Question about Mitsubishi WD-62525 62" Rear Projection HDTV
The status red light keeps blinking and tv will not turn on
  • Mitsubishi Master
  • 8,617 Answers
Thats caused by either the lamp door or side exhaust vent door not being secured properly.Or the switches are not making contact when the doors are fastened.
Posted on Nov 05, 2010
Mitsubishi WD-73638
lamp is gone needs replacement
Jul 08, 2013 | Televison & Video
What does it mean when the status light is blinking red on my mitsubishi wd-62526
When the status light is blinking push the device and menu buttons on the tv at the same time and hold for 5 seconds or more. The red light will then blink a code. It will blink like 3 times, pause, then blink like 5 times. That would be a code of 35. It may blink one time long, then two short blinks. That is not a code blink but indicates another problem. Do a search for the service manual for your tv on the internet and look up the code. Sometimes it is as simple as a dirty fan that won't turn any more. But by knowing the codes you will know if you need a technician or if it is something simple.
Oct 07, 2011 | Mitsubishi WD-62526 Projection TV
I have a wd52525 the status light keeps blinking
There are 3 different LEDs on the front of this televison. The TIMER will blink green. The STATUS will blink orange and the LAMP will flash red or orange depending on if there is a failure or if the lamp timer is showing over 5000 hours.
If I answer your question directly and the status is blinking a steady orange light, then you have left the side filter cover or the front lamp cover off or they are loose.
Also holding the menu and device buttons together until the timer light blinks will reveal a code that will help in diagnosing your problem. Goodluck.
Jul 04, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Status indicator flashes 3 short times, then one long red flash
Once the status light blinks 3 times, this is an indication that there's a problem with the lamp. The lamp may need a replacement.
If you replace the lamp, but get the same problem, check the inverter board.
If you're not sure where the inverter board is, then you may need to contact a pro for your safety.
Good luck and have a good evening!
Feb 14, 2010 | Mitsubishi WD-52327 52" Rear Projection...
Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Jul 13, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Status light on, tv will not respond
if the "status" light is blinking red than you most likely have a fan failure going on inside the set. there are 5 fans in the tv and it could be any one of them.
Apr 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
61 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
