Question about Palm Zire 72 Handheld
Fatal exception I always have a problem with my zire72 palmone when I'm trying to open my card the screen keep on saying fatal exception and need to be reset I reset it using a paper clip but it work I dont know how to work this please help thanks...
    Scholar:
  • 94 Answers
Sounds like a third-party app is causing the problem.
Try Palm's own guide to diagnosis and you should find out what.
Palm page
Regards
Philip
Posted on Jun 26, 2008
Fatal error unhandled c00000fdh exception at 30119435h in autocad 2011
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Fatal-Error-Unhandled-Access-Violation-Reading-0x0000-Exception-at-bcbdad73h.html
Fatal Error while opening AutoCAD Dec 05 2014
Applies to AutoCAD 2009, AutoCAD 2010, AutoCAD 2011, AutoCAD 2012, AutoCAD 2013, AutoCAD 2014, AutoCAD 2015, AutoCAD Architecture 2009, AutoCAD Architecture 2010, AutoCAD Architecture 2011, AutoCAD Architecture 2012, AutoCAD Architecture 2013, AutoCAD Architecture 2014, AutoCAD Architecture 2015, AutoCAD Civil 3D 2009, ...
See More
Issue:
While in the process of starting AutoCAD , a Fatal Error occurs.
Causes:
Fatal errors usually indicate program corruption or a corruption somewhere within the operating system.
Solution:
There are several ways to address the problem: Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
Sep 16, 2010 | Autodesk AutoCAD 2010
When inserting a raster images, receive the "FATAL ERROR Unhandled Access Reading 0x0000 Exception at 10b0961eh" message.
See More
Issue:
Causes:
Solution:
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
Article ID: kA230000000tTXu
Sep 15, 2010 | Autodesk AutoCAD 2010
Treo 650 suddenly went to a palmone boot up screen then to a palmone powered screen and just keeps repeating without fully going to the normal screen mode for the phone.
When the first screen flashes, as the bar is loading, hold up. Let go once the bar finishes. If that doesn't work you may need to hard reset. Just google how to give it a hard reset and remember that you will lose everything that isn't backed up if you do.
Feb 12, 2010 | Palm Treo 650 Smartphone
When I use my Palmone T5 calendar it will not save and I get a fatal error and have to reset again. I can not beam into the clendar without fatal error message. What can I do to get this to work properly?
You might want to try a a hard reset. This will erase everything on your hand held so you might want to try the free palm chat that palm offers. Here is a link to that. Just scroll to the bottom of the page and you will see Palm Chat. Click on the link that says Chat Now and follow the directions. Best wishes.
http://kb.palm.com/wps/portal/kb/na/tungsten/t/unlocked/supportservices/page_en.html
Nov 17, 2009 | Palm Tungsten T5 - Multilingual Handheld
Fatal Alert Datamgr.c,Line7564 InvalidUniqueIDPassed I get this when I synchronize.
Perhaps you haven't tried performing a more severe reset to break the freeze. You might want to try doing a hard reset. This will erase all data from your hand held so make sure you have everything backed up on your computer so you can sync it again after the hard reset. Note, when I occasionally receive a Fatal Alert error, the Reset on-screen button almost never responds to a tap...I invariably have to depress the reset button in the back of my E2. http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(26419) resets:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,case=obj(887) Depending on a variety of factors including the available memory on your E2 and other installed applications, the problem might or night not be caused directly by the program you were trying out. But once you get the E2 unfrozen, you should refer to this article to troubleshoot the cause of this apparent software conflict:
http://kb.palmone.com/SRVS/CGI-BIN/WEBCGI.EXE?New,Kb=PalmSupportKB,ts=Palm_External2001,Case=obj(27908) Also, I recommend going to the developer of the software you are using, to determine whether there are any compatibility issues at their end, and whether they have an upgrade available.
Here are the directions for the hard reset.
1. Press and hold down the power button.
2. While holding down the power button, use the tip of your stylus (or a similar object without a sharp tip) to gently press and release the reset button inside the hole on the back of your handheld.
3. Wait for the Palm Powered logo to appear and then release the power button.
4. When you see the message that warns you about erasing all your data please continue and then follow the on screen directions.
If this doesn't help then I recommend going to www.palm.com. From there you will need to select PDA's and then the model of yours. It will go to another screen and you should be able to contact palm via free chat. I have had to do this several times and both times I got fast service. Hope this helps.
Aug 24, 2009 | Palm Tungsten E2 Handheld
Fatal Alert when doing hot sync on palm tungsten e2
you gotta do a hard reset. i had the same problem. go to the palmone website and look up how. make sure you back your stuff up in case you can't get things back. once you perform the hard reset the error should go away.
Nov 09, 2008 | Palm Tungsten E2 Handheld
Fatal alert
Do you have an MP3 installed on your Palm?
You might have to reinstall it.
Jun 13, 2008 | Palm Tungsten T5 - Multilingual Handheld
Fatal Exception every time I sync.
Check docs to go and Avantgo Documents to Go and Avantgo are usually the culprit with me; if you use these try to reinstall. Check (delete and reinstall) "complex" applications, build to be able to use databases on the SD card. The final straw is the procedure suggested by Palm; -make a copy of your back-up from the palm directory; program files/palmone/van/backup. - do a hard reset - reinstall the applications one by one, hotsync after every install until you have found the offending application
Sep 11, 2005 | Palm Zire 72 Handheld
What is LyncHS, and Why am I crashing EVERY day?!
LyncHS, Zire 72, Soft Reset and XP Professional I do a sync and my PDA crashes... I have to do a soft reset almost every single time. I have been having the same exact problem but cannot seem to find anyone who can help!!!! Before I got my Zire 72 I had this problem with my Sony Clie. I even narrowed it down to this LyncHS application and still could not get help. I finally purchased a new PDA because I was getting tired of this happening. It was not the PDA... it is the Palm OS or a Palm application that is a problem. I have not installed ANY third party applications so PalmOne needs to quit trying to tell me to uninstall those. MitaMe, you are absolutely correct... this is not acceptable and since I am not the only one having problems, I fully expect PalmOne to take it more seriously and try to resolve it. I should not have to perform a soft reset most every time I sync on my Windows XP Professional PC. By the way, I sync on my computer at home which is not Windows XP Pro and this does NOT happen.
Palm Zire 72 Handheld Logo
192 people viewed this question
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
