cut the wire in middle and add crimp connectors so you can reconnect later if needed. You only need to cut one and it doesn't matter whether it's the black or red wire.
Oct 02, 2008 | 2000 Lexus ES 300
Sub woofer making a screaching loud noise when powered on
The pop from other electrical items makes me think it's a ground problem but I am do not have a clue as to what type of setup you are running over there. Did you try a surge protector?Is it 110volts with a seperate ground wire?
Have you tried running a UPS?
Sep 26, 2008 | Logitech X-230 Computer Speakers
Sub Woofer Stopped working
You know what happened to mine?
I tried to shove it behind a five-drawer file cabinet and managed to crack the circuit board inside because the power cable torqued the socket inside.
I was able to shove a tiny piece of 14-gauge wire inside and bridge the disconnect between the solder joint of the center lead and one of the metal terminals of the switch; now my speakers are working again!
Jul 17, 2008 | Audio Players & Recorders
Woofer making horrible noise! HELP!
Think as an expert... Probably from my experience repairing woofers etc... the cone (1) or the spider (2) isn't well glued onto the woofer skeleton(or both???) The woofer cone must be absolutely centered or else you will get those clicks in low frequencies(you also get them in higher frequencies but you can't hear them!) I must say that it is very difficult to repair a woofer by your own. I suggest to return it back where you bought it and take another one (i suppose that you have a guarantee ha?).
Aug 10, 2007 | Alpine SWR-1542D Car Subwoofer
Televison & Video Logo
260 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
