Question about LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac
Leapster L-Max touch screen issues
Good Morning. I saw your post concerning the touch screen issues you were having with your Leapster L-Max system. We have the same exact issue. The screens touch sensor does not correlate to where you touch and the calibration does not work. Were you able to resolve the issue and if so what was the solution.
Thanks in advance,
Chris
  • zebrastripes Jun 24, 2008
    My son's L-Max also is having problems with the touch screen. You try to click on a game and it picks something else on the screen. Very frustrating for a 5 year old to understand!
  • tedmod Dec 05, 2008
    I agree, this is very frustrating. My leapster L max touch screen also does not work correctly. help!!! The screen does not always work. it seems like it is the top and the bottom of the screen. I guess it is the common areas.
5 Suggested Answers
SOURCE: leapster doesn,t respond when the
for leaster 2 -
turn off unit, take out cartridge.
hold the hint button, turn unit on.
press A button, touch the stylus on all the cross hairs that appear.
power unit off when done.
power back up.
(got these from the leapfrog site and it worked for me!)
Posted on Dec 30, 2008
SOURCE: Leapster 2 will shut off right after the "important" screen
Just called Leap Frog and apparently this is a common problem (defective screen). As long as it was purchased within a year they will replace it for free. They ask you when and where you bought it. (You have to pay to send the broken one back it was like $5). Hope this helps.
Posted on May 28, 2009
SOURCE: Leapster L-Max with No Sound
We had the same problem and I found the speaker was broken. Radio Shack part # 273-0092 is almost a direct replacement. Under $4 and works like new now.
Posted on Jan 11, 2010
SOURCE: Screen calibration doesn't work on Leapster 2.
CALIBRATION - summary of hints from here that eventually got our circa 2007 green leapster's screen recalibrated - in no particular order: 1) "home+hint+B" to get started, 2) "A" button next, 3) cleaned dirt from the gap between the plastic and the screen all the way around with a toothpick (seemed to be the KEY ELEMENT to get everything else to work), 4) be patient and keep trying until you see the targets - the first one should appear in the top left corner while the text is still on the screen, 5) if it doesn't work just right the first time try again, 6) unit should beep each time you press a target center.
Posted on Apr 17, 2010
I have leapster l-max and am having trouble with the stylus working. when i try to calibrate, i can't click on center targets
Leapster L-Max recalibrates differently. I was trying to use the instructions and it kept asking for a blue button. For the Leapster L-Max push B, A, Hint, and Home when you turn it on. Do not have a cartridge in the player or it will think it is a regular Leapster. Once it says calibrate screen it will say to press A, then wait until a target appears in the upper left hand corner, touch it and you should hear a sound, then a new target appears in the lower left hand, repeat actions, then lower right hand screen, and finally the upper right hand screen. If it stops at any time and doesn't get more arrows, try it again or turn it off and see if the pen works. It may take several times to get it working again.
Feb 05, 2011 | LeapFrog LeapSter L-Max Console
The touch pen doesn't work
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted
2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears.
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Nov 28, 2009 | LeapFrog LeapSter L-Max Console
TOUCH SCREEN IS NOT WORKING
We have the same problem and our leapster is only 2 days old.Do Touch Screen Calibration,it should help.I do it everytime for my son when he wants to play and it does help...But once u turn leapster off,u'll have to calibrate it again next time...
Just hold down hint button while turning on.When the Leapster menu screen appears,press the A button.Touch each of the crosshairs that appear with the stylus.restart unit. ..That what we do everytime.
Oct 24, 2009 | LeapFrog Leapster 2 Learning System
My Leapster 2 comes on, shows the name on screen & ask to touch my name w/ the pen; however when I touch the name, nothing happens. It keeps asking to touch a name or "guest".
Answer
5) Restart unit
Jul 28, 2009 | LeapFrog Leapster 2 Learning System
The touch screen on my sons leapster doesnt work.
Buy another one from the same store and just swap them.
Feb 20, 2009 | LeapFrog LeapSter L-Max Console
Leapster can't read input
You need calibration
Touch Screen Calibration is as:
1.) Ensure that a cartridge is NOT inserted.
2.) Hold down the Hint (’?') button while turning the unit on.
3.) When the LEAPSTER menu screen appears, press the ‘A’ button.
4.) Touch each of the crosshairs that appear with the stylus.
5.) Restart the unit.
Dec 25, 2008 | LeapFrog Leapster Electronic Book:...
How do I delete a name from Leapster? I bought it used.
Question How do I delete or change a player name on Leapster™ cartridges? trnsp.gif Answer It is possible to remove a player once you have added three player names to the cartridge. If there is a name on the cartridge that you want to remove, take these steps.
1- Add new players until there are three players on the cartridge.
2- Once you have three players on the cartridge, an "X" will appear below each player's name.
3- Touch the "X", then touch the name of the player you want to delete. Touch "Yes" to delete the name. Then add a new name, or touch OK twice to go back to the sign-in screen without adding a name. Two names will always remain on the cartridge.
Dec 23, 2008 | LeapFrog LeapSter L-Max Console
The pen won't work on my daughter's leapster
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Nov 10, 2008 | LeapFrog Leapster Electronic Book:...
Leapster screen not working
Apparantly, the Leapster screen issue is a common problem. While this suggestion is not ethical and since my game was near perfect condition, I went to Wal-Mart and bought a new one of the same color and then returned the broken one.
Jun 12, 2008 | LeapFrog Leapster Educational Game: Disney...
Leapfrog Leapster touch screen
Got my son's to work. Used these instructions.
Question Why doesn;t my Leapster2 respond to the stylus pen? trnsp.gif Answer If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Feb 11, 2008 | Nintendo Game Boy Advance Console
LeapFrog Leapster Electronic Book: Spider-Man (30425) for PC, Mac Logo
263 people viewed this question
Top LeapFrog Computers & Internet Experts
Alun Cox
Michael Cummings
Level 1 Expert
Are you a LeapFrog Computer and Internet Expert? Answer questions, earn points and help others
