Washing Machines Logo
Anonymous Posted on Nov 05, 2010
My Maytag stackable MLE2000AYW washer stops during the wash cyle. If you push the start button again it will continue but then it stops again. Sometimes you have to push the start button 3 or 4 time to finish washing a load of clothes. I think I need to replace the Dial Timer but want to be sure. Thanks Darrel
  • 1 more comment
  • Anonymous Nov 16, 2010
    I noticed that it always stops in the same place, at the begining of the rinse cycle and the the begining of the spin cycle.
  • Anonymous Dec 30, 2010
    i replaced the timer and it is still stopping.?
    I replaced the timer and it still stops????
Anonymous
Level 3:
  • Washing Mach... Master 43,501 Answers
  • Posted on Nov 18, 2010
Anonymous
Level 3:
Answers
43501
Questions
0
Helped
10835266
Points
101584
The timer motor is too weak to push it past those spots that are the hardest places for it to turn...
That is why it always stops at the beginning of the next phase of the wash cycle...
Replace the timer and you will be working fine again..
heatman101
Level 3:
  • Washing Mach... Master 17,130 Answers
  • Posted on Nov 05, 2010
Level 3:
Answers
17130
Questions
0
Helped
3631777
Points
52372
Youmay be right as the timerr can cut off due to poor contacts or faulty timer action. The best you can use a good switch cleaner to wash off dirt( with the main power OFF) , use a brush to clean , a good air jet to blown out dirt and wash the contacts with the cleaner as youa re switching ON/OFF the switches.
Once the contacts seems clean allow time to dry off and recconnect washer to mains. If there is a marked change repeat the work if not the prime suspect can be the timer unit.( make sure your door lid swiches are good, clean them also)
Maytag Neptune washer - cycle starts but then doesnt advance cycle stops
possible control timer bad or motor overheating and shutting down
12helpful
3answers
Washer not spinning in spin cycle
My maytag neptun mah4000ww washer stop spinning in spin cycle.
Now it stop spin even during regular cleaning cycle. What to do?
How mach it may cost?
2helpful
Mle2000ayw Stackable washer/dryer not washing, spinning
If the door lock light is on then is might be the "door lock enable spin switch" the plunger at the opposite end from the wax motor is not fully depressing the switch. In the stackable it is just behing the door lock. Remove the two middle covers (2 white phillips screws and one hex head screw on the middle of lower cover by the wires)to test place a few layers of masking tape on the end of the plunger and cycle the machine. Might also be a weak Wax motor (dark brown in color) to be safe replace both for about $12 each. Fix in 10 - 15 min.
1helpful
2answers
Maytag bravos washer stops cycle "f" code flashes
This isnt really a solution because Im having the same problem. The repair man that came said that is buildup of soap in the water line. I use my own powder soap, not h/e, and its not desolving and getting built up in the lines. Im not sure what to do to get it to stop doing this. He suggested cutting back on the amount of soap and running hot water through the lines which I have done for the last couple of days but I still have this problem.
1helpful
Maytag stackable
Hello, Welcome
At this site you will find diagrams and schematics for your solution!
http://www.pcappliancerepair.com/model-display.php
Please remember to leave a rating before you leave
Huum
Top Washing Machines Experts
john h
