Question about HP iPAQ H2210 Pocket PC
After A Hard Reset IPAQ H2200 starts but wont restart after i switch it off
Hi. I have an IPAQ 2200. After a hard reset the unit starts up and I enter in all the details required, it charges up i.e. The amber light flashes and then goes solid. When I check the battery stats it shows full charge for both batteries. If I swith the unit off by pressing the power button at the top right hand corner, I cannot get it to switch on again unless I perform another hard reset and go through the whole process of entering in all the data once again.
What am i doing wrong?
How do i fix this problem?
  • Theatrix Jun 24, 2008
    Thanks for replying Hp_man.
    I have tried that and it still does not switch on again.
    Any other Suggestions?
  • 35 Answers
HOLD DOWN THE POWER BUTTON WHILE YOU DO A RESET.
Posted on Jun 23, 2008
I have an HP iPAQ 6920 with a Keypad Security Lock Code. My son while playing with the phone repeatedly entered the wrong code and now it's not accepting my original code. Also there's now a 2m 08s...
Welcome to Fixya
Passwords are encrypted type. There is no special code that you need to enter to bypass the password for this unit. The only way for you to use this unit again is to do a Hard Reset. Meaning everything will be back to original factory state. If you decide to do that, then please follow the procedure below:
A clean reset clears all user-installed settings, programs, and data, and restores
your HP iPAQ to factory settings.
To perform a clean reset and return your HP iPAQ to factory settings:
1.Press and hold the Answer/Send, Power, and End Call buttons.
2.While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the HP iPAQ until the device restarts.
3.When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ restarts and powers on.
Thank you for using Fixya!
Dec 24, 2010 | HP iPAQ hw6920
I want to format my ipaq hx2410 please tell me how to do that
To perform a hard reset you need to press buttons 1 and 4 in addition to the reset hole. This should do the trick.
The guidelines for resetting your phone is given below
Performing a Hard Reset
Perform a hard reset only when you want to clear all
user-installed settings, applications, and data from RAM
(Random Access Memory), where data and applications you have
loaded are stored.
CAUTION: If you perform a hard reset, your Pocket PC loses all data
and programs not saved in iPAQ File Store.
To perform a hard reset:
1. Press and hold down the Calendar and iTask buttons.
2. While holding down these buttons, use the stylus to
lightly press the Reset button on the bottom of the iPAQ
Pocket PC for about two seconds.
HP iPAQ hx2410 Hard reset
3. When the Pocket PC screen begins to fade, release the
Calendar and iTask buttons first, and then remove the stylus
Note: If you simultaneously push and hold the Reset, Calendar,
and iTask buttons for more than two seconds, the battery
disconnects. To restart the device, either plug the device into the
AC Adapter or press the Reset button again.
After performing a hard reset, you may need to reinstall
applications stored in iPAQ File Store to restore shortcuts and full
functionality.
4. The Pocket PC resets and powers on.
To return your iPAQ Pocket PC to factory settings after
performing a hard reset:
1. Tap Start > Programs > File Explorer > My Device.
2. Tap the iPAQ File Store folder to open it.
3. Tap Edit > Select All.
4. Tap and hold the selected files, then tap Delete.
5. Tap Yes to delete all file in iPAQ File Store.
Apr 03, 2010 | MyNetDeals HP iPAQ hx2000/ hx2100/ hx2400/...
On IPAQ hx2700, how do I do a hard reset? I want
loaded are stored.
functionality.
Sep 23, 2009 | HP iPAQ HX2700 Pocket PC
Not turning on
Hi there, I think you pressed some more buttons and accidentaly you entered your device into Serial Mode (Bootloader), which you should update your ROM or reinstall your existing ROM in order to exit that state. I am sending you a link to HP website including your device's ROM upgrade download link, and a complete list of instructions. First of all, connect your device with a usb cable to your PC and see the "USB Mode" in the screen of your PDA. Also please be carefull and read the instructions very carefully before starting the process. Here is the link: (http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?swItem=ip-55697-1〈=en&cc=us&idx=0&mode=4&) Hope this helps. Have a nice day.
Apr 20, 2009 | HP iPAQ H2200 Pocket PC
Rx5915
I got this info from HP website..
1. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the
Reset button.
It doesn't mention a password. I also have an HP Ipaq and don't need a password to hard reset. Good luck. If this helps you plz rate this. Thank you kindly.
Jan 31, 2009 | HP iPAQ rx5915
I forgot my passwod to my windows mobile ipaq 5.0
here is your answer
but if you want to solve your problem quick
microsoft takes 11$ to fix it
see this if this help you
Resetting the Device
Sometimes there is a need to reset your Pocket PC. Resetting the
device is known as performing a "soft" or "hard" reset.
Performing a Soft Reset
A soft reset stops all running applications, but does not erase any
programs or saved data. Be sure to save any unsaved data within
a running application before performing a soft reset.
Perform a soft reset to:
■ Stop all running applications
■ Install a new application
■ Restart the Pocket PC if it stops responding
To perform a soft reset:
1. Locate the recessed Reset button on the bottom of your iPAQ
Pocket PC.
2. Use the stylus to lightly press the Reset button.
The Pocket PC restarts and displays the Today screen.
loaded are stored.
functionality.
Oct 16, 2008 | Computers & Internet
Power-on delay
some software program is causeing it to slow down.
try uninstalling some of your programs, or preform a hard reset witch returns the pda into the original state.
How Do I Perform a Hard Reset?
Perform a soft reset when:
  1. Press and hold the Calendar and iTask buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the bottom of the iPAQ Pocket PC for about two seconds.
  3. When the Pocket PC screen begins to fade, release the Calendar and iTask buttons first, and then remove the stylus from the Reset button.
    CAUTION: If you push and hold the Reset button for more than two seconds, the battery disconnects. To restart the unit, either plug the unit into the AC Adapter or press the Reset button again.
Mar 23, 2008 | HP iPAQ HX2400 Pocket PC
Doesn't start up
Hi, Based on your post/description, your iPaq 2210 will not power on. It is possible that your battery is deactivated. To reactivate, plug it to the AC power supply/adaptor, press reset at the back of the unit. Assuming no other problem, the unit will initialize back to default factory settings. It's very likely that all your previous/personal settings, files and applications will be also gone. Good luck and pls post back how things turn up. Kind regards.
Jul 21, 2007 | HP iPAQ H2210 Pocket PC
IPAQ 5455 Hard Reset
Just hold down the calendar and today buttons, these are the two outer buttons on the lower left and lower right, then using a stylus press and hold for at least ten seconds the soft reset button this is located on the lower right edge of the unit. The screen should reset and the iPAQ will boot up again.
Sep 07, 2005 | HP iPAQ H5455 Pocket PC
Hard Reset HP 6515
Hold down the POWER button and press the reset hole for approx 5 seconds, then remove stylus from reset hole first, follow by release of POWER button.
Sep 07, 2005 | HP iPAQ hw6515 Pocket PC
HP iPAQ H2210 Pocket PC Logo
861 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
