Question about Janome MyLock 634D Mechanical Sewing Machine
Janome My style 16 - stretch stitches
Okay, bought the machine second hand, had it serviced and it works beautifully only how do I turn the dial around to "stretch stitch"? I feel like I'll break it if I force it around there to about 7 o'clock so was wondering if you perhaps push/pull the dial to turn it?
I thank, in advance anyone who might help.
  • trickyriki Jun 15, 2008
    Thankyou Georgi for your spot-on solution!!!, I've given it that bit extra push and it does turn around to the green triangle. I just wasn't brave enough to force it until I heard for sure.
    Must have coffee before resuming sewing...going cross-eyed now.
    Happy sewing to you too. ;)
  • Anonymous May 25, 2009
    top thread wont pick up bobbin thread when sewing - if i tighten tension top thread snaps.
I just bought the same machine off ebay, and wanted to get a jump on ordering a 1/4" quilting foot. Could you tell me if I need one with a high shank, or if the ones online that "snap on" will work?
Thanks for your time!
Posted on Feb 21, 2010
Hi , i have one the same and yes you do have to force itjust that bit further on the [length] dial till u see a green triangle, it is just past the 'o' then select the green stitches you want, i hope this helps happy sewing from georgi
Posted on Jun 15, 2008
Usha flair model
If you check on your machine, there will be a switch or dial (depending on model) that also has a blue color. That is probably for stretch stitching. You will have to change the switch or dial to the stretch stitch setting and then you will get those stitches. No need to change the needle plate. You will only need to change to a ball point needle if you are stitching on knit. Otherwise a regular needle will be fine.
May 03, 2014 | Janome Sewing Machines
Free hand stitching
Drop your feed dogs, remove your normal foot... replace with embroidery or darning foot... or leave without a foot. stretch fabric in a hoop..... set your stitch.. and sew as you move the hoop.
Jul 25, 2012 | Janome Memorycraft 6500P Computerized...
Janome machine probs
try a ballpoint or a stretch stitch needle, that what I use when sewing
knit, t-shirt. it doesn't break the fiber in the fabric.
Jun 05, 2012 | Sewing Machines
We have a Janome sew precise machine that we bought new about two
I had the same "problem" with my new machine. I called Janome's customer service and they told me the stitch length dial needs to be on S.S. I did that and it worked!
Jan 06, 2009 | Janome Sew Precise Mechanical Sewing...
Machine will not sew forward without backstitching
You have selected the Stretch Stich (SS) mode on the stitch length regulator, just turn the knob around until you have a number 1 - 5 and that should be it.
The model number will be the last digits on the metal compliance plate with voltage etc.....looks like:
V / 1234 / 123454321 / 2016
This then would be a Model 2016
Nov 25, 2008 | Sewing Machines
Skipping stithes
Try practicing on a test piece before moving on to the quilt. Batik fabric is beautiful! I would check the thread size and needle. I tried quilting with invisible thread and had the same problem. The minute I changed to 50 wt.thread and a new needle the problem disappeared. I've found that 40 or 50 wt. thread works best on my Janome.
Oct 19, 2008 | Janome 1600P-DB Mechanical Sewing Machine
Janome Harmony 2049
Darning would normally be done with the triple stretch stich, the one that is a zig-zag broken up into three stitches right and then three stitches left. See-through Zig-Zag foot. Zig-Zag set at it's widest. Feed set to about 1/16-1/8 inch (1.5-3mm) and darn by sewing forward a bit, adjust fabric, and then backward by pressing and holding the reverse button. Continue back and forth until you've created a darned box. For extra strength, turn fabric 90 degrees and repeat over same area.
Jan 29, 2008 | Janome 2049LX Mechanical Sewing Machine
Janome MyLock 634D Mechanical Sewing Machine Logo
1,156 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
