Question about Hitachi Televison & Video
Remote for 160gb hard-disk recorder has stopped working. Not a battery issue.
  • grorignaux Jun 19, 2008
    thanks for the tip on the camcorder. It does work and shows that the remote is still operational.
    Armed with that, any suggestions on where to go from here. Is it just a matter of having the unit serviced, or is there anything anyone knows of that I can try myself? I didn't say in the original post that the unit is a Hitachi.
    Cheers
    G
Purchase a harmony 670 remote and it can be programmed for your device
Posted on Jun 16, 2008
    Habit-Forming:
  • 166 Answers
The camcorder test is a new one on me, we repair lots of remotes the most usual cause of troublwe is liquid spillage first remove screws if any then carefully prize the two halves of the case apart remove the PCB and the rubber membrane the membrane side of the PCB will look sticky and wet clean with Isoprypl alcohol also the membrane reassemble fit new batteries and try.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
YOU CAN VERIFY THAT IT IS NOT WORKING BY RECORDINGTHE FREQUENCY WITH A CAMCORDER. To do this, you simply point the remote at the camcorders lens while recording and press buttons (with good batteries in the remote). Next, play back the recording and you will see the remotes output flashing if it is working....and of course, no flashes means the remote is dead. Remotesare pretty much useless to fix because it is cheper to replace them. You can look for the same remote on Ebay or go to Walmart to buy a Universal Remote that you can program.
Posted on Jun 15, 2008
Error code recording stopped. Problem with record buffer
I've done some searching this seems very proprietary, I would first try contacting the manufacturer directly to see if t hey can shed some light on this issue.
Jan 23, 2015 | Tascam X-48 48-track Hybrid Hard Disk...
Hello, I have allmost full wd passport 160Gb disc, computer don't recognise disk *** passport (it's writen "local disk" in folders section in explorer) say it's not accessible and...
Hi there and welcome to Fixya!
This error indicates that the processor is not able to communicate with your External Hard Disk.
I'm pretty sure you've already tried connecting the External Hard Disk to a different computer. If not, this is the best time to do it to isolate the issue. If you're having the same issue with other computers, then the problem lies with the External Hard Disk. There's a possibility that it's damaged, corrupted or infected by a virus. If it's still under warranty, get assistance with the manufacturer. If it's not, try checking the cable for any physical damaged, or better yet try a known good working cable.
Also, try restarting the computer when the External Hard Disk is connected to see if the computer can check its volume during the reboot. If the External Hard Disk failed to load after restarting, it is a possible virus issue. I would suggest running the most up-to-date antivirus software that you can find to scan your system and the external hard disk itself.
Jun 29, 2011 | Western Digital Passport 160GB External...
Transcend 320GB is recongized as "unformatted"
Here is an article with some ideas on how to solve issues with an external hard disk.
If it does not work, one last option is to take the hard disk out of the case and connect it directly to the SATA or IDE interface in your computer.
Jul 01, 2010 | Transcend 160Gb StoreJet 25 Unveils Rugged...
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
Formatting disks for EDSR1600
The EverFocus EDSR Security DVRs use standard PC Parallel (PATA) hard drives. I have used ATA100 and ATA133 speeds with no problems. There are no PC-type settings required except as below. The DVR has it's own internal firmware and will format the drive to its requirements.
If you are using a SINGLE drive tray, the largest hard drive I know will work is 500 GB. Set the drive to Master and you are done with the hardware setup. (CS Select would also probably work.)
If you are using BOTH drive trays, the largest hard drive EverFocus says will work on the EDSR100 or EDSR110 is 320 GB. Set both drives to Master and you are done with the hardware setup. (CS-Select on both would also probably work.)
Do NOT set any drive to Slave!
Lock the drive trays; if you don't the DVR will not go into record.
Press the STOP key and then press the MENU button. Go into the SYSTEM menu and do a DISK RENEW. This will erase the hard drive and also prepare it for DVR recording.
Do this by using ► or ◄ to select DISK RENEW. Change NO to YES (by using ▼ or ▲) and press the ENTER button. Highlight YES again by using ► or ◄ and again press the ENTER button.
Press the MENU button to exit and reboot the DVR. Then press RECord and you should be recording.
Aug 09, 2008 | EverFocus EDSR1600 16 CHANNEL 160GB...
DVD Recorder LG 160GB HDD/DVD Recorder
There will be a delete option in the list of recordings somewhere.
With out a model number it is impossible to know exactly where.
Jun 25, 2008 | LG Televison & Video
Can't record onto disc
press dub on your remote, it will open the menu choose your programme you want record then click on hdd to disc.
Mar 02, 2008 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
Televison & Video Logo
63 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
