Question about Whirlpool Washing Machines
Banging noise from washer on spin - Whirlpool Washing Machines
    Genius:
  • 1,036 Answers
This is due to a defective damper (Yes they have shocks just like cars do)
They are replacable items available from online spares suppliers. Here's a link for you - But may be another closer to you.
http://www.domesticspares.co.uk/index2.asp?loaderpage=&userid=2008614945170
To access it, disconnect from supply, remove top by undoing screws at rear, then remove back.
The dampers are located right at the bottom at left and right.
May be easier to tip M/C forward to give easier access.
Check all springs are secure, and that foam rubbing strips are still in place (other causes of banging).
Hope this helps you.
Posted on Jun 14, 2008
Load noise and will not spin out clothes
Good Morning PJ, this is AP with Electrolux.
Thank you for submitting your question concerning your Frigidaire front load washer, ATF6000ES. Typically if your washer is making a banging noise it could mean one or two problems, but primarily the tub is off balance or your washer is not level. In this regard, since the tub is spinning it would be advisable to reach out to a local service provider to properly diagnose your washer. You can often locate a qualified tech through the manufacturer website.
Mar 04, 2014 | Frigidaire ATF6000ES Front Load Washer
Bangs when spin cycle is going
sounds like the washer is not level, underneath the washer are 4 legs that are adjustable, you just turn them up or down. one of them may be to high.
Jan 15, 2012 | Kenmore Washing Machines
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
Load banging noise during spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Oct 20, 2010 | Frigidaire GLTF2940ES Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
Banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
Feb 10, 2010 | Washing Machines
First: Loud Banging Noise. Now: No spin cycle.
Sounds like it may have been overloaded, or unblanced, I would say it would be better to replace....it can get pricey if the first fix doesn't work. Washers don't cost what they use to, get a scratch and dent sale item and save money too!
Aug 09, 2009 | Washing Machines
Washer sounds like off balance during spin
old duets have nut on rear pulley that becomes loose. remove rear panel and tighten nut. check while spinning by hand if pop is felt. if it rotates smoothly then you may need new shocks on tub
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WASHER MAKES A BANGING NOISE WHEN SPINNING
Try redistributing the wet clothes for better 'balance'.
Jan 08, 2009 | Whirlpool LHW0050PQ Front Load Washer
The spin bang all over the machine
is it actually spinning or jsut making banging noise. if just noise
sounds like a broken motor coupling( this machines equivelent to a belt. part number 285753a . mounts directly to the motor shaft and connects to the transmission, order a new one it installs between the motor and transmission,assy
Jan 16, 2008 | KitchenAid KAWS850LE Top Load Washer
Washing Machines Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
