Question about Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard
RAM UPGRADING but when i inserted the 512MB PC3200, my system is not booting..sometimes it makes three long beeps..
Cheks the connectics of the harddrive and try again
Posted on Jun 14, 2008
Replacing ram (1 x 512mb and 1 x 256) with 2 x 1gb. PC boots ok (slowly) then seems to freeze (nothing shown on taskbar) - desktop icons take ages to appear then seem to randomly refresh. The new ram is...
Try re-installing the two new sticks two or three times. Sometimes there is a little build up of oxides on the contacts on the motherboard and keeps the bios from properly recognizing them.
Sep 18, 2013 | Fujitsu Siemens SCENIC P300 PC Desktop
1.Suggest me the type of ram which is supported Foxconn 8657MF-series. 2.When i installs DDR400 RAM of 256MB it gives continuous beep(bee-bee-bee) sound. 3.What are the beep codes of Foxconn...
the beep sound on system starting before booting starts refers no RAM in system, if you need to upgrade your RAM then go for DDR-SDRAM PC3200 200MHz 512MB 0r 1GB.
Jan 24, 2011 | Foxconn (865G7MC-ES) Motherboard
Hi, I have a little problem with the RAM of my Acer Aspire 8600. Probably I am using a wrong RAM module for the upgrade, but I would like to have your opinion. I have instantiated a new module of RAM...
Probably you have used the wrong RAM module in the upgrading. You must be using 1 GB PC2100 RAM instead of PC3200 in order to have a complete 1 GB of RAM.
Nov 09, 2010 | Acer Aspire 8600 PC Desktop
Istall the ram but do not desplay ram is out of socket and than buzzer 3 bip I was install Ram to other mother board Ram is ok please solve the problem
It is the wrong speed ram for the other motherboard for instance 133 sdram, 100 sd ram, pc2700 ddr ram, pc3200 ddr ram etc. you will have to see what type of ram is acceptable in your new board.
Feb 15, 2010 | Intel D845GLLY Motherboard
Liteon na115 mainboard can't display/load bios
1) Try re-seating the RAM
if it's still the same problem, then the power supply maybe bad.
Try with a good PS.
Jun 17, 2008 | Lite On NA115 Motherboard
PC3200
Ya that indicates bad ram, Did you try just the 512 MB stick without having the other one in. If that doesn't work then your motherboard may not be compatible with that stick of RAM.
Good luck,
Lee
Jun 14, 2008 | Intel Desktop Board D845GLVA...
Upgrading ram
Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 27, 2008 | Asrock 775VM800 Motherboard
I have baught a photo program from BB and your Geak Squad said I needed more memory and I gave him my info & he said PC3200,is that Centon 512MB PC3200?
Hello tonya,
PC3200 memory and Centon 512MB PC3200 if they both DDR400 its thesame.
that is absolutely the same.
melnavz
Apr 10, 2008 | Dell Dimension 3000 PC Desktop
Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard Logo
27 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
