2008 Ford Focus SE Sedan Logo
Anonymous Posted on Jun 14, 2008
Manual hi looking for user manual for 2008 ford focus style estate TDCI.
Anonymous
Level 1:
  • Contributor 32 Answers
  • Posted on Jan 08, 2009
Anonymous
Contributor
Level 1:
Answers
32
Questions
0
Helped
19203
Points
73
The user manual can be found at http://www.focusplanet.com/
Scroll to just below the pictures, under the Focus Owner's Manual section look for year 2008. Click the link and the manual will open/download as a PDF
1helpful
Can you instigate a dpf clean on a 2008 ford focus 1.6 diesel tdci without using a diagnostic machine thanks
Yes, drive with the revs above 3000RPM for 20 minutes. Motorway driving at 70MPH is ideal.
2helpful
2006 Ford Focus Ghia tdci estate manual that shows the speed control buttons that I have in my car.
When setting the cruise control first you have to be going more than 30-35mph.then press the on button then when at the desired speed press the set+that should do it the set-is the coast button and the resume button will bring you back to the last speed setting remember if you touch thr brake pedal it shuts of the cruise while in motion
Where is power steering resevoir on focus 2006 1.6 diesel
There was an issue with the steering in that 04-11 focus... let me see if I can find the problems they've had for you.
Ford Focus fuel pipe leak (2004-2011 cars)
Cars built between July 2004 and February 2005 could have had problems with their fuel return pipes leaking. The pipes were made from material that degraded over time, allowing fuel to seep out.
Ford Focus wiper motor problem (2004-2011 cars)
On early second-generation cars built between April 2003 and March 2005, there were issues reported with the wiper motor. Water could enter the motor through the arm spindle, and if it contained salt, could short-circuit it and cause the motor to overheat. This could lead to trim melting around the motor.
Ford Focus engine failure problem (2004-2011 1.6 TDCi cars)
1.6 TDCi Focus models built between February and June 2004 might have problems with their engines, causing them to cut out. Misaligned oil feeds between the cylinder heads and camshaft bearings reduced oil flow, causing premature wearing of the camshaft bearings and engine seizure.
Ford Focus brake pedal problems (2004-2011 cars)
Cars built between November 2005 and December 2006 could have developed problems with their brake pedals. In particularly cold weather, the pedal could become stiff, as the non-return valve in the pump began to stick.
Ford Focus roll-over protection problems (2004-2011 CC cars)
On some Ford Focus CC models it was found that there were issues with the roll-over protection system. Securing bolts holding the system in place were either loose or not fully tight. Therefore the protection would not be fully effective. Ford should have fixed this for free, so make sure the work has been carried out.
Ford Focus cooling fan problems (2004-2011 1.6 TDCi estate car)
On some Focus 1.6 TDCi estates built between July 2004 and December 2006 there were problems with the cooling fans. Where roads are particularly salty, corrosion could easily occur, reaching as far as the control module. In extreme cases this could cause it to overheat, which could lead to fire.
Ford Focus rear hub bolt problems (2004-2011 cars)
On some Ford Focus models built between February and April 2007 there were problems with the rear hub bolts. They could come loose because they weren't made to the correct design specification.
Ford Focus power steering problems (2004-2011 cars)
Ford Focus models built between April and May 2008 could have had problems with their power steering. Some of the hoses fitted were not to the required specification. The hoses could degrade and allow hydraulic fluid to seep out, which could either cause the power steering to fail or, in more extreme cases, cause fire when the fluid became hot.
Ford Focus risk of fire problem (2004-2011 cars)
Hatchback and estate 1.6 TDCi Ford Focus models, manual and automatic, built between January 2006 and January 2007 may have a risk of fire unless they've had their cooling fans checked. Salty roads could lead to corrosion, overheating and fire if not sorted.
Ford Focus water leaks (2004-2011 cars)
On second-generation cars, some owners have reported water leaking into the cabin. Check any sunroof or window seals before you buy. Also look for damp carpet inside, because it could have become mouldy if left untreated.
Every one of these issues should have been remedied by Ford for free, so make sure the work has been carried out.
1helpful
I need a 2006 Ford Focus Estate TDCI repair manual
I frequently use and highly recommend registering for free at www.autozone.com Your registration gives you access to a variety of repair and shop manuals, most giving you detailed repair instructions and diagrams.
1helpful
My central locking will not work on my 2006 TDCI Focus estate, it is the manual locking system. when I lock the doors from the inside they all open up again as I walk away.
ALL ford focus do that you can not lock the car from the inside only the outside. Its to stop you locking your car keys from inside.
1helpful
Focus estate creaking and grinding when turning right
Could be the CV joint needs greasing up, or replacing, check for splits in the rubber gater around the drive shaft(looks like a bellow). Replace if necessary.
Black smoke when turbo kicks in
Remove and clean the EGR valve.If that doent work replace the airflow meter.
Fm radio doesn't tune
check that the antenna is plugged into the back of the unit or look under your fender and make sure it is plugged in there as well or use manual search instead of autosearch
2answers
Ford focus car
hi from uk all new cars in uk have drivers handbook and service schedule enclosed and when each service is completed ? the service recorded and book stamped as part of your warranty as to regular service/history should you rq any warranty work ?
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
