Question about Gateway 506GR PC Desktop
Computer wont start
I recently moved my desktop and when i plugged it in the computer wont start up. When plugged in i get a blinking light in the back of the modem but the computer still doesnt start. I have tried removing the battery and replacing it and also messing around with the cables that connect from the start button to the mother board (http://support.gateway.com/s/MOTHERBD/Intel2/102007/102007mvr20.shtml) and the best i got was the G to blink blue and the battery sign under to blink yellow
  • 1 more comment
  • Anonymous Jul 01, 2008
    I have the same problem but no solution... I just came back from a vacation, and the computer just wouldn't turn on.
  • bocyber Jan 09, 2009
    Have a Mod. 702GE Gateway desktop. Was working fine and I put it in hibernate mode at lunchtime. I came back to it an hour later and it will not start. The fan runs, the power indicator light is on, and the CD/DVD drawer extends and retracts. Otherwise, nothing happens. The CRT monitor diagnostic screen intermittingly shows "monitor OK, check cabling" for awhile. Nothing was touched or changed while I was away from it, but I checked the cabling, power supply, etc., anyway.
    Any ideas?
  • dcridelich Apr 28, 2009
    computer won't start. if I hold the power button the G blinks blue and the light below it blinks yellow the hard drive doesn't sound like it is going thru the boot process. this happend once before but when I held the power button in for a few seconds it suddenly booted.
    This time nothing but blinking lights
Replace your bios battery
Posted on Jun 14, 2008
My computer wont start up. The power supply light flashes green when plugged in then red. But still nothing , can someone please help?
Try a Power Supply Unit (PSU) Reset: Unplug the electrical cable from the wall and the PSU (Back of Computer)
Move the red voltage selector to the opposite position it is in and then slide it back. If you live in the USA 120Vac to 220Vac back to 120Vac
After you have done this you can plug the power cable back into the PSU. Connect the power cable to the wall power. If the PSU is still serviceable it will no longer be blinking.
2c170cb8-7c41-4ef0-8a3f-ff232e57320e.jpg fd10abb2-6218-42f0-8857-b761fffbcecd.jpg
Jul 08, 2013 | HP Compaq Business d530 PC Desktop
It wont start gust does beep beep beep
Is there a light blinking on the back of the computer near the fan or plug? If so you need a new power supply unit.
Feb 04, 2011 | E-Machines eMachines Desktop PC
No panel lights, no fan, flashing front left light
the blinking lights means power issue. If you already plugged the computers power cable directly to the wall and stll get the blinking power light then your probably looking at a bad power supply in the computer.
Just for measures go into the system and if you have a video card remove it and start the system up. Also take out the memory stick and put them back in just incase during the move some components got loose. Put on your detective hat and check all connects. if problem still persist replace the power supply. In Computers terms thats called the PSU (power supply unit)
Your friend
Joel
May 29, 2010 | Dell Dimension 3000 PC Desktop
Green power supply light blinking, computer won't start.
A lot of those E-Machines used a small power supply (150 to 180 watts) and were known to have a failure rate. There is a way to check them by jumping across a two connector wires on the end that plugs into the Motherboard. Let me know if you want try this.
Apr 25, 2010 | E-Machines T5026 PC Desktop
Computer wont start up. Blinking green light in the back of tower
I've had that happen twice to my Vaio desktop and there was a very easy fix. I'm not a techie, but I found a recommended solution online when this first happened six months ago. I couldn't find the solution again, but I fortunately remembered the steps.
Remove the side pane to access your motherboard cables, etc. Locate the connector on your motherboard that contains the wires going from your power supply to your motherboard. It will be a large, rectangular connector with a lot of individual wires It is not a ribbon cable but should be located next to a ribbon cable connector andnext to a geen blnking light on your motherboard (when the power supply is plugged into the wall). Note: This green blinking light is in addition to the green blinking light on the back of the PC.
This next step is important: You have to disconnect the connector noted above from the motherboard WHILE the power suply is plugged into the wall. Wait a few seconds and plug it back in. The blinking reen light on the motherboard should now be a solid green light. The PC should now power up.
It worked twice for me; I hope it works for you.
Mar 05, 2009 | Sony VAIO VGC-RB42G PC Desktop
Wont boot
je lit mes cd mesya pas du son
Dec 26, 2008 | Intel Celeron -D 2.26Ghz Computer System...
Acer aspire T120c wont start red light blinks once when i push the power button
If you turn on the computer and it will beep once and the red light blinks means the computer is starting will.. but if the computer beep once and the red light blinks once means there are something missing or something bothering the computer.. try this Check the connection cable of your computer, the power source, the hardware interface, and if you installed a new hardware, try taking that hardware out and turn on again the computer. if the problem still exist try to disassemble and assemble the hardware of the computer. You must have someone with you know how to assemble and disassemble the computer hardware for safety method TY.
HOPE I CAN HELP
Dec 05, 2008 | Computers & Internet
No power, power supply & motherboard green light blinking
I had the same exact problem for the same exact reason. Plug the power cable into the back. Open up the side of the case and unplug all the wires that the power supply plugs into. The motherboard, harddrive, cd & dvd drives, everything. wait about 10 minutes and plug them back in, plugging the BIG cable that connects to the motherboard back in LAST. This will make the light go from blinking to solid. I think it is a safety? to protect the motherboard from damage.
Nov 01, 2007 | Sony VAIO VGC-RB42G PC Desktop
Unable to turn on computer
was the computer on standby when you plugged it out?  press and hold the "on" button for 5 sec's this should switch it off and reset then try turning it back on again by pressing the same button
Oct 31, 2007 | Compaq Presario S6000NX (DQ178A#ABA) PC...
Gateway 506GR PC Desktop Logo
207 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
