Question about Samsung SGH-D600 Cellular Phone
Samsung d600 just went off by its own
My d600 was working fine and it just went off, i change the ribbion from the main board to the sub booard and it still won't come on. any advice on what can be the problm. you can contact me at Bobrands@iburst.co.za
  • naicker Jun 14, 2008
    Hi, thanks for the help, but, what is a strip connector, is that the ribbion from the main board to the sub board or is that the battery connector pins between the board and the battery,
    thanks alot friend, i'm gonna get the stuff 2day and fix the phone.
  • 24 Answers
Change strip connector,then it will done
Posted on Jun 14, 2008
  • imran shaikh Jun 14, 2008
    where the strip/ ribbion connect to the PCB.
My Samsung would work fine for 5 minutes before the screen went black while the audio worked fine. Now there's no picture at all but the audio continues to work.
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Nov 29, 2016 | Samsung Televison & Video
Samsung HL61A750 61 Inch 1080P Led Powered DLP HDTV will not stay on. It can be turned on, but 15 or 20 seconds go by and it goes/tunrs off. Everytime.
It sounds like the lamp bulb, I had the same problem and I took the bulb unit out of the back, cleaned it out really good and replaced it, it works fine now and I didn't have to buy a new bulb unit for about $200.00. Good luck.
Sep 06, 2009 | Samsung Televison & Video
Player works fine, speaker works fine but screen is blank...
This dvd player is having a problem with the video input /output circuits. This could be a minor problem with a loose connector or some over expanded solder joints. It could also be a problem with the video ic have a problem with its circuits. The connector problem and the possible cold solder joint problem can be repaired. The dvd player must be taken apart and the connection cleaned and repaired. If the problem is with the video solid state components, you will have to have it repaired by a service center. The video has a main ribbion connector that connects the laser lens to the main board video inputs. This ribbion cable usually will run under the laser transport mechanism. It is connected to the main board and laser transport by clamping connectors. You can look and see if this connector is loose or bent and has lost its function. Try cleaning the contacts points of the connectors and the connectors on the main board and laser transport.Also look for bad or cold solder joints in the areas of the connectors. Try to resolder these points.Use new solder to insure a good connection. Remember to only work on these dvd player with all power disconnected. Always wear anti-static wrist bands and gloves when working on the dvd player to prevent further damage. If the cleaning and repairing the of the possible cold solder joints do not repair the problem, you probably have a bad video chip and should replace the dvd player.I hope this information helps you with your problem.
Mar 21, 2009 | Mintek MDP-1815 Portable DVD Player
My Samsung E250 Phones Buttons are not working, Screen is also blank
plz try to replace the flex cable that connects the screen to the main board. It may fix the probem
Thanx and regards
sukhvinder
Jan 09, 2009 | Samsung SGH-D600 Cellular Phone
Hd52w59 - Me again....
sorry havent got back got some personal issue going on. So its cycling off. my fist instinct is to check the ribbion cables that go between boards. and most connectors. theres a cable that runs from the back green booard to the front center crt board in the front. this could be a problem. does the set make any noises?
Dec 28, 2008 | RCA HD52W59 HDTV Projection Television
Samsung 50' Plasma HP-R5072
if it is in warranty, call 1-800-samsung for service, if the tv has backlights, then it could be the power supply or main board, if it does not have backlights then its probably the inverter board or T-con booard
Dec 09, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Blank Screen
the power supply board has gone bad. part number
BN96-00249A
Oct 19, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Audio but no video
If the screen is not illuminated this can be from the screen power supply, the main screen driver board, or the screen itself has failed. The service rep will change boards to service this, and adjust as necessary.
The set will require factory level service.
Jerry G.
Aug 20, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Samsung SGH-D600 Cellular Phone Logo
32 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
