Question about Nikon Cameras
Our coolpix camera is always saying memory card is write protected format the card so we bought a new sd card and it worked for about 5 sec. then said the same thing please help
    Brigadier General:
  • 11,967 Answers
Is the slide switch on the side of the card in the correct position? It should be "unlocked".
Posted on Nov 05, 2010
Camera says card is not formatted and asks if I want to format but neither yes or no works
The little write-protect-switch on your sd card is perhaps the problem - that it was shifted by vibration and stands protect instead of free. or that it already was not good set or by slide or re-connect it was moved , if not may be replace the sd memory card.
Feb 12, 2016 | Nikon COOLPIX L810
Nikon coolpix copy button will not work
Make sure the SD card is not set to protect with the small slide switch on the side of the card, then try formatting the SD card NOT the internal memory.
Jan 27, 2013 | Nikon Coolpix 4100 Digital Camera
My nikon coolpix digital camera s51c say memory card is write protected... and will not let me go to format card... what do i do... pls help
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 09, 2012 | Nikon Coolpix S51c Digital Camera
How do I change coolpix s52 to change from internal memory to sd card?
Try formatting the SD memory card using the camera's Menu setting.
May 04, 2012 | Nikon COOLPIX S52 Digital Camera
Have just purchased a Nikon Coolpix S3000/ Bought a SanDisk 2gb memory card whch will not work just says 'write protected'. Have looked for a switch on side to unlock but there doesnt appear to be one. ...
Hello
The problem is likely to be in SD card
This problem mostly comes with SD cards which have lock switch, your card have no switch at all so using a card reader, format it and put back in camera, hope it works if not it should be in warranty, avail your warranty option and replace it immediately.
Good Luck
hope it helps, if so do rate the solution
Dec 21, 2010 | Nikon Coolpix 4500 Digital Camera
My camera is saying that my card cannot be used ( sd card) I erased the pictures on it and still it comes up with that. last time I used my camera it worked fine. What do i do?
Try formatting the card in the camera using the camera's format feature located in its menus. If offered "low level" format, select it. Note that this will also totally erase the card, so do this only after you're certain that all needed photos have been backed up to your computer.
Dec 02, 2010 | Nikon Coolpix S51c Digital Camera
Memory card wont format. I bought a new 4G sandisk memory card but all it says after formatting is the card is full.
The S200 uses SD cards. Your new 4GB card is actually an SDHC card and will not work in the S200. You need to use SD cards, 2GB and smaller.
Jun 02, 2010 | Nikon COOLPIX S200 Digital Camera
Nikon coolpix s51 digtal camera memory card says can not be used?
hi..
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it.
You need to unlock the card itself. Take it out and look for a tab on the left. It should be pushed up.
thank u
rate me
Jul 22, 2009 | Nikon Coolpix S51c Digital Camera
CoolPix 5000 "OUT OF MEMORY" message that we can't figure out
At 4GB size, your memory card is likely a SDHC card, and not a standard SD card. Although they look the same, there is a difference in formatting. Unfortunately your model camera was designed before the SDHC format came out, and it will not work with your camera. But fortunately standard SD cards are very inexpensive these days, and you should be able to purchase a good 2GB standard card for around $6 with shipping:
http://www.amazon.com/s/ref=nb_ss_e?url=search-alias%3Delectronics&field-keywords=sd+card+2gb&x=23&y=20
Jul 03, 2009 | Nikon Coolpix 5600 Digital Camera
Nikon Coolpix L11 Memory Card Error
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 05, 2008 | Nikon Coolpix L11 Digital Camera
Cameras Logo
126 people viewed this question
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
