FixYa.com
Tags:
LG enV VX9900 Cellular Phone
Won't Charge- Is there anything I can do? (by 4 users)
posted by LOTP on Jun 14, 2008
Basically, my LG Env won't charge.
The little peice that cover's the place were you plug the cable into the phone is broken off, but does that effect it?
It charged earlier, but the cable had to be in some weird angle, and now it's not charging at all. : (
Am I going to have to replace my phone, get my phone fixed, or buy a new charger for it?
Help, Please! : (
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
3 Other Users Have The Same Problem
Comment by beck71, posted on Jun 25, 2008
Have the same problem, charger port is broke, had phone for about 8 months.I took it back to Verizon and they mailed me a new one, 2-3 day delivery. I have had new(refurbished) one for 2 months and this one broke already!
Comment by jaymeehayden, posted on Jun 21, 2008
My enV won't charge. I put the charger into the phone and nothing happens, the charger is really loose and keeps falling out of the phone.
Comment by Guest, posted on Jun 20, 2008
i have the same problem and dont know what to do i just bought a new battery and charger and it will ship in a few days maybe it will work. someone plz help
Solution #1
posted on Jul 22, 2008
Not Rated (0)
chrstinaaa
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
that's what is happening with my enV
i put the charger in and nothing happens at all.
and just to warn whoever gets a refurbished one...they are so messed up. this is my 3rd refurbished enV
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Jul 15, 2008
Not Rated (0)
littlesweet
Rating: 0%, 0 votes
well i dont have any long term ansa but here is a short term one while you find a new charger.
Take the charger and dismantle the end that plugs into fone. you should have 2 wires a black & white or black & red. Leave the blobs of solder on the end of the wires as this helps. Leave the wall socket end of charger in tact.
Take your battery out of fone. As with a normal battery you will see a (+) and (-) sign on it. Attach the black or darkest wire to the negative (-) metal square on the battery and the white or lightest wire (maybe red) to the positive (+) metal square on the battery (after trial & error i found a clothes peg to be the best form of attaching it). Leave attached for 15 minutes and this will give you around an hours usage when you put the battery back in the fone. If you leave it overnight then it will be on all day.
Basically you are making the circuit without the fone which bypasses your pin problem. Any charger will work with any fone as the charging components are in the wall end. Just make sure the voltage is compatible ie, 5v fone charger replacing 5v charger etc. Although majority of chargers are 5v.
I know this works cos i did it to mine last nite as i needed to ansa my emails. Really simple but a little drastic like i said but if the pin connector is broke anyway wot you got to lose?? I am a girl so if i can do it anyone can lol!!
Only drawback is you cant use the fone while it is charging unless you have 2 batteries and you use one while the other charges which is what i am doing. In fact i might not buy a new charger lol, i dont need one now ive found this method works.
Happy charging!! Hope this helps! Gail-michelle
Solution #3
Not Rated (0)
tyler914
Rating: 0%, 0 votes
mine did it to your charger port is broke take it back to verizon and they will give you a new one no charge
Can you Help with these Cellular Phones problems?
phone stays on the verizon logo
Took battery out and didn't... Answer This...
my lg phone will ring but cant...
I can not answer or talk on my... Answer This...
phone froze when synchronizing...
my env froze when I was... Answer This...
Pictures and videos Rearranged!
i know its not a big deal but... Answer This...
What is ERI? Manual explains...
Manual explains how to set it,... Answer This...
Repair Service
Find Cellular Phone Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
