In this case it probably missing the video driver and this is the reason that it can not configure the video mode..If you don't know if it has the driver or not ..or if the driver is the one from windows..try to download and install the original one from the support site ..and run it into computer .When you finish ..restart the computer and try again ..If the video card is compatible with the game ..it will work ..If it still does not work ..it means you need a graphic card with more resources .. to be sure ..check the minimum requirements for the game to run ..They are available on the internet ..just search for them ..If your system does not meet these requirements the game can not load proper ..
Looking at the specification of the motherboard, the maximum you are looking at is 512MB AGP card (Nvidia or the like), unfortunatley i cannot tell you exactly which one, as differnt cards are used for different things i.e. gaming, web creation etc etc
You should find out what kind of video card you have and go to the website for that video card and download the newest drivers available (example www.nvidia.com ) It can be the graphic card doesn't have enough memory to run the game. Some of them are very demanding on video resources. Check out the minimum requirements on the game for system ram and video ram.
you can't do because those games require builtin directx 9, pixel shader v 3.0 and other stuff
The Mobile Intel® 915GM/GMS, 910GML Express Chipset family is compatible with versions of Microsoft* DirectX* up to 9.0. Support for previous versions of DirectX (8.x, 7.x, 6.x and 5.x) is also available.
In conclusion, if you want to play those games you must buy a better videocard
This could be a problem with your EDGE DS software. Check you have the
right software by visiting the official EDGE DS website at edge-ds.cn
(NOT edgei-ds.cn, this is a FAKE site).
If you want info for now to tell the difference between a real and fake
iEDGE, just in case, check out:
is this a multi card or a normal game, if its a multi card for e.g R4 or Ncard you need to change the save format settings, but if its a normal game one of the teeth could be damaged or even a glitch, if thats it then you need to take the game back to where you bought it from (depending on how long you have had it between 6 to 8 months)
When you upgraded your video card, did you also make sure that you were not going over the limit of availible power from your power supply. Once in a while a computer will either tell you that you cant use the computer because it doesnt meet requirements or it just will boot up then shut down immediatly Also, make sure that all drivers are current for both motherboard and video card. I find it best to have both installed before physically installing a new video card.
Your video card drivers are most likely the culprit. Go to HP.com, find the drivers and downloads section and get an upgraded video/graphics driver. Either that or you need to upgrade the video card in the computer, not sure what kind of slot or if one is even available for the d530.
Usually these cards are problematic because get stuck when you fill the available memory with game saves and you must use a special SLOT-2 reader/writer to delete, add or edit files in the card memory from a computer...
If your card seller didnt included that reader/writer with the card then you must call them for support on your problem or try to guess what card model is yours, If you know that info is useful to put it in your question, If not then you have to make a research in internet.
