Question about Frigidaire Refrigerators
My model number is FRT181L6JB1 and my freezer needs to be colder. Is there a separate control for the freezer? I don't feel right about boosting the refrigerator to cool the freezer. Thank you in advance for your help.
HVACRH20
  • 237 Answers
SOURCE: Refrigerator not cooling
You will have to let it run for a while, then take the interior back cover off the freezer side to look at the frost pattern on the coils. There should be a nice even white frost on them all, if there is a solid block of ice the defrost cycle isn't working and if there is not much frost but a few inches then you likely have a sealed system leak (no more refrigerant). There can be other issues like the compressor start device not working or the temp control failed, etc. so we will have to go back and forth to do more troubleshooting. Repost with more info when you have it.
Posted on Jan 31, 2007
SOURCE: Kenmore Model # 596.735032.. Fridge is cool, Freezer is not freezing
After pulling the fridge away from the wall and removing the lower right hand panel I noticed that the compressor (big round black ball with copper tubing) was not turning on. I also noticed that there was a ticking or popping sound comming from it every couple of minutes or so. After doing some research online in numerouse forums I decided to try and replace the overheat relay that is attached to the compressor. It only took maybie five minutes at most to change it and the compressor is now working with nice cold air comming into the fridge and freezer. Hope this helps someone else with the same problem.
Posted on May 10, 2008
  • 2920 Answers
SOURCE: Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Posted on Aug 27, 2008
huuum
  • 750 Answers
SOURCE: whirlpool side by side refrigerator not cooling
Hello danielscynt,
Welcome to Fixya,
You said, freezer is fine the refrigerator is 50-65 does not get colder than 50.the evaporator fan is working but it seems to be blowing very little air
Have a 1998 Hotpoint Model # CTX16CAZDRAD Serial # ZS738209. The refrigerator is not cooling. Temp is at 66 degrees with setting at 5. The Freezer is working, but it seems to be running all the time. Please help!
There are a few things that come to mind!
The Freezer is working, but it seems to be running all the time, you said!.
This could be a bad thermostat!
But lets try some simple maintenance first!
Is your freezer packed too the hilt with packages???????
Where the articles cover the air vents in the freezer?
The freezer and the fridge share the cold air and the passages must not be blocking the cold air from moving out of the freezer!.Search your freezer !
Also your fridge is 10 years old!
Did you ever remove the plastic grille at the bottom of the fridge along the front, and GENTLY run a refrigerator brush along the black metal tubes running back and forth under the fridge?
( You can buy this brush at any hardware store $10.)
They must not be covered in ten years of lint and dust. These narrow tubes carry the freon and run in this parallel fashion back and forth, so they are cooled by the air being **** through them.
if not and they overheat your fridge will get warm.
If the tubes are found to be covered or submerged in dust sometimes I have found them one to two inches thick in dust, and sometimes they are even not visible until you clean the dust out.
Then it will take 10 to 24 hours for the system to get back to full working temperature again. As long as the heat did not cause permanent damage!
if these are not the answer, then you may need a hands on diagnoses!
BUT, most of the time these two things are what I find!
Let me know how it goes!!!!!!!!
Thank You for asking my advice!
Huuum
Please remember to leave a rating for me!
Posted on Oct 08, 2008
lenwest
  • 150 Answers
SOURCE: Refrigerator part not cooling, freezer
There is a vent that is connected from the freezer down to the fridge right where the fan is,make sure nothing is blocking it.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Posted on Feb 27, 2009
My freezer isn't cold enough. Are the higher numbers on the thermostat dial colder or are the low numbers colder? See full question below.
Hi, If I remember correctly, make sure the freezer control is set to on, otherwise neither will cool.
You need to give it 24hr for temp to settle, then check to see if freezer temperature is 0? to 2? F (-17? to -16? C).
Turn control to next highest number if too warm.
Turn control to next lowest number if too cold.
Allow 5 to 8 hours for adjustments to take effect.
Check to see that fresh food section is 38? to 40? F (3? to 4? C).
Hope this helps
David
Mar 02, 2018 | Amana Refrigerators
Which is colder 1 or 5?
My Avanti's temperature control is numbered 1 -5, and after 5 is MAX.
There is a separate control in the freezer section, but that is another matter.
As a matter of fact, in any refrigerator with a temp control, turning it towards the RIGHT will always result in COLDER.
If you open the door dozens of times an hour, you'd probably want to keep it on MAX.
If not, then MAX setting might begin to freeze some of the items you do not want frozen. If you are a normal user, try setting to 3.
Aug 16, 2014 | Avanti Refrigerators
Maytag fridge not cooling
If the ref or freezer is too warm and you turn the dial to make it colder the compressor should come on. If the ref or freezer is not cold like you say the compressor should be on all the time. You should hear it, but you can definitely feel it and it should be very warm after a short while.
If the compressor does not get warm unplug the ref with the compressor running and plug it back in immediately. A good compressor should not start up right away.
If it is running and not getting warm and does start right up after unplugging it and plugging it back in it is inefficient and not compressing the freon gas enough and therefore not cooling enough.
The fan in the freezer should be running as should the fan under the refrigerator.
The condenser should be warm and the fan should be blowing[drawing] air across it when the compressor is on.
You don\'t repair compressors and to recharge them correctly is expensive.
May 01, 2013 | Refrigerators
Need User Manual for Electrolux Model Number N520J-R, Freezer is cold, but fridge section is not.
The right bottom corner of my fridge is broken and I need the part. Please let me know if it is available. The specification is as follows: model code: N520J-R, and name is Electrolux, Kelvinator, please let me know because I do not have any other option to fix it. I have financial problem to buy a new now but only I can buy a door to replace it. Thank you. My contact: razaqanwari@yahoo.com, my mobile is 0406266401
Jan 03, 2012 | Refrigerators
How to make my freezer colder
Hi, some thermostat control knobs and directions to make it colder are different. Here is the best way to find out which way to turn it to make it colder. Make sure you hear it running. Take the control knob and listen carefully while you start to turn it in one direction first. Turn it until you hear the unit shut off. If you turn it all the way to the left and it keeps running, turn it all the way to the right until it stops running. Once you know which way it stops running when you turn it, this will tell you that you need to turn it until it comes back on again and runs. This will be the way it turns to get the temperature to get to a colder setting. When you are doing this, do it very slow and give it about 3 minutes in between each time you start to turn it the other way. On mine it has numbers on it. The higher the number lets say from 1 to 8, the colder it gets, but some are the lower the number the colder it gets. So, you want it to shut off, so wait until you hear it running before you turn the knob. You can open the doors and it will make it come on faster. So when it goes off when you turn the control knob, you will no to turn it the other way for it to come on and it will get colder the more you turn it in that direction. Very easy. PS If it doesn't get colder when you find out which way it goes, you may have a bad thermostat. Please let me know. You can put a thermometer inside to watch the temperature
Good Luck,
Shastalaker7
Jun 30, 2010 | Hoover 9.9 cu. ft. / 280 liter Upright...
Temp Control
Hi!!
The higher the number, the colder the setting.
Rate this post, Good Day!!
Apr 26, 2010 | Haier 5 cu. ft. / 142 liter Chest Freezer...
I have an Upright freezer. I don't know which exact model I have. (I think the 14.1 Cu In Frigidaire) How do I warn the freezer up a liitle bit? Its too cold.
Here is a link that can help. Let me know what you find while you look at the PDF. Is this your refrigerator? Let me Know, Thanks, Sea Breeze.
Temp. control should be on page 4 part number 18 Turn left for warmer or right for colder. If this don't work then the control will need replaced.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Jan 31, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Temperature control
I have a danby mini fridge and freezer and noticed the same problem. The temperature dial has NO NUMBERS ON IT! it just has a strip that goes from light to dark blue. That's it. I looked in the manual and it doesn't say anywhere which way is colder...it makes sense that the darker the blue the colder the temperature but why keep us guessing?
Mar 15, 2008 | Danby 3.6 cu. ft. / 102 liter Chest...
Refrigerators Logo
41 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
