SOURCE: Fn+F8 hotkey dose not work but the remain FX go fine
Another Alternative is to check your BIOS to see whether or not your Wireless is turned on, if it is not pressent in your BIOS then update your BIOS Driver on the Internet to ver 1.4, Double check your version Compatabillity. Next if the adapter driver is installed, follow the following intructions: start -> settings -> control panel -> system -> hardware -> device manager -> now look for the wireless adapter, see if it is operational or marked with an error -> if it is marked check that it is configured for automatic, and also the resources. Set the configuration manually if so. restart the system.
1) Resource conflict = change resource settings
2) No adapter = check if the adapter is enabled (Y) then see if there is any conflicts (y) correct the settings e.g. resources and see if windows shows that the device is enabled (N) try to enable this device. If (N) then goto BIOS settings to correct it.
Hope this helps
