I have an 18 month old acer AT3220B TV - it has always had a rather loud humming noise in the background and also the volume adjusts itself?! Now I have a vertical black line down the RHS of the screen? A friend also bought the same TV at the same time as I did and within 3 months had the black line in the same place as mine is - he was told the TV was not worth fixing and was given a replacement TV. Mine is still under warranty. I am curious what causes this black line? the humming noise? and the crazy volume?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 105 Answers
The TV reciever is capable of recieving an interference especially if your mobile cellphone is near the TV otherwise the black line which is shown on your screen is not normal,you have to sent your unit the service center.....
Posted on Jul 08, 2008
Background noise and music is so loud we can't understand the dialog
If the sound was disconnected, you would hear absolutely nothing at all. There is a problem with the sound signal itself, so connecting external speakers probably would not help at all. Electronic components have failed, which caused the sound problem issue.
Aug 05, 2014 | Sceptre Televison & Video
Hello I have a Technics SU-V45A amp, it's about 18
See there is a problem with the volume conroller as it is 18 years old the controller has worn out replace the volume controller with a new one and you will be able to enjoy great sound again
Dec 05, 2010 | Technics SUV500 2-Channel Amplifier
Loud background noise
Have you already tried to lower the volume on the headset itself some steps, during the call, until you hear the conversation clearly?
Just my 2 cents... Carlos
May 12, 2010 | Samsung WEP410 Bluetooth Headset Wireless...
Wanted to adjust quality of sound, such as treble
Go in ur menu pick the audio go down pick the reset the tv set back to factory setting will get the
Mar 24, 2010 | Westinghouse SK-26H520S 26 in. LCD HDTV
Acer Aspire One laptop is making a humming noise when I start it
Locate the Microphone from the control panel and reduce or mute the microphone volume.
Control Panel, Harware and sound, Manage audio devices,recording
adjust the Voulme there.
Mar 11, 2010 | Acer Aspire One PC Notebook
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Buzzing/humming noise that increases as you raise volume. So loud that you can not even watch tv
Hello snow1525,
You may have a torn speaker element. This is usually the cause of buzzing noise in the sound, also you may have a bad capacitor in your audio section. This is what I would suggest doing as a test open the front bottom panel of your TV and visually inspect the speakers for signs of ripping and or tearing in the speaker element. If the element or elements are torn it may be possible to repair it with rubber cement or rubber paste just coat the tear with the rubber cement to hole the torn edges together and allow it to dry for two days before testing the sound. If the speaker elements are not ripped then the problem may be a bad capacitor either in the audio section (power supply) or in the filter block (usually attached to the speakers to separate bass and treble signal to the speakers.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Apr 16, 2009 | Televison & Video
TV making loud humming noise
Sounds like u need a color wheel
Apr 06, 2009 | Televison & Video
VCR Hitachi F361
The noise from the TV is called 60 cycle hum and it is caused by a capacitor that is open, a test for ripple voltage will confirm this The noise from the VCR is more then likely common mode noise which would not be heard but for the bad capacitors in the TV. Simply put the common mode noise is being added to the 60 cycle hum. Now for how to fix this, if you have a background in electronics you can use a schematic, multimeter and an oscilloscope and Multimeter to find the bad capacitors, and the schematic to tell you what the voltages and %ripple should be. If you do not have a background in electronics, take the set to be repaired
Sep 29, 2007 | Hitachi VTFX631A VCR
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
