Question about Canon PowerShot A70 Digital Camera
Black screen camera powers up and all menu functions display ok but screen remains black in shooting mode
  • Anonymous Jun 18, 2008
    Yes, I have this same problem.
  • 5461 Jun 18, 2008
  • 2,039 Answers
Go to this link for UK. Near the top of the window, there is a search box. Type in 37383 and click the box right below it that is labeled "Search by Case ID". Then click the Search button. All information and instructions on the resulting page are applicable to the UK. There is a button at the bottom to contact Canon Tech Support.
Posted on Jun 14, 2008
My camera s flasnmode did not work it happaned when my camers power on for a long time how to fix that flash mode ?
If the built in flash does not function, then the Camera flash may be turned off or ot is set to Auto and will only flash when the taking pictures in poorly lit environments. To turn on the flash so it works regardless of the lighting conditions, press the flash button on the Camera until the Forced Flash icon appears on the LCD screen. The flash button on the Camera has a lightning bolt symbol on it.
If the Forced Flash setting is already enabled and the flash is still not working, then the issue may be due to another camera setting. Even if the Forced flash setting it enabled, the flash will still not work in the following settings.
When shooting movies.
When shooting in the Twilight or Handheld Twilight mode.
When shooting with the Burst or Multi Burst mode.
Shooting with the Fireworks or high sensitivity mode. (ISO)
Following the above steps should resolve the issue. However, if the issue persists try resetting the Camera back to factory settings and specifications.
Try power resetting the Camera to check if it resolves the issue. To power reset the Camera, turn off the Camera and remove the battery pack. Press and hold the power button for 30 seconds. Remain the Camera without power for 60 seconds and reinsert the battery.
If the issue persists, try Initializing the Camera. The Initialize option can be done only if the Menu of the Camera is accessible. To access Initialize select MENU-->SETUP-->SETUP 1-->INITIALIZE-->OK.
This should resolve the issue.
Thanks for using FixYa.
Jan 17, 2011 | Sony Cyber-shot DSC-W55 Digital Camera
Canon eos rebel xsi screen is black when taking a picture but shows picture afterwards..Menu works also so screen works but just black when trying to take a pic..
Set the shooting mode to a Creative Zone mode. Press MENU to enter the menu. Under the Setup tab, select [Live View function settings] then press SET. Select [Live View shoot] and press SET. Select [Enable] and press SET. Press MENU to exit the menu. Press SET. The image should now appear on the LCD instead of through the viewfinder.
Refer to "Live View Shooting," Chapter 5 in the manual for more details and the limitations of the LiveView mode.
Dec 26, 2010 | Canon EOS Rebel XSi Digital Camera
How do i change picture size on my coolpix l18
Press the shooting mode button in shooting mode to display the shooting mode selection menu and set the shooting mode to Auto (the green camera). Press MENU to display the shooting menu. Navigate to "Image Mode" if necessary and press OK. Take your pick of sizes here, then press OK to save the change and then MENU to exit the menu.
Nov 12, 2010 | Nikon COOLPIX L18 Digital Camera
I have a Panasonic DMC-LX2 digital camera, I'm based in the UK. Has worked fine for a couple of years, but 2 weeks ago, when powered up, none of the buttons work. Screen is illuminated, lens emerges OK,...
I just got identical situation today, and I have no clue at all. However, I figure that the camera is actually working busy like someone is holding the "UP" button continuously. To see this, power on your camera at any mode except the "Scene mode". After it's on, turn the mode select knob to "Scene mode". I saw my camera menu flashing like crazy. When you press any button, the menu should stop running. But once you don't press the button, the menu start running again.
Please let me know if you have any update.
Sep 21, 2010 | Cameras
Trying to change my pixels from 8 to .3 pixels...how do you do it? Nikon Coolpix E4600
In Auto mode press the MENU button to display the Shooting Menu. Highlight Image Mode and press Right on the multiselector. Highlight TV Screen and press OK. Press MENU to return to Shooting mode.
Mar 16, 2010 | Cameras
Camera Screen black
Time for a new camera, the cost to have it exchanged by Nikon is near the cost to replace.
Jul 11, 2017 | Nikon COOLPIX S5 Digital Camera
Canon Powershot SD1000: LCD screen display
Hopefully you resolved this already. If not, push the "DISP." button left of the MENU button. Pushing it gives you three options: black (for discreet shooting so your LCD doesn't give garner dirty looks from fellow concert goers), liveview, and liveview with info overlayed (shooting mode, ISO, etc.). Good luck!
May 05, 2009 | Canon PowerShot SD1000 Digital Camera
Sony w200(12.1MP) Shoot Mode no display
I was having the same problem earlier and I showed my camera to my father and he fixed it! What you need to do is press the center button (that usually toggles between viewfinder mode and LCD mode) and when the display is on (mine would come on for a second or two and then go black) press the up arrow (the display button). Now the display stays on during shooting mode! This fixed the problem for me and I hope it helps you out too!
Jan 16, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Camera screen remains black when I turn on shooting mode
Turn the camera on. With the screen showing, press the DISP button and this will give you a selection of different screen views i.e. squares for aligning shot squarely; black - thru viewfinder only; etc. Different modes will give you different screen displays i.e. P setting screens are different to when you have the camera set on AUTO.
Hope this helps.
Jan 11, 2009 | Canon PowerShot S51S Digital Camera
Shooting mode will not operate
Your camera has a defective CCD imager. Please return the camera to Canon in New Jersey and they will replace the CCD at no charge to you. This is a known issue and should be covered under extended warranty. Good luck my friend. Joe Weibel customelectronics.org
Feb 27, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot A70 Digital Camera Logo
60 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
