Expert
- Posted on Oct 29, 2011
Re: 2009 ktm 125sx torque settings for head and cylinder
Thank you for contacting FixYa with your inquiry. I have been going
over some of the older help requests that have been archieved and
trying to provide solutions for those that didn't get answered. Hope
this information helps.
KTM Torque settings
- Collar screw, front wheel spindle Front axle nut 40Nm 30ft lbs
- Brake Caliper front Brake Caliper front Loctite 243 2 19ft lbs
- Brake Disk, front Brake disk front Loctite 243 1 11ft lbs
- Brake Disk, rear Brake disk rear Loctite 243 1 11ft lbs
- Clamping screws, upper fork bridge Top triple clamp 20Nm 15ft lbs
- Clamping screws, lower fork bridge Bottom triple clamp 15Nm 11ft lbs
- Clamping screws, fork stubs Front axle pinch bolts 10Nm 7ft lbs
- Collar nut, rear wheel spindle Rear axle nut 80Nm 59ft lbs
- Hex nut swingarm bolt Swingarm nut 100Nm 74ft lbs
- Hex collar screw handlebar clamp Upper handlebar clamps 20Nm 15ft lbs
- Allen head screw handlebar support Lower handlebar clamps Loctite 243 4 30ft lbs
- Shock absorber top Shock absorber top bolt 60Nm 44ft lbs
- Shock absorber bottom Shock absorber bottom bolt 60Nm 44ft lbs
- Sprocket screws Rear sprocket bolts Loctite 243 3 25ft lbs
- Ball joint for push rod Rear brake pedal pivot Loctite 243 1 7ft lbs
- Engine mounting bolts Engine mounting bolts 45Nm 33ft lbs
- Engine brace Engine brace 33Nm 24ft lbs
- Screw adjusting ring spring preload Shock preload collar bolt 8Nm 6ft lbs
- Spoke nipple Spokes 5Nm 4ft lbs
- Other Screws on chassis M6 10Nm 7ft lbs
- M8 25Nm 19ft lbs
- M10 45Nm 33ft lbs
- Other collar nuts on chassis M6 15Nm 11ft lbs
- M8 30Nm 22ft lbs
- M10 50Nm 37ft lbs
- Front Sprocket 44ft lbs
TF
