Question about Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard
PC3200 but when i inserted the 512MB PC3200, my system is not booting..sometimes it makes three long beeps..
  • Gupt Jun 14, 2008
    yea, its not working...So it may not be suitable with the board.. right?
    Thanks alot.
  • 4,472 Answers
Ya that indicates bad ram, Did you try just the 512 MB stick without having the other one in. If that doesn't work then your motherboard may not be compatible with that stick of RAM.
Good luck,
Posted on Jun 14, 2008
  • Lee A.
    Lee A. Jun 14, 2008
    Ya that is most definetly the case especially if you know the ram is good.
Replacing ram (1 x 512mb and 1 x 256) with 2 x 1gb. PC boots ok (slowly) then seems to freeze (nothing shown on taskbar) - desktop icons take ages to appear then seem to randomly refresh. The new ram is...
Try re-installing the two new sticks two or three times. Sometimes there is a little build up of oxides on the contacts on the motherboard and keeps the bios from properly recognizing them.
Sep 18, 2013 | Fujitsu Siemens SCENIC P300 PC Desktop
1.Suggest me the type of ram which is supported Foxconn 8657MF-series. 2.When i installs DDR400 RAM of 256MB it gives continuous beep(bee-bee-bee) sound. 3.What are the beep codes of Foxconn...
the beep sound on system starting before booting starts refers no RAM in system, if you need to upgrade your RAM then go for DDR-SDRAM PC3200 200MHz 512MB 0r 1GB.
Jan 24, 2011 | Foxconn (865G7MC-ES) Motherboard
I have a dell dimension 4600. It has original memory cards installed. 2 256 MB for a total of 512 ram. I recently tried to install 1 GB memory card. When I start up computer it beeps several times,...
several beeps in a system is caused by a memory issue -- If you've recently added or tried to add additional memory to the computer and have started getting these beeps. Remove all new memory you've added to the computer. If the computer works fine after removing the new memory you're encountering either an incompatibility or defective new memory.
Sometimes when the computer is moved and/or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If reseating the memory did not resolve the issue try swapping the location of the memory. If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
the specs can be found at this link
the system you have is upgradable to 4G of RAM, and this RAM must be installed in equal pairs
so if you have 4 slots to insert memory in (assuming you will retain the 2 256M) , you must install the other slots by 2 512M, 2 1G or 2 2G DIMMs -- make sure you isntall exact same DIMMs, dont mix memory makers or specs, other than what Dell specifies
memory type must be
PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
i hope this helps --
Dec 09, 2010 | Dell Dimension 4600 PC Desktop
Can a ddr pc2700 replace ddr 400 pc3200 are they compatible? I only get beeps when booted
Yes it can be compatible.PC3200 DDR 400 will underclock down to PC2700 in order to match the frequency of the lower end memory card. In order for your system to run it should have a matched memory frequencies. But memory compatibility depends sometimes to its brand name.
I hope this could help you..Thanks..:-)
Dec 23, 2009 | Asrock P4VM890 Motherboard
Memory upgrade issue
Most ram has to go in pairs. Buy another stick of the 1GB, and it will run fine.
Jan 23, 2009 | FIC K8-800T Motherboard
Adding More Memory
Reset the BIOS using the motherboard jumper before booting into Windows.
Jul 23, 2008 | ASUS P4S800D-X (610839122325) Motherboard
cheks the connectics of the harddrive and try again
Jun 14, 2008 | Intel Desktop Board D845GLVA...
I have baught a photo program from BB and your Geak Squad said I needed more memory and I gave him my info & he said PC3200,is that Centon 512MB PC3200?
Hello tonya,
PC3200 memory and Centon 512MB PC3200 if they both DDR400 its thesame.
that is absolutely the same.
Apr 10, 2008 | Dell Dimension 3000 PC Desktop
Intel Desktop Board D845GLVA (BOXD845GLVAL) Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
