Samsung DVD-HR720 DVD Recorder
Problem for Samsung DVD-HR720 DVD Recorder
Samsung DVD-HR725 DVD Recorder 160GB
By Detsch on Jun 14, 2008
After I switch on the Samsung recorder-> DVD is blinking, HDD is on, display is showing "load" and nothing happens afterwards. It would be great to get some ideas how to solve this. Many thanks in advance.
Same Problem
May 06, 2009
-   My samsung dvd HR 720 during a recording session just turns completly off if i set for 1 hr 2 hrs 2.5 hrs still the same problem. please help -   Guest
Feb 20, 2009
-   I cannot play any of the CDs that I have copied on other machines.
I have been told that cheaper machuines will play any disc.
can any body tell my why?? if this is so it is not worth buying expensive models.-   ronv461
Feb 20, 2009
-   I have HR725 with the same problem, I do find that if I pull the plug for aprox 2min it clears it.
Ron -   Guest
Feb 04, 2009
-   Same problem here for over a year.
This is a piece of **** !
None of the solutions will work.
Im afraid its just a brick now and Samsung sure as hell wont replace it. so Bye bye 200 euros. -   Guest
Jan 19, 2009
-   My problem exactly. After I switch on the Samsung recorder-> DVD is blinking, HDD is on, display is showing "load" and nothing happens afterwards. So if I understand the situation correctly, this is now an object for the scrapyard? I had a almost full disk with things I really would like to save.
/Jay-   Jaysus
Best Solution
posted on Oct 01, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The main processor card is not running. There is a small controller card for the display that starts correctly and wait the signal from the main processor. This signal never comes.The solution is simple: replace the cpu board! :-(
Solution #2
posted on Sep 09, 2008
Somewhat Helpful)
Raj001
Rank: Apprentice
Rating: 82%, 3 votes
I have other problem but I know how to solve the 'load' problem. Just hold on to power on button for 4-10 seconds, the player will turn off and reset itself. Mostly this will solve the problem. Problem most likely due to incompatible disc or the menu selection jump to quickly. Hope this help.
My problem is that my recorder no longer output any sound, just like that!! Any help will be appreciated.
Was this helpful?
Yes
No
Popular Solutions for Samsung DVD-HR720 DVD Recorder
Questions and Unsolved Problems for Samsung DVD-HR720 DVD Recorder
Do you recommend Samsung DVD-HR720 DVD Recorder?
Answer
Answer
Blank dvd-rw will not format. Tried many makes. Says due to 'error detection' gets to 90% Machine... (More)
Answer
how do i finalize a disc on my samsung hr720 dvd hdd recorder
Answer
i cannot record digital input only analouge.I have a good digital ariel and the tv on digital gives... (More)
Answer
forgot parental password and how to open multi-region, this unit is region 3
Answer
Model HT Z310 will not load the disc. It shows loading and then opens the disc. It doesn't complete... (More)
8 Other Users Have The Same Problem - Continued
Comment by beerbelly100, posted on Oct 01, 2008
I have the same problem. tried holding the power button put this didn't solve it.
Comment by wnverhoef, posted on Jul 11, 2008
Same problem here, stuck at load when I turn it on. Won't open either, just says 'open' on the display but doesn't do anything.
Kinda weird that the player responds to the remote control, but won't do anything else :)
Tried pulling plug but didn't help, alas.
Comment by passy34, posted on Jul 02, 2008
I moved the Recorder from one TV to another and now it will not move beyond the 'load' stage. Nothing works.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Players Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
