Question about SanDisk Sansa m240 MP3 Player
Player not turning on
My player refuse to turn on i turned i press the power button vesides the volume button but nothing happens. However when i put it onto my comp[uter it detects it
  • jeevan nayak Jun 15, 2008
    i have tried charging it my coneecting to my computer for more then an hur but it doesnt respond however i can sync it with my media player and all
  • 96 Answers
Your player is lowbat. Try to put onto your computer in 1 hour or the laps charging of your battery, after that observed if your player turn on when press the power.
Posted on Jun 15, 2008
The screen is frozen on the PHILIPS icon and when i reset it it did nothing, but when i put it on the charger then reset it, it starts charging, but when i take it off the charger it goes back to the...
Please follow the below steps and check if that resolves the issue:
  1. Press down on and hold the "Power" button on your Philips GoGear MP3 player.
  2. Press down on and hold the "Volume Up" button on your Philips GoGear MP3 player. Continue to hold both of these buttons down for three consecutive seconds. The MP3 player will turn itself off.
  3. Press and hold "Power" until your Philips GoGear MP3 player turns itself back on. Your GoGear will no longer be frozen and you can use it as normal.
If you require further assistance then please revert back.
Regards
Anand Gupta
May 04, 2011 | Philips GoGear ViBE Digital Media Player
Bn59 00463 volume works nothing else cant turn on
Step 1: Remove the batteries
Step 2: Press the power button (red button) on the remote control 5 times.
Step 3: Replace the batteries and your remote should work fine.
Oct 20, 2009 | Samsung Televison & Video
Same here
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work.
Aug 30, 2009 | SanDisk Sansa MP3 Player
Power
First, try a soft reset. Do this by pressing the center button and the up volume button simultaneously and try turning it on. If that does not work for you, you will need to get a micro sd card (it can be a dummy) and insert it into the slot on the side of the mp3 player. If you do not have one, you can use one of the round edges of a paper clip (be careful) to get it to come on. When you put either in, it should come on automatically, but if not, just press the power button. This should work for you.
Sony walkman nwza 818 volume control button wont turn up! I press the plus button on the volume control located on the side of the mp3 player, and it does nothing yet i can still turn it down! please help
My Sony MP3 player's volume control button wont turn up! I press the plus button on the volume control located on the side of the mp3 player and it does nothing yet i can still turn it down! Please help
Jul 29, 2009 | Sony Audio Players & Recorders
Volume is all the off and will not turn up
sound like ur volume avls(volume limit is on) so go to settings thengo to common settingsin that the second one down should be AVLS or (volume limit) contoller. also does it go up at all or does nothing happen.
Apr 17, 2009 | Sony NWZ-S615F Walkman Video MP3 Player
When i am turning on sansa e260, the screen always shows sandisk
try to open up the the mp3 player by taking off the screwes....(make sure that you are using a NON magnitized screwdriver) and remove the back and take out the batter and try to press the power button....then put the batter back in but dont put the back cover back on....now try to turn it on if nothing happens take the battery out press the power button then take out the next set of screws(they should be silver colored) then take all faceplate off then clean the inside of the buttons with que tips and rubbing alchol...(do not use the menthol rubbing alchol{may leave crystals behind that can hurn the mp3 playin in the long run}) then out the face plate back on and put the battery back in and press the power button...should turn on if not u have a bad connection somewhere with some of ur bottons.....
Feb 15, 2009 | SanDisk Sansa e260 MP3 Player
My alpine works but it puts out no sound
Hold down the (F) button for several seconds. Release button and select (General) by turning volume knob and press (enter). Now select (Power IC) by turning volume knob and press (enter). Now turn knob and select (on) then press (enter). Hold (escape) button for several seconds.
Feb 06, 2009 | Alpine CDA-9886 Car CD/ MP3 Player
Dell DJ Ditty
For this player, mtp device = good, wmp 10 =good, and xp =good - so your system definitely meets the requirements.
Dell did not list any other repair methods other than reset. You could try this, but it is a long shot: Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
I'm thinking that this one just has a circuit/power supply malfunction and will need to be replaced. The starting price for an Mp3 repair service is usually $280, and most will refuse b/c the mp3 manufacturers will not supply parts (Dell officially washed their hands of this product in 2006).
Jun 13, 2008 | Dell DJ Ditty MP3 Player
I was using my sansa e250 when it froze
perform soft reset on the device press and hold the menu/power button for about 30 secs until the player turns off.
Dec 03, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
