Question about Asrock Motherboard K7S41GX for AMD Sempron/Athlon/Duron (B01029)
Asrock motherboard k7s41gx still beeping
I have tried all that you said and is still beep 3x
  • 4,472 Answers
How dirty are the ram slots you might try blowing them out with computer air? The only next step is to assume the motherboard is bad and replace that.
Good luck,
Lee
Posted on Jun 14, 2008
Loud beeping sound on start up , now will not start up , power ok
First remove the Ram and boot the system without it. If you hear continuous two beeps, then the problem is with the Ram, you need to replace it. If nothing happens, then your cpu or your motherboard is gone. Good luck. Thanks for using FixYa.
Jun 03, 2010 | Asrock K7S41GX Motherboard
3 beeps when i boot my pc with ram but no beeps when i boot without ram
Here is the info I found on the Asrock website. This would be a normal code if you have no RAM in the system.
Beep Code Descriptions 1 short Memory refresh timer error. 2 short Parity error. 3 short Main memory read / write test error. 4 short System timer failure. 5 short Process error. 6 short Keyboard controller BAT test error. 7 short General exception error. 8 short Display memory error. 9 short ROM BIOS checksum error. 10 short CMOS shutdown Read/Write error. 11 short Cache Memory bad.
Apr 14, 2010 | Asrock K7S41GX Motherboard
Not getting no post beep
beep may be disabled in bios setting or ur internal speaker has gone bad
Jan 09, 2010 | Asrock K7S41GX Motherboard
I just installed a used Asrock K7S41GX board which is working just fine exept I have no sound through my external speakers. The internal speaker on the the board beeps on startup but nothing after that. Do...
If you hear just one short beep on the onboard speaker it means that everything is fine. You should download the drivers for the onboard sound from Asrock website.
May 18, 2009 | Asrock K7S41GX Motherboard
Asrock K7S41/K7S41GX problem
2 x DDR DIMM slots
- Supports DDR400/333 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
3 beeps is usually either video card related, or memory. be sure your memory is UN buffered, and DDR400 or 333 DIMM not DRam.
Remove and re-seat your video card as well.
there should be a troubleshooting guide in your install manual stating the designation of 3 beeps.
Dec 22, 2008 | Asrock P4VM890 Motherboard
ASRock K7S41 / K7S41GX, sound 3 Beeps 3 times, then power off automatically
I had 3 beeps, pause, 3beeps, pause and so on.
Defective SMD transistor near the ATX power connector. Original is a 2SB1202 (marking B1202).
I bought a 2SB1203 which is stronger and soldered it in. The K7S41GX board runs as fresh as from the dealer.
Aug 27, 2008 | HP Compaq dc5100 PC Desktop
Beeping
How many sticks of RAM are in the PC? If more then 1 try each stick 1 at a time see if any of them will work by themselves. Also if you have any other memory that is known to be good to test in this PC that would also disprove some theories.
Good luck and if it still not solved let me know and we can see if there are any other solutions besides trying a new stick of memory.
Lee
Jun 14, 2008 | Asrock Motherboard K7S41GX for AMD...
Beep Beep Beep
How many beeps? There should be a sequence of beeps. Are they all the same, or are some short beeps and some long? Please clarify so I may help you further.
May 22, 2008 | Asrock K7S41GX Motherboard
Bios beep
Looks like a problem with the RAM modules. Try reseating /swapping them, or change them altogether.
Hope that helps, and oh yes, dont forget the fixya rating!
May 08, 2008 | Asrock K7S41GX Motherboard
Asrock k7s41gx
it seems to me its a dust problem. any beeps?
Sep 13, 2007 | Asrock Motherboard K7S41GX for AMD...
Asrock Motherboard K7S41GX for AMD Sempron/Athlon/Duron (B01029) Logo
112 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
