Question about ASUS motherboard P5S-MX SE LGA775 SiS671FX Dual core / Core2 Duo PCI-E integrated VGA micro ATX P5... (4719543152454)
No display when i boot up no disply of bios, but ok v.card.run cfu fan,
My cpu is front light on but not go to disply powr fan is ok runing but not show the disply plz help me any on
check the display monitor cord to CPU if attached perfectly/check on off switch of display screen
Feb 23, 2015 | Computers & Internet
My VGA has been corrupted. How can I fix it?
Hi , I suggest to check for any thermal issues including condition of the video card fan / heat sinks ie dust ,
If supported you can run a LINUX disk like Ubuntu in live / try mode
If video works ok , then most likely a Windows environment incl hardware conflict or virus / driver corruption issue ,
but if not then most likely a video card hardware issue like bad card cooling fan or excessive dust - thermal shedding issue or card bios/chipset fault
If a likely software issue then uninstall and then reinstall the video card
Consult ASUS or Nvidia support
The procedure is something like this
Onboard video support ?
yes
uninstall the video card driver and any video vendor configuration applets
Uninstall video card in device manager if still present.
Shut down and remove mains power cable
remove the hardware video card ,
(using anti static electricity procedures)
Attach onboard video to display
Power up and enter and configure BIOS setup if required, ie 1st seek onboard video
Bootup to Windows
Install the onboard video device
using Windows plug&play default driver executed during booting
Restart
Confirm working ok
Update the chipset driver (inf) if applicable,
restart
Shutdown
Reinstall the hardware video card
Attach to display
Reconfig BIOS setup if required
Start to install default driver
Install video driver / update from card default using a known good driver whose setup file has been previously downloaded
restart and test
Hope this helps
Dec 06, 2013 | ASUS GeForce Computers & Internet
Xfx video card stop displaying on monitor. I use xfx motherboard connector instead and display is OK
This is a BIOS problem, you have to boot to BIOS config menu, do it by pressing f1 or f2 or f10 on boot splash screen, browse the menus and find an option like 'init display first' or something like that, set it to Pcie or AGP, depending on your motherboard, reboot and voila!, have a nice day
Mar 08, 2011 | XFX GeForce 7800 GTX, (256 MB) Graphic...
Gateway GT5220 bios works no boot up
If the issue was the video card then there would be no display. If there was any display it would be discolored.
Try unplugging any removable media that's hooked up to the computer. After that try to boot it up.
If it still doesn't go anywhere then you most likely have a power supply issue on your hands. try unplugging an unnecessary components inside the computer such as any CD/DVD drives and removing any cards installed. Pretty much everything but the motherboard and the hard drive. If it still doesnt boot properly then you might either have to buy a new power supply or a new motherboard as long as you know your hard drive is good.
The thing si if it was an issue with the hard drive you would get an error message. If you seemed to have left out any error messages please post them.
Jun 07, 2010 | Computers & Internet
Installed gf6200 windows wouldnt start up
remove the card, go to setup utility in disply mode section use the AGP or PCI disply setiings or auto then save settings. turn of pc, install the card and then reboot, this time system will boot up, actually system boots but no display is being given.
Jan 07, 2010 | Nvidia GeForce 6200 AGP Graphic Card
Error code =8302
check your bios settings that the vid output is set to boot from the right device that you want it to be from. try reseting defaults
Feb 24, 2009 | MSI P4M900M-L Motherboard
Pci express slot
Hi dineshcs.
When adding a new graphics card (Your's being a PCI-Express), you must change a bios setting under the title " Advanced " section. Open you're M2N-MX manual & turn to page 2-21. You need to change the boot order for you're graphics to list,
[PEG/PCI]. Change Initiate Graphic Mode Select to [Disable].
These changes stop the onboard graphics card from loading & allow the PCI-Express card to load. The issue of possible motherboard overheating can be caused by many things. Here is a list of things to check.
1). Check the CPU heat-sink fan. Make sure the fan blades are
free from dust build up. Check fan speed in bios (Its RPM will be listed). It should be running a min of 2300 RPM.
2). Also in the bios is Hardware monitor. By booting into the bios go to this & watch the temp of CPU & motherboard. If either is getting too hot suggest you add a side case 3" fan to the system to help lower the CPU & motherboard temp.
Good Luck!
Mike
Jul 18, 2008 | ASUS M2N-MX Motherboard
Powering up, but no video display
u back cmo pin on 1 2 only 23 resets it wont boot do u have onbord video out port use thatto see in bios then change it to pci express or agp whetevr uuse to boot off 1st in inet disply ok
Jan 23, 2008 | ECS 945GZT-M (V1.0) Motherboard
Intel 845 GVSR
90% in d845gvsr cpu dry problem , when we press fan after that swicth on the system may be it's giving display solution is bake cpu socket at 200 digree C, after it's working fine otherwise there is no solution. cpu socket problem like hang, restart, some time display , just bake the cpu socket with hot air gun or bga machine,
Nov 11, 2007 | Intel Motherboard
Itz a P2509
try to disable your eithernet card in bios and see if you still get the error.
Mar 30, 2007 | Toshiba Satellite P25-S507 Notebook
ASUS motherboard P5S-MX SE LGA775 SiS671FX Dual core / Core2 Duo PCI-E integrated VGA micro ATX P5... (4719543152454) Logo
52 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
