Question about Canon i9900 InkJet Photo Printer
Cleaning the heads about a dozen times and aligning the heads about a half dozen times, got the printer working again, but after about 36 copies it went on the blink again and after cleaning the heads some more and aligning the heads, it only prints a few little lines, like the size of a thumbprint but the rest of the page is blank. Any ideas?
    Problem Solver:
  • 6 Answers
Buy new heads
Posted on Oct 18, 2017
SOURCE:
SOURCE: canon pixma mp780 - vertical line on printing
Not sure if this will help but there is a small glass panel to the left of your flatbed scanner- this must be clean or else I get a black vertical line in my printing.
Posted on Jul 27, 2007
  • 833 Answers
SOURCE: I have blank lines through my printouts
Run the cleaning cycle. If that doesn't work, try to use an alcohol soaked swab on the print head. Some of the jets are clogged.
Posted on Jan 05, 2008
  • 6 Answers
SOURCE: Canon MP730 won't print at all (blank pages).
try to move the blue nozzel over the printing head to the from the right to the left and try, it will work
Posted on Mar 20, 2008
SOURCE: Canon PIXMA iP4000
If you look on the net this problem is very common. There is a good idea that seems to have helped heaps of people on fixyourowncomputer.com using WD-40. Worth checking it out
Posted on Mar 27, 2008
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
Posted on Nov 21, 2008
Unable to align Epson 3540 print heads
Hi, it is possible that the cartridge/s are not seated properly.
Try and remove them and reposition them again.
Sometimes this will work.
Also try turning the printer off and unplug it for a short time then retry installing the cartridges again.
then do a realine and see if it helps.
Regards Micky
Dec 12, 2013 | Office Equipment & Supplies
My Canon Pixma MP480 All-In-One InkJet Printer is printing half the page, words are cut off.
Hi Good day!! Try to try the head cleaning and alignment
1. Click "Start"
2. Click "setting"
3. Click "Printer and faxes"
4. right click your printer and then properties
5. go to printing preferences"
6. Click "Maintenance"
7. Choose Head cleaning.. after that you can align it.. by clicking "Align button.
if still haf page, clean it again and align...
Hope it works!! thx
Oct 12, 2010 | Canon Pixma MP480 All-In-One InkJet...
Color ink not printing, I have replaced the color ink, I have run all "cleaning" programs etc. When I print a page with some color or colors are a very faint gray. Any help ? No codes, flashing lights etc,...
It sounds like you have a severly clogged print head. The nozzles are likely gummed up and need to be cleaned. To do this, you need to inserta new set of OEM cartridges. Run the deep cleaning utiliity a half dozen times and then the alignment utility. This should clear the problem.
You have most likely been using aftermarket/reloaded cartridges with inks that do not meet the manufacturer's specifications. I would take them back to the vendor and ask for either a refund of replacements. If you are going to continue to use these cartridges, I would take out the OEM cartridges, reseal the two openings on the cartridge ( use electrician's tape) so that they can be used to clear the nozzles should they again become clogged with aftermarket ink.
Let me know if this solves your problem.
Mar 04, 2010 | Canon PIXMA iP90 InkJet Printer
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Asker's Testimonial
" Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Comments:
Nov 12, 2009
- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
Pages are coming out completely blank...ink is fulll...i have cleaned the print head
I'm saying the same below!
By mclamemo on Nov 12, 2009 " " re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Help! +++++++++++++++++++++++++++++++++ I have learned from experience, that Epson2.gif does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Good Luck :0(
Comments: Nov 12, 2009- Funny. hahahahah,
lol :0) :0) :0) :0) :0) :0)
Asker's Testimonial " Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Oct 16, 2009 | Epson Stylus C84 InkJet Printer
Printer prints blank pages, have changed and installed new ink cartridges. wen through the head cleaning cycle bunch of times no luck. Any suggestions in fixing this?
Are you using Generic Cartridges? Pls See Below
Good Luck :0(
Oct 08, 2009 | Epson Stylus C84 InkJet Printer
MFC-490CW Won't print black
We are going to attempt to do a "power purge" to get rid of any clogged ink nozzles. Note, this will probably eat up about half of your ink, but that is the price you must pay in order to attempt to fix this bad boy.
1) Get into maintenance mode. Press these keys: Menu -> Black Start -> Scan x4 (hit it four times). A number pad should come up. If not, do it again.
2) Hit key 7, then key 6.
3) Press the right key until you get to "CLEANING BLACK."
4) Press 3.
5) Press Black Start.
After it purges and gets back to the main maintenance screen, press keys 9 and 9.
Let your printer start back up. If this does not work, try the above steps up to three times. If it does not work then, you need a new print head, which is not a user-replaceable part on this model.
Good luck.
Aug 05, 2009 | Brother MFC 490cw Color Inkjet...
Phaser Printer 8550 leaves black lines
There is a wiper blade between the print head and the drum. Sounds like you have some buidup on it causing your problem.
Nov 13, 2008 | Xerox Phaser 8550DX Laser Printer
HP psc 2110 Printer keeps telling me to Align print cartridges. I follow the steps but it always comes up alignment failed and starts printing Instruction page all over again. I can print from my computer...
Press the cancel button. Then press the "setup" and top "copy option" buttons together to enter maintenance. Use the right arrow (right copy option) button to scroll through the options if you like, but then hit the cancel button to skip the alignment.
May 18, 2008 | HP Office Equipment & Supplies
Canon i9900 InkJet Photo Printer Logo
97 people viewed this question
Clive
Clive
old marine
old marine
