Question about Microsoft Windows Server Standard 2003 for PC
Server Installation Hi I am install windows 2003 server but how to enable DNS please send any link tell me regards, Ravikumar.P
    Sergeant:
  • 213 Answers
follow these steps
Posted on Jun 14, 2008
Windows 2003 R2 server installation guide
I am providing you with the best installation guide which will make your work a bit easy so please go to the below link and have a look through it.
http://www.windowsreference.com/windows-server-2003/step-by-step-windows-server-2003-installation-guide/
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 15, 2010 | IBM Computers & Internet
Tip
Server 2003 & client configuration
<p><span>Some days before I have done a job on Windows Server 2003 Enterprise edition & Client XP. It is departmental food court. In the office room of the restaurant have a system which will be Server system and main domain. There was another 8 system in every department of food <span> </span>with printer for billing.I</SPAN><br> <p><span>Windows Server 2003 includes a mission critical Windows Server operating system, such as security, reliability, availability, and scalability.</SPAN><br> <p><span>You have to install DNS server for DC without DNS the client computers wouldn't know which one is DC.You can host DNS on a different server than DC.</SPAN><br> <p><span>Before Starting the DC installation process you need to make sure the <span> </SPAN>following points</SPAN><br> <p><span> </SPAN><br> <p><span>1)You have installed Basic windows server 2003 installation</SPAN><br> <p><span>2)Make sure you have assigned a static ip address to your server</SPAN><br> <p><span><span> </SPAN>Now start DC and DNS Setup process</SPAN><span></SPAN><br> <a><span> </SPAN></A> <span><span>Domain Controller</SPAN></SPAN><span></SPAN> <span>Active Directory is a huge topic in itself. While DCPROMO is easy to run, planning of both the physical and the logical structure is the key to a trouble free active directory. </SPAN> <p><span>Domain controllers do not have to be your most powerful machines, however they must be reliable and always available to answer logon requests. </SPAN><br> <a><span>DNS (Domain Name System)</SPAN></A><span><span> </SPAN></SPAN><span>Role</SPAN> <p><span>Once DNS is setup, it runs itself thanks to the new dynamic component hence DDNS. TCP/IP knowledge plus understanding of how DNS works is essential when troubleshooting connectivity problems.</SPAN><br> <p><span>DNS enables client machines to resolve servers IP addresses. Once the client finds the server, Active Directory uses LDAP to locate services like Kerberos, Global Catalog that clients request.</SPAN><br> <a><span>Print Server Role</SPAN></A><span></SPAN> <p><span>In my experience there is a contrast between the software settings which are easy to configure and the hardware which constantly need for attention e.g. paper jam, 'out of toner'. Check list for print server:</SPAN><br> <p><span></SPAN> <br> <p><span>Printer Priority</SPAN><br> <p><span>Network Printers</SPAN><br> <p><span></SPAN><br> <p><b><span>Client Configuration :- </SPAN></B><span>After</SPAN><span><span> Installation of Windows Xp give the IP Add on TCP/IP of IPV4.If you want to manually configure DNS server addresses, click</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Use the following DNS server addresses</SPAN></b><span><b><span>,</SPAN></B></SPAN><span><span> and then type the preferred DNS server and alternate DNS server IP addresses in the</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Preferred DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>and</SPAN></SPAN><span><span> </SPAN></SPAN><b><span>Alternate DNS server</SPAN></b><span><span> </SPAN></SPAN><span><span>boxes. After all job try to ping each other. I'm trying this and it also pinging. Files and data also can be shared through it.</SPAN></SPAN>
on Feb 15, 2011 | Computers & Internet
How to use network inventory ? what is it requirment ?
Installed Windows server 2000/2003/2008 on server PC
Set IP address as 192.168.0.1
     Subnet address : 255.255.255.0
     Gateway :  Blank (only if you use router)
      Primary DNS  : 192.168.0.1
      Secondary DNS : Blank
Set up the server as Domain Controller plus DNS server.Here is the link on how to
1) http://www.visualwin.com/AD-Controller/
2)http://www.ssw.com.au/SSW/Standards/DeveloperInstallationNetworkSetup/Windows2003_01DomainControllerSetup-InstallingActiveDirectoryandDNS.doc
Client setting
Set IP address as 192.168.0.2
Here is the link on how to join the domain
1) http://www.petri.co.il/joining_a_domain_in_windows_xp_pro.htm
2) http://www.windowsnetworking.com/articles_tutorials/wxpjoind.html
Client Operating system must be windows xp pro,2000 professional,Vista ultimate etc
Dec 24, 2009 | HP Pavilion DV5234US Notebook Laptop
DNS
If the Windows 2003 server is utilized as the DNS server, then yes it should be set to 192.168.1.5. You need to get into the Linksys router via http://192.168.1.1 and under DNS of DHCP if it is set to .1.1. You should be able to change it to .1.5.
Dec 07, 2009 | Microsoft Windows Server Standard 2003 for...
Domain creation
Hai,
You go to this site tucktail.In that site U check your desired domain name available r not.And then register the domain name.
Jan 27, 2009 | Microsoft Windows Server Standard 2003 for...
DNS
firwstu important for
dns domain name services
name to ip\
ip to name
and createto host id
and pointer.
create todomain name.
bye
Jun 04, 2008 | Microsoft Windows Server Standard 2003 for...
Server 2003 sp1 not installing
Plz be posted , in case of server installation - it is veryu delicate the above situation may occur only for the following points .
1.intallation files were skipped by user manually (due to bad CD)
2.Improper Installation (in case root directory contained XP os and installation was overridden windows folder )
3.using a crack patch to OS for CD-KEY.
check and let us know.
Regards,
Sushil
May 27, 2008 | Microsoft Windows Server Standard 2003 for...
DNS Deligation
hi,
the above attached a link document is for windows 2000 server not for 2003.
ramana
May 22, 2008 | Microsoft Windows Server Standard 2003 for...
Microsoft Windows Server Standard 2003 for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
