Question about LG 26LG30 26 in. LCD TV
Will only show black tv , and blue light on - LG 26LG30 26 in. LCD TV
  • 11,361 Answers
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there is some troubleshooting you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Please post back what you find.
Posted on Nov 05, 2010
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
My tv will not show a pic the light that shows the tv is turned on will blink 15 times and then will go to a black screen but i can see that its on only by the screens blue black hase
thats code for something, look it up on the lg web site unless you really wanna wait for some one to type it out for you, pretty much every thing manufactured after 2000 has info online, utilize it
Start with LG support
Nov 19, 2010 | LG Televison & Video
Brake Box Will Not Work
First try a 12 volt "stab in" test light pushed into the blue wire at the brake controller. Red is brake feed from the truck, black is 12 volt power and white is ground. If all is wired correctly, the blue wire should power up when you hit the brakes. Be sure to turn the controller up to highest setting to test it. When you hook the test light up, the connection indication light should come on. Then turn red when you hit the brakes. Also see http://www.etrailer.com/faq-wiring.aspx for more info.
Oct 22, 2009 | Pioneer Voyager 4000 HD-DVR
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
Blue snowy pixel areas on my plasma
some of these panels were mis-calibrated from the factory after not aging long enough. Let the TV run for atleast 2 hours and adjust the Vs and Vscan voltages. When it is blue in the left I have found generally the Vs is about 10 volts too high.
Jun 16, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
LG 26LG30 26 in. LCD TV Logo
74 people viewed this question
Steve Allison
Steve Allison
