Question about Lexmark X83 All-In-One InkJet Printer
Printing No "Print" option in the menu function; paper does not load
    Novelist:
  • 148 Answers
You will need to go to control panel then to printers then remove the printer from the system. Also from the start menu go to the search menu and in the files and folders box type in your printer ,scan for all related applications and files, When they are all on the screen click once on the first item then hold the "ctrl" key down and press the "" key this will highlight all of the files still remaining once they are highlighted right click on the first one again and delete the remaining files. if they do not delete or a warning comes up stating that the file can not be removed go to each one of the files, right click on them individually and delete them or as many as you can. then reinstall your software according to the manufacturers directions. Be macho blessed... Mark
Posted on Jun 27, 2008
Printer is out of cyna color but only want to print black how to we override
You have to follow this steps:
1. Load paper in the tray.
2. On the File menu in your software application, click Print.
3. Make sure the printer you want to use is selected.
4. To change settings, click the button that opens the Properties dialog box. Depending on your software application, this button might be called Properties, Options, Printer Setup, Printer, or Preferences.
5. Change the paper orientation on the Layout tab, and paper source, media type, paper size, and quality settings on the Paper/Quality tab. To print in black and white, click the Advanced button, and then change the Print in Grayscale option.
6. Click OK.
7. Click Print or OK to begin printing
Mar 16, 2015 | HP Officejet Pro 8600
Manual feed tray bypass
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Jul 25, 2012 | HP LaserJet 4250n Printer
Hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
My printer prints blurrey out of focus pictures. I download from my camera and print a few on photogaph paper. This happened once before and for reasons that evade me it cleared up and printed fine. ...
Before replacing this awesome printer try this steps first.
First check the paper you're using, load the paper with the printing side down.
In the program being used for printing, click File , and then click Print .
Make sure the appropriate printer is selected, and then click Preferences or Properties.
Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
Paper size : Make sure that this option matches the paper loaded in the product.
Make sure that the image file has enough resolution for the size of the printed picture. Although many photo applications can enlarge an image or part of an image to any size, eventually the individual pixels become visible and the whole image looks blurry.
Apr 23, 2011 | HP PhotoSmart C4280 Laser Printer
My Lexmark 4600 printer has a paper jam. do not know how to unjam it.
How to clear and avoid paper jams
Follow these instructions to remove and/or avoid paper jams and misfeeds in your Lexmark X3500, X4500, X4600 & X4800 Series All-In-One.
Paper jam in the printer
Remove the paper manually
  1. Press pattlnk_10282008_1820-power-icon.gif to turn off the printer.
  2. Firmly grasp the paper, and gently pull it out.
  3. Press pattlnk_10282008_1820-power-icon.gif to turn the printer back on.
NOTE: Check inside the printer to ensure that all the paper is removed. Any small pieces of paper left in the printer will continue to cause paper jams.
Paper jam in the paper support
Paper or specialty media misfeeds
These are possible solutions if paper or specialty media misfeeds or skews, or if multiple sheets feed or stick together.
Try one or more of the following:
Check paper condition
  • Use only new, unwrinkled paper.
Check paper loading
  • Load a smaller amount of paper into the printer.
  • Load paper with the print side facing you. (If you are not sure which side is the printable side, see the instructions that came with the paper.)
Remove each page as it is printed
  • Remove each page as it exits, and let it dry completely before stacking.
Adjust the paper guides
  • When using media less than 8.5 inches wide
  • To rest against the edges of the paper or media, making sure it does not buckle
Printer does not feed paper, envelopes, or specialty media
These are possible solutions. Try one or more of the following:
Check for paper jams
  • Check for and clear any paper jams. For more information, see "Paper jam in the printer" and "Paper jam in the paper support" above.
Check media loading
  • Verify that the specialty media is loaded correctly.
  • Try loading one page, envelope, or sheet of specialty media at a time.
Check printer default and pause settings
  1. Click:
    • In Windows XP (default Start menu): Start pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows XP (Classic Start menu): Start pattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers and Faxes.
    • In Windows Vista (default Start Menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gifControl Panel pattlnk_10282008_1829-right-arrow.gif Printers (under Hardware and Sound).
    • In Windows Vista (Classic Start menu): pattlnk_10282008_1829-vista-start-button.gifpattlnk_10282008_1829-right-arrow.gif Settings pattlnk_10282008_1829-right-arrow.gif Printers.
  2. Double-click the print queue device.
  3. Click Printer.
    • Make sure no check mark appears next to Pause Printing.
    • If a check mark does not appear next to Set As Default Printer, you must select the print queue device for each file you want to print.
Banner paper jams
There are many possible solutions. Try one or more of the following:
Clear banner paper jams
  2. Remove the jammed banner paper from the printer.
Review banner printing checklist
  • Use only the number of sheets needed for the banner.
  • Select the following settings to enable the printer to feed paper continuously without jamming:
    1. With a document open, click File pattlnk_10282008_1829-right-arrow.gif Print.
    2. Click Properties, Preferences, Options, or Setup.
    3. Select the Paper Setup tab.
    4. From the Paper Size area, select Banner.
    5. Select Letter Banner or A4 Banner as the paper size.
    6. Select Portrait or Landscape.
    7. Click OK.
    8. Click OK or Print.
Regards,
Ron
Mar 26, 2011 | Lexmark 4600 Multi Function Printer Option...
I NEED TO PRINT DOUBLE-SIDED ON AN hp3150 LASERJET. hOW DO i DO THAT?
Follow these steps to change print settings, and then print in Mac OS X 10.6. Step one: Select your product
  1. In the program from which you want to print, click File , and then click Print . Figure 11: Click File, and then click Printc02458420.jpg
  2. Select your product from the Printer: drop-down list.
Step two: Change print settings
  1. Type the number of copies to print in the Copies text box.
  2. If you want to print multiple copies, select the Collated check box to print the pages of each copy in order.
  3. Select the pages of the print job that you want to print. To print all pages, select All. To print a specific range of pages only, type the page number that begins the page range in the From text box. Then, type the page number that ends the page range in the To text box.
  4. Select the size and type of paper loaded in the product from the Paper Size drop-down list.
  5. Select the orientation for your print job. To print in portrait orientation, click the icon on the left. To print in landscape orientation, click the icon on the right.
Step three: Change the paper type and quality settings
  1. After the Orientation section, click the drop-down, and then select Paper Type/Quality . NOTE: This drop-down usually defaults to the program specific drop-down. In this example, the drop-down is the TextEdit drop-down. Figure 12: Select Paper Type/Qualityc02458421.jpg
  2. Adjust the Paper Type setting to match the paper loaded in the product.
  3. Adjust the Quality setting to change the print quality of the printed page.
  4. Select Print Borderless to print photos without a white border.
  5. To change the color profile or to turn on Photo Fix, click the arrow next to Color Options to display the Color Options menu. Figure 13: Color Options menuc02458422.jpg 1 - Paper Type/Quality menu options 2 - Color Options menu (only available if you click Color Options)
Step five: Print the print job After all the settings match the needs of the print job, click Print on the Print window to print the document or print job.
Dec 26, 2010 | HP Photosmart C3150 Printer
Out of paper error
The paper settings in the print driver must match what is loaded in the product. NOTE: These changes do not change the default print settings. The print settings return to default the next time the program opens.
  1. Open the document that you were trying to print when the issue occurred.
  2. Click File , and then click Print . The Print dialog box opens.
  3. Click the button that opens the Properties dialog box. Depending on the software program, the button might be Properties , Options , Printer Setup , Printer , or Preferences .
  4. Click the tab that provides paper type and size settings. The tab might be Features or Paper/Quality .
  5. From the Size is drop-down menu, select the paper size that matches the paper in the tray.
  6. From the Type is drop-down menu, select the paper type that matches the paper in the tray.
  7. Click OK , and then click OK again to print the document.
Nov 23, 2010 | HP Photosmart 8250 InkJet Printer
The printer says Load MP feeder B5. how can I fix this.
Several options here:
1st - cancel any documents in the print queue. and print off a report of some kind via the menu button on the machine. if that prints correctly then it either a software/ print driver setting issue.
2nd - If that prints out correctly open up a text pad/ notepad and attempt to print that if the message pops up it's very possible the paper handling has been miss-configured within the print driver.
Now if the document does print out fine, the original document you were attempting to print is set to a B5 paper size. If that's the case pending on what program you are using you will have to change the paper size to you choice of paper your using.
3rd - open up the paper tray and confirm it's set to letter or legal pending what type of paper you have in the tray(not the manual feed tray). I highly doubt it's the tray however as B5 setting would not allow any type of normal paper to be loaded.
4th - on the machine hit the menu button -> paper menu -> confirm that the paper type/ size and source are configured correctly.
Link to the user manuals for this machine : click here
Oct 19, 2010 | Lexmark T632 Laser Printer
Print job will not print from the manually feed tray unless I select the Go button for it to process
Table 3-7. Paper Handling Menu
Item Values Explanation
ENVELOPE FEEDER
SIZE=COM10
For supported paper sizes
see page 1-12.
This item appears only when the
optional envelope feeder is installed.
Set the value to correspond with the
envelope size currently loaded in the
envelope feeder.
ENVELOPE FEEDER
TYPE=PLAIN
For supported paper types
see page 1-12.
envelope type currently loaded in the
envelope feeder.
TRAY 1 MODE=
FIRST
FIRST
CASSETTE
Determine how the printer will use
Tray 1.
FIRST: If paper is loaded in Tray 1,
the printer will pull paper from that
tray first.
CASSETTE: A paper size must be
assigned to Tray 1 using the
TRAY 1 SIZE option (the next item
in this menu when TRAY 1
MODE=CASSETTE). This allows Tray 1
to be used as a reserved tray.
TRAY 1 SIZE=
LETTER
see page 1-12.
This item appears only when TRAY 1
MODE= CASSETTE. Set the value to
correspond with the paper size
currently
Mar 12, 2008 | HP LaserJet 4350 Printer
Only wants to print out of tray 1
paper size or paper type is incorrectly set on trays (check settings via printers keyboard menu) or and settings in print driver are incorrect (control panel/printers and faxs right click hp icon properties
Nov 30, 2007 | HP LaserJet 4350 Printer
Lexmark X83 All-In-One InkJet Printer Logo
23 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
