Question about Nikon Cameras
Nikon d50 shutter sticks open and reads err in top lcd
Get the camera cleaned
Posted on Aug 07, 2008
Try taking the battery out for 48 hours while charging it.
then place the charged battery back in the camera.
go to the menu and reset the camera's defalt settings.
If this does not work it will certainly not hurt the camera.
And please send more info about how this happens and when.
Thomas Bauer
tom@tbauer.com
Posted on Jun 15, 2008
Err on top of display on camera
Unfortunately, this probably won't be a good situation. Most of the time the ERR(or) message you're getting shows when there's an internal problem, and most likely a shutter error. Not an uncommon problem with the older consumer models like D40, D50, etc.
Dec 27, 2013 | Nikon D50 Digital Camera
I get "Err" on the
The ERR message indicates a camera malfunction. In my D-90 manual it says that it can be cleared by releasing the shutter. The only way to do that is to turn the camera off and back on. Rarely, that won't work and you have to remove and reinstall the battery.
The manual also says that it this have frequently or persist to contact a Nikon authorized service center. I would contact Nikon tech support at www.Nikon.com and discuss the problem them before contacting an authorized service center.
Jan 25, 2011 | Nikon D50 Digital Camera
Hi i have dropped my d50 and err comes up
There is a motor/gear assembly inside the camera that moves the lens in and out and covers the lens when it is retracted. When it dropped, you most likely cracked or shifted something out of place. A broken tooth does not stop function, but shudders when it hits the gap. A shifted gear, slips and similarly may cause this effect. If it doesn't open the shudder, you get no picture.
You will need to open it up and attempt to repair the mechanics that drive the lens.
May 05, 2010 | Nikon D50 Digital Camera with 18-55mm Lens
Shutter sticks open. ERR and Clock flash.
It would help to have more information.
You should call Nikon.com repairs. Go to the website and find the support and the repairs and call the 800 number for the repair department.
Oct 21, 2009 | Nikon D50 Digital Camera
Wont take picture, Top screen says ERR. It's a D50
If it's a problem in AF and M mode it is an indication that it is probably your shutter. I have heard of similiar problems. Best bet is to call Nikon and explain your problem. Might have to send it in to be repaired or replaced.
Please rate!
Cheers
Oct 04, 2009 | Cameras
Shutter stuck half open
This sounds like the mechanism has worn. It is a straight forward service centre procedure, I wouldn't recommend trying to do anything that will make it worse. Leave it to Nikons engineers.
Mar 11, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
Err
If this only happens when using the flash - then it is a problem of flash synchronisation.
If it happens all the time - then one of the shutter curtains may be sticking.
Either way, you should get the camera looked at by a repairer.
May 07, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D70 Err
Sounds like the shutter is sticking. This could be due to damage or just need cleaning. This probably means that you need to get the camera professionally serviced/fixed as shutters are extremely delicate.
Nov 09, 2007 | Nikon D70s Digital Camera with 18-200mm...
Shutter
I had the same problem but replaced the lens with a different lens and it worked just fine.
Aug 27, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
Cameras Logo
227 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
