My Memorex VCR Model MVD4543 I am unable to setup and program
  • valentine641 Nov 05, 2010
    Note I am un able to setup VCR Time Date, and all other setup necessary to operate VCR.
    Valentine
  • 736 Answers
If you need the manual it is available here http://dl.owneriq.net/e/e3a8d328-f590-43ad-b1d9-73347c9f7e90.pdf
To set the date and time you need to per page 24 press setup while in VCR mode and using the upd down left right button to navigate through the menu/screens and press the OK button to select the highlighted option.
So highlight Clock Set and press OK. Enter two digits for the month, two digits for the day, and two digits for the year using the number buttons on the vcr's remote. If it isn't understanding 10 for the year try 82 for the two digits for the year. When you are finished insterting all of the numbers the hour digits will blink.
Enter two digits for the hour and two digits for the minute using the number buttons. Press the number 1 button for AM or the number 2 button for PM after the AM/PM setting blinks after entering the digits for the hour and the minute or use the up/down to select am or pm. Now press select and you should be done.
It isn't clear what else you need help with. Timer Recording is on the next page of the manual but that is normally not applicable for VCRs like this one anymore because they do not have digital tuners.
Is it connected to the television properly? Plug in the cables to the vcr where is says out and connect the other end to the television. Switch the television's input appropriately or tune it (the tv) to channel 3.
Posted on Nov 05, 2010
  • Televison & ... Master
  • 17,130 Answers
If you meant that you are not able to program the VCR for the timer recording then it is possible that the fault is in the processor/controller of the timer unit.
Please confirm if the VCR is working otherwise with all the function in order except the timer setup and channel programming.
If so the tuner module /programming section has errors and needs a check. This is a sensitive section and will require experience in electronics to proceed. Please confirm
I need a manual for a memorex mvd4543
Try Googling (Memorex)(mvd4543)(manual) without parens.
May 08, 2017 | Memorex Televison & Video
Hook up to tv to record from tv.model mvd4543
Download the user manual to your set from net. It will have all connection details. To download it, click here.
May 26, 2012 | Memorex Televison & Video
Memorex model MVD4543 The DVDs are only playing in black & white. I can't get them to color. Help!
You might want to make sure that your connecting cables are correctly hooked up. B/W picture can be caused when you mix up the connections of component cable. Make sure all the colors match, red with red, blue with blue, etc. Hope that helps!
Jul 18, 2011 | Televison & Video
I am wondering how to record a tv show on a blank VCR tape. The VCR I have is a Memorex MVR2031 VHS VCR. Can you help with step by step directions?
Cable from Programming source to TV. Tv OUTPUT cables to VCR INPUT. You will need to check the VCR Manual if you still have it. retrevo.com doesn't have your model listed since it's classified as obsolete, even though many people still have VCR only units.
You have to set your recording channels on the TV to match the switches on the VCR. May have to do it by menus, remotes or both and or just switches on the back of your units.
Here are some basic how-tos:
http://www.ehow.com/how_5024699_setup-cable-tv-vcr.html
http://www.ehow.com/how_5126493_record-tv-shows-vcr.html
http://www.mvrhs.org/library/How_to/TV/VCR_Recording.html
http://www.ehow.com/how_6849_hook-vcr.html
Setup varies based on source of programming (ie satellite, cable, etc) Good luck. Hope this has helped.
Mar 09, 2011 | Memorex MVR2031 VHS VCR
Need coades for memorex
It depends on what remote you are trying to program to the Memorex MVR4040 VCR.
Almost every remote control2_bing.gif that is used today can be found at:
http://www.remotecentral.com/search.htm
Enter the model number of the remote you need codes for in; 2.Search For Downloadable Files.
Once you see the remote you are using click on View Details, click on Download File.
Find the code for your device and program the universal remote control as indicated by the manufacturer.
Feb 09, 2010 | Memorex MVR4040 VCR
I just hooked up a cable to my Memorex, and do not know how to program the tv thru the remote.
Using the remote, click on menu and find setup. Click on it and answer the prompts. Regards, Joe
Jan 07, 2010 | Memorex MVT2135 13 in. TV/VCR Combo
Programming Device Control code for Memorex MVT2135B
21479 is the Sansui code that worked for me with the Memorex TV/VCR combo MTVT2135 and the Comcast Custom DVR 3 Device remote.
Jan 20, 2008 | Memorex MVT2135 13 in. TV/VCR Combo
Remote codes
dvd will **t show on tv these production are ** good hadn't been sents day one and ***** buy a**therone
Nov 13, 2007 | Memorex MVD4543A
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
