Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Carrier ac unit
I have a carrier 50tff006 unit and need installation information can ya help
  • James Helmer
    James Helmer May 11, 2010
    Are you planing to attempt the installation your self or do you need the information for trouble shooting an installation?
  • 230 Answers
This appears to be a Roof Top packaged unit. You will definitely need some help with this install. Your local Carrier distributer should have the installation curb kits and economizer etc.
Here is the most technical data I can find for this unit. Under the 50TFF section you will see the accessory dimensions. I hope this helps. (You will need adobe acrobat to read the file)
Posted on Jun 18, 2008
  • Don Berry Jun 18, 2008
    OOps here is the link.
Plugs on Carrier yc273d air conditioner
You probably have a 230 volt AC that uses a different plug. If you insist on using unit there you will need an electrician to run the correct wiring and install the correct female for your unit to operate.
Jul 13, 2015 | Carrier Heating & Cooling
What tonnage is my new Carrier A/C model # 24ABC642A300 and how many sears is it?
The AC unit you inquired about is 3.5 ton unit. With a 10 seer rating.
Hope this information helps.
Mar 01, 2011 | Carrier 38CKC042 Air Conditioner
Wiring diagram needed for carrier air con unit
Here ya go:
May 27, 2010 | Carrier 38CKC036 Air Conditioner
Looking for a parts list/owners manual for an old carrier AC unit. Model #38 REO 36 300. Any idea?
Follow this link to the search page for the Unit need need literature on. If you want to change models (i.e. from the 38BR to the 38RE, both of which you list in your question), just enter the 1st 3-4 characters in the search box. this link is for the 38RE. Good luck!,3063,CLI1_CNT1_DIV12_ETI9039_MID4442_QRYY,00.html
May 27, 2010 | Carrier 38BRC036 Air Conditioner
Carrier Durakool 1.5 ton A.C. Moter out of order within 3 months only. Can replace A.C. new.
If you bought the unit new and it's only 3 months old, the motor should be under warranty and whoever installed the unit should replace the motor for free and Carrier should pay him for the warranty work.
Aug 18, 2009 | Heating & Cooling
Here's some info for your unit. I found the FE4 series of documents on the Carrier web site and you can get quite a few documents related to your unit there and download them for free.
Just select FAN COILS and enter in "FE4" below that to get the documents for your unit.
Here's a document that provides some technical info for your the FE4 series of A/C units.
Here's a carrier manual that might be of some use to you as well.
You might want to contact Carrier customer service to see if they have any other information for your unit, or if you need further assistance. You can call them at 1-800-227-7437 or 1-800-CARRIER
Hope you find this very helpful and best regards!
Aug 06, 2009 | Carrier Heating & Cooling
It wont come on
Really need more info to fix this. Start with the high voltage. if ya got power 240 V then check forlow voltage. at least 24V ac across red and blue on most units at the T-Stat. rheem and carrier are red and brown. if ya got that then theres a break in the circut somewhere. If your unit is equiped with a float shut off switch see if its not triped due to a clogged drain line. most common cause. check my site for more info.
Jul 11, 2009 | Intertherm Heating & Cooling
Lexmark 3500 carrier jam
Hi adirag! This is directly out of the user's manual! Clear Carrier Jam These are possible solutions. Try one or more of the following:
Remove any obstructions
  1. Raise the scanner unit.
  2. Remove any objects blocking the path of the print cartridge carrier.
  3. Make sure the cartridge carrier lids are closed.
  4. Close the scanner unit.
  5. Press button_select_0.jpg.
Remove print cartridges
  1. Make sure the printer is on.
  2. Raise the scanner unit.
  3. Remove both print cartridges.
  4. Make sure the cartridge carrier lids are closed.
  5. Close the scanner unit.
  6. Press button_power_0.jpg to turn the printer off.
  7. Disconnect the power cord from the wall outlet.
  8. Plug the power cord back into the wall outlet.
  9. Press button_power_0.jpg to turn the printer on.
  10. Reinstall the print cartridges. For more information, see Installing print cartridges
  11. Close the scanner unit.
  12. Plug the power cord into the wall outlet.
  13. Press button_power_0.jpg to turn the printer on.
  14. Reinstall the print cartridges. For more information, see Installing print cartridges
Hope this helps and good luck!
Jun 14, 2008 | Lexmark Wheelwriter 3500 Typewriter
Carrier Infinity DC motor drive problems
Contact the company that installed the unit. Its new, under warranty, Anything you do could void the warranty. If they do not take care of the problem without charges contact Carrier and tell them what's going on. The company who installed the unit is responsible for making it run correctly. Good luck. kstfas
Aug 26, 2007 | Carrier 38CKC036 Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
325 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
