Turns on, then shuts down before anything shows on monitor
The computer shuts down almost as soon as it starts up. Then it will not start up again until I unplug it and start over. Each time, it will just shut down again. I took the side panel off and watched the LEDs on the Mother board. A green light stays on near the CPU. When I turn it on, a red light flashes for an instant at the bottom of the board, near the board slots. I tried a different power supply with no change. I tried unplugging all the power cables to the drives with no change. I unplugged and reseated the memory chip and the CPU with no change. I don't have another CPU or memory chip of the correct type to try in it. Any suggestions? The computer shuts down almost as soon as it starts up. Then it will not start up again until I unplug it and start over. Each time, it will just shut down again. I took the side panel off and watched the LEDs on the Mother board. A green light stays on near the CPU. When I turn it on, a red light flashes for an instant at the bottom of the board, near the board slots. I tried a different power supply with no change. I tried unplugging all the power cables to the drives with no change. I unplugged and reseated the memory chip and the CPU with no change. I don't have another CPU or memory chip of the correct type to try in it. Any suggestions?
    Scholar:
  • 107 Answers
Hi ,
u check almost all ....
also check with u r power buton of front panel of pc if this button is get short then it is possible .....please disconnect switch from board & just short with any metal ....if u r pc is not geting shut down please replace rower switch ...
if this information is useful for u please Rate me........
Posted on Jun 14, 2008
  • Techpoint
    Techpoint Jun 22, 2008
    friend u r not Rate me for this solution for long time .if u resolve problem please Rate me......
E machine model T3626 turns on display doesnt work and doesnt power off???
Sounds like either the Monitor is bad or the Video Card is bad. Try plugging another monitor on the computer and if it can't show a display then more than likely the Video Card is bad. If it shows on the monitor you just plugged in, then the original monitor is bad.
May 01, 2012 | Computers & Internet
Why my LCD monitor produces white glowing screen as it turns on
It is likely the computers video board that is failing, my best advice is to have it hooked up to another computer to decide which is the problem the monitor or the computers video card.
Jan 23, 2012 | Computers & Internet
Computer required restarting due to problems with mouse. Once computer was restarted gateway monitor would not work
Not enough information. Please describe any monitor activity when
you turn it on, do this while the computer is still off, unplug monitor, then
plug back in. It should start automatically, then show the gateway logo, then
go blank for several seconds, then show no input signal box, then shut down on its
own. If it fails to do this it is probably that the power printed circuit board
is failing, not delivering the proper power to the main board and/or the back
lamps. One can have this board repaired inexpensively by a qualified electronic
technician.
Email me at Sprint6@zoominternet.net
and we may be able to get your unit working properly again.
Have it repaired soon to avoid additional component failures
Dec 17, 2010 | Gateway FPD1975W 19" LCD Monitor
I hooked my monitor to my computer but it shows a monitor with a ? on it. its because the resolution is to high but i cant change it now.
shut down the computer and start it again. just press and hold the start buuton for few second and the pc will turn off. then start it again
Sep 12, 2010 | Computers & Internet
I have an Acer AL2017 Moniter. Upon turning on the tower the moniter turns on briefly makes this watery sound shuts down and continues this for sometime eventually until no picture shows at all.If I play...
Had the same problem took it apart and found 5 capacitors on the power/inverter board swelled i replaced those with new ones then it worked perfect.. there were 2 1000uf 25v and 3 330uf 25v swelled.
Nov 26, 2009 | Acer AL2017 20" LCD Monitor
Acer Aspire 5520
Sounds like a fried battery. Try a brand new one.
Jul 14, 2009 | Acer Aspire 5520-5579 Notebook
Takes to long for the monitor to start
This is a power supply problem in the monitor. There is an unstable component or components that are failing or you have some cold solder joints in the connections.The reason it turns on is that some components are self healing and will sometimes stabilize after warm-up periods.Cold solder joints sometime close after heating up in the circuit You should return to dealer for repair or replacement. Hope this helps you.
Feb 04, 2009 | Envision EN-7100e 17" Flat Panel LCD...
LCD Shuts down
The monitor screen may be OK, but the monitor electronics are not. YOu state that the comuter works fine with a different monitor. That leaves out the video card. If you reall ywant confirmation of a bad  monitor, Try it on another computer ansdI am willing to bet that it  will again shut off.  Take it to a shop for repair or replace it.
Feb 01, 2009 | X2Gen MG19MY 19" LCD Monitor
Is there more than one fan inside the computer? Did you double-check the connection from the fan to the motherboard? Sometimes a computer will shut down if it doesn't sense that the fan is turning on, to prevent the computer from overheating.
Jul 25, 2008 | Compaq Presario S5100NX (E120866) PC...
Computers & Internet Logo
288 people viewed this question
David Payne
David Payne
