Question about Lexmark Wheelwriter 3500 Typewriter
Lexmark 3500 carrier jam
I have a problem with my lexmark 3500 series printer.......it says carrier jam....can u pls let me know wat 2 do
    Novelist:
  • 97 Answers
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print lexmark 3500 carrier jam - cartridge_carrier_lids_closed_2.jpgp://i.fixya.net/uploads/images/cartridge_carrier_lids_closed_2.jpg" alt="cartridge_carrier_lids_closed_2.jpg" class="h_mi" />
  11. Close the scanner unit.
  12. Plug thelexmark 3500 carrier jam - button_power_0.jpghe wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges
______________________________________________
Hope this helps and good luck!
-WB
Posted on Jun 15, 2008
  • 462 Answers
Wildbill has the answer
Posted on Jun 19, 2008
WINDOWS VISTA LEXMARK 3500-4500 SERIES DOWNLOADS
The lexmark 3500-4500 series is a ip so one the device is conncted (ypu should assign it a fixed ip address from yourrouter) you should be able to find it in network printers
Feb 04, 2013 | Lexmark International Lexmark 3500-4500...
Carrier Jam message in window
http://images.lexmark.com/publications/pdfs/2007/3500/mhs/en/d0e10275.html
Jul 21, 2012 | Lexmark X4650 InkJet Printer
My printer keeping sayin clear carrier jam what does that mean
hi
i need to know to the model of your printer
here is a link with that same message, just to give you an idea
Lexmark, http://images.lexmark.com/publications/pdfs/2007/3500/mhs/en/d0e10275.html
Nov 12, 2010 | Office Equipment & Supplies
My lexmark x5630 x56xx series displays carrier jam the carrier bangs to the left, i saw a thin strip of plastic in the printer looks like its broken off from something please help
just try to fix it .but i think it is broken so you need to replace the broken part i advise you to show it service center.
Have a nice day and do not forget to rate please...!
Feb 03, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
Lexmark 3500-4500 Series error message paper jam
I suggest you list your problem under lexmark printers.
DickyO
Sep 08, 2009 | Lexmark Wheelwriter 3500 Typewriter
Anyone knows where to buy a cartridge carrier?
Here is a link to the user guide for your printer:
Lexmark 3500/4500 Guide
The installation of ink cartridges begins on page 70.
Thanks for using Fixya.
A Fixya rating would be appreciated.
Feb 04, 2009 | Lexmark X5470 All-In-One InkJet Printer
How do I clear carrier jam on lexmark p6250
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Oct 25, 2008 | Lexmark P6250 All-In-One InkJet Photo...
Lost my disk to my lexmark 3500 series wireless printer?
You can always find the Drivers to any kind of printer or hardware if you just google it. just go Lexmark 3500 series and look for the words Driver or Drivers Download and this is the most important part so listen up, make sure you download the right drivers the ones that coincide with your printer. Its that easy and let me know how it goes alright have fun
Oct 02, 2008 | Lexmark Office Equipment & Supplies
Error 1203 and carrier jam error
Error 1203 on a Lexmark is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad... I would suggest you to try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
If that doesn't work just call up their support number and check for replacement..
May 24, 2008 | Lexmark P915 InkJet Photo Printer
Lexmark Wheelwriter 3500 Typewriter Logo
174 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
