2.5'' Mobile HDD not beingread at all
Hello. I'm desperate. I just put some gigas of video on this removable HD , and now no computer can read it. They say USB Ide found and then reading error . No icons shown. Maybe I havn't deactived the right USB hub before unplugging, but it's strange that for this I have to throw away an expensive device (my father's, by the way)
If more info are needed ask me
THANK YOU
  • 4 Answers
A,
I have had many of the same issue with portable USB hard drives, what the industry does not tell you is that they get hot in those cases, and there is not active cooling (i.e.: a fan). Usually, that is not a problem for the hard drive itself, however, it is for the USB to hard drive bridge electronics. This is good for you, as, more than likely, the drive is good and the USB bridge, which is separate, has failed.
You will need to carefully take apart the external USB case and connect to your computer either with a new USB case you can get at a good computer store or online store, or if you are technically more inclined, you can attach to a IDE port of you desktop PC witha 2.5" to 3.5" disk drive adapter.
If you need more specifics, let me know and supply the make and model of your USB drive.
-J.
Posted on Jun 15, 2008
Undelet hd
Here's a how to partition, you just do it in reverse, sort of:http://www.pcworld.com/article/73826/partition_your_hard_drive.html
Nov 26, 2012 | Toshiba TECRA P5 C2D T7700 2.4GHZXP PRO CD...
My Lap top HDD is not showing up when connected to my Desk top. my siemens lap top hinges broke. I tried working with it and damaged screen. Removed HDD drive and found a free case at home with the USB...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Jul 12, 2011 | Silver Jeans MOBILE DISK HD-234-U2P...
I have an Argosy Mobile Video HDD & when i connect it to Windows XP with his SP3 i have a text saying "the speed of your HDD can be faster if you connect it to a USB 2.0 port" the problem is...
Hello.
for this problem a simple solution is here change your Harddrive USB Cable and check it its working or if its not working please check in under device manager remove USB Driver and Install it again
May 15, 2011 | Computers & Internet
I have G41M COMBO(GIGA-BYTE) mother bord with 1G Integreted Graphic Card (Intel), 2G RAM DDR3. Problem when running games Computer becomes to slow
The onboard video chip is very weak and it can't handle the amount of data required by a game. There's only thing you can do - install a decent video card.
Oct 20, 2010 | Asrock G41M-GS Core 2 Quad/ Intel G41/...
Notebook cant see my 30 giga hdd
i assume the armada is a compaq product? if so, you may want to read your installation documentation- hdd may have jumpers, or spacers that need to be re-located! if it's not a compaq 'compliant' product, then good luck! compaq hardware is very 'proprietary'! meaning, if our laptop don't like it, then it don't work!! i've tried compaq ram on a toshiba- slotted right in! no prob. 'til i booted! didn't like it! seems very unfriendly to me! if your hdd 'kit' is supposedly compatible with your laptop, then, as i stated- check dox for jumper, or spacer settings. remove hdd and check for bent pins!! if there are any, very, very carefully- using fine tweezers- straighten them until they socket properly!
break one of and you're s.o.l.!
you may have a friend with the proper tools, and a steady hand who could assist, it there's a bent pin!
the hdd can appear to seat properly, but still have a bent pin. check any jumper/spacer settings first! also compatibility with your armada!
good luck!
Oct 19, 2009 | Compaq 30GB NOTEBOOK HARD DRIVE KIT FOR...
Video is choppy when transferring flipvideo
I have the exact same problem ... I have a Compaq ... Vista Home Basic, plenty of RAM 1.8GHz ... FLIP told me the exact same thing ... it's exTREMEly frustrating.
Jul 23, 2009 | Pure Digital Flip Video Ultra Camcorder
PS3 pwr issues
I had this same problem, I removed the HD from the ps3 and put it in my notebook (you can do it in any other computer), with the ps3 HD in my notebook I booted up from a bootable cd downloaded from the SeaGate web site (a diagnostic tool). The tool found and fixed a problem in the ps3 HD, after that I put it back in the ps3 and it worked. =)
Hope it helps.
Oct 06, 2008 | Sony Playstation 3 (PS3) Console
P4VM890 + new videocard! No boot up!
welcome to fixya
Well i never did it that way but ok
your going to have to reboot the computer with the reboot disk ,,
once thats done turn off computer and install the video card and then also insert the drivers disk that came with the video card
this should work has for me and i have done 100s of video cards
Although if you bought a good video card and still have a 400w power supply your going to run into trouble make sure you have a 500w power suplpy or better to run a good video card ,,,,,
i hope this helps you out have a good day:)
Jul 19, 2008 | Asrock P4VM890 Motherboard
Drive Lock Password for Hitachi HD in HP Pavilion zv5466ea notebook
probably a little bit late but I think I found a solution ...
1.pull the hard drive out of the laptop
2.boot computer into bios settings
3. set a new bios password and check lock computer
4.while the computer is on slide the HDD in the laptop again.
5. save and exit bios
6.fortunately in the next boot you will get your hdd back
Jul 05, 2008 | Hitachi TravelStar 80GN 80 GB Hard Drive
Computers & Internet Logo
255 people viewed this question
David Payne
David Payne
