Question about HP LaserJet 4L Printer
HP4L Each time I switch on my computer the printer prints a page with one line of one ore more "X" ses. I have reintsaled the XP printer driver, but it did not help. Now I switch the rinter on only after I have started the computer.
  • 3 more comments
  • cuker Jun 15, 2008
    Yes it works correctly if I power it up after I powerd up my computer. Operating system WindowsXP. It is hooked up using a parallel printer cable.
    Thanks
  • Bahiano Jun 18, 2008
    How do you "dump" or "purge" the internal memory of the 4-L--it is printing none stop blank pages--or one line or a few letters at top of some pages.
    I clicked on the printer icon on bottom right of my screeen and then hit "delete" or cancel print jobs--but it still continues printing
  • cuker Jul 10, 2008
    At long last I have connected a new cable, but the problem did not go away.
  • hector_morch Jul 23, 2008
    Each time I switch on my computer the printer prints a page with one line of one ore more strange characters....page after page.It looks as the memory has a lot of garbage. I change the printer cable and installed again the printer...it continues doing the same
  • Tim Babcock
    Tim Babcock May 11, 2010
    Does it work correctly when you power it up after Windows?
    Is this hooked up using a parallel printer cable or a usb cable?
  • HP Master
  • 2,794 Answers
Good. Usually that error is cause by a bad data signal comming in from the printer cable. It should be replaced to get rid of the problem.
Posted on Jun 15, 2008
  • Tim Babcock
    Tim Babcock Jul 11, 2008
    Getting that kind of data communication to happen during power up can cause the Xs to appear. You should start the printer after the computer is into Windows to get the problem to go away. If the printer was on a network system, this wouldn't happen but this does happen on parallel cable connections. This used to happen a lot during the DOS days when you shut the computer off.
    As far as purging the memory goes, that particular printer doesn't have a control panel to purge the memory. You have to turn the power off, wait 30 seconds to turn the power back on. If the job isn't on the print que in Windows, chances are it went into the memory of the printer.
HP 4L will print test page just fine but cannot communicate with my computer. Tried to download new drivers but that didn't work. Any ideas?
Hello, The HP4L will be connected by a parallel cable. This is the big cable attached to the I/O interface. The first thing to try would be to reseat the cable by removing from the printer and the computer. Look at the pins for any obvious bent pins. Install the cable back onto the printer and computer. Try sending a test page to the printer from the computer. If the printer does still not work, I would definitely recommend the use of another cable. If the cable has been changed and the printer still does not function, then most likely the inferface has gone bad, in which case the cost of repair for this older printer may not be worth it. regards, Pre.....
Jan 15, 2011 | HP LaserJet 4L Printer
Prints only hp invent page
Most of the time, if a printer prints the demo page, it is functioning. Perhaps you should uninstall the driver, and go through the `add printer' wizard (on Windows based computers). If it discovers it, it should work. The driver is resident on Windows XP and above.
Sep 20, 2010 | HP LaserJet 2200D Printer
In the process of printing pictures but I can not locate the photo printer function on my LexMark 4650. Pls advise. Thank you
reintsall your printer driver software. you can download the latest printer driver software from your printer manufacturer's web site then restart your computer
Jun 11, 2010 | Lexmark X4270 All-In-One InkJet Printer
HP4L Printer-While printing,paper cycles1/2the way, printer stops
Check the paper size setting in the software and print driver. Sounds like a non-standard paper size setting.
Feb 15, 2009 | HP LaserJet 4L Printer
Kyocera 3900 dn, is there a way to speed it up?
1.install the latest print driver; see if the rip/spool time is long or the printing time is long. The rip time depends by your computer (!) and the print driver (disable the collate option when printing multiple copies of 1 page = on the printer you should see 1/5 spit a page then 2/5 and spit another page for 5 copies of same page. If you see processing the spit the page then processing and spit the page means your computer is sending 5 times the same page instead of sending once and ask for 5 copies !!! )
2.use network connection instead the USB.
3.expand the printer memory
4.switch the printer from PCL to KPDL or Auto when printing pdf files.
Dec 28, 2008 | Kyocera FS-3900 DTN MONO LASER PRINTER
Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Cannot Install it Successfully
Restart you computer. Turn your printer off, wait 20 seconds and turn it back on again. Load up software you use to talk to the printer.
What interface are you using to connect to the printer?
Jul 17, 2008 | Star Micronics TSP400 Label Printer
HP4L prints all balck page
Try reseating the print cartridge if this does not work try a new print cartridge the problem seams like your primary charge failure.
If you require more help please get back to me
Thank You
Mar 11, 2008 | HP LaserJet 4L Printer
Printing problem
>go to printers & faxes
>right-click on the printer icon and select Properties
>click on the Print Test Page button
>windows test page will print - if issue still persists : uninstall driver from the XP Control Panel -> Add & Remove Programs -> EPSON Printer Software
>reboot computer
>re install printer driver
Dec 31, 2007 | Epson Stylus C82 InkJet Printer
HP LaserJet 4L Printer Logo
54 people viewed this question
Ben Johnson
