Question about Asrock Motherboard K7S41GX for AMD Sempron/Athlon/Duron (B01029)
Beeping my mother board beeps 3x repeatedly i checked the memory on a different pc and it was working alright
  • louise4us Jun 17, 2008
    i pray that you keep on with the good work youth been doinng am most greatfull
  • 4,472 Answers
How many sticks of RAM are in the PC? If more then 1 try each stick 1 at a time see if any of them will work by themselves. Also if you have any other memory that is known to be good to test in this PC that would also disprove some theories.
Good luck and if it still not solved let me know and we can see if there are any other solutions besides trying a new stick of memory.
Lee
Posted on Jun 14, 2008
  • Lee A.
    Lee A. Jun 17, 2008
    Did you get the problem solved yet?
    Thanks,
    lee
I have a dell inspiron 545. I lost my display and the computer now beeps four times, pauses and beeps four more times. Can you tell me what happened to my computer?
This is normally a memory error. Turn off the computer, and open the side of the case. Pull and re-seat all memory chips. Turn power on, if it still beeps. Turn off power, pull all the memory chips and re-seat one only. Turn on power if it beeps againg, pull the chip out and try the other one. Repeat for all chips. If you find any that do not cause the beep issue, you have found your bad memory chip. If not, try the same one at a time memory test in a different slot on the computer. If no beeps, then its a bad slot and dont use that memory slot.
If none of this works; as unlikely as it seems you could have all bad memory chips, or a bad mother board.
Jun 12, 2012 | Dell Computers & Internet
Dell inspiron has no display and beeps four times and then pauses and beeps four more times
Five long beeps at a range of five seconds then, repeats
Five long beeps for a modern motherboards indicates a processor failure. If you wish to remove the processor and re-seat it (reconnect it to see if it begins to work again) make sure to get some thermal compound to put between the CPU chip and the heatsink. More info at: http://www.hardwaresecrets.com/article/How-To-Correctly-Apply-Thermal-Grease/274
POST AMI BIOS beep codes
  • 1 - Memory refresh timer error
  • 2 - Parity error in base memory (first 64 KiB block)
  • 3 - Base memory read/write test error
  • 4 - Mother board timer not operational (check all PSU to MB connectors seated)
  • 5 - Processor failure
  • 6 - 8042 Gate A20 test error (cannot switch to protected mode)
  • 7 - General exception error (processor exception interrupt error)
  • 8 - Display memory error (system video adapter)
  • 9 - AMI BIOS ROM checksum error
  • 10 - CMOS shutdown register read/write error
  • 11 - Cache memory test failed
  • 12 - Mother board does not detect a RAM module (continuous beeping)
Source: Wikipedia
Feb 28, 2011 | Computers & Internet
PC will not boot up, tried replacing the psu, unpluging the hard drive & 7-1 card reader. The pc then makes a 8 beep sound before repeating itself. Mother board is a pc chips m848a
Beep codes are vary depends on the BIOS manufacturer, when ever your computer beep more than once this mean it has an hardware problem. To determine the problem you need to check the memory, if these is another empty memory slot take the memory from its present slot and put it in the empty slot always make sure the memory fit firmly in the slot .If you still hear the beep you can replace the memory,you can replace the video card if the problem still exist you should try another CPU because the present one may be faulty and finally if the problem still exist this mean the memory slot is faulty and the only way to fix this is to replace the motherboard.
May 18, 2010 | Computers & Internet
When I power up my acer PC I get a beep beep beep
Open your cpu cabinet cover.
Then Refix RAM memory on mother board.
Remove pci cards from mother board if any.
Make sure motherboard is not ground with cabinet.
Reattach ATX power connector to motherboard.
Pull cmos cell from motherboard for 10 minutes then refix it .
Then it work again.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 06, 2009 | Acer (AST135-U-S3100) PC Desktop
Laptop Beeps on start up 1 long and two short beeps
You've checked the memory board/card, but have you tried using another memory card? The 1 long followed by 2 short beeps indicates that there's a problem with the memory card. Try to remove the memory card, then wipe the gold traces with a dry cloth and put it back in.
If you try replacing the memory card but you get the same problem, then proceed with the video card.
Aug 29, 2009 | HP Pavilion dv9000z Notebook
Dell XPS 600 beeping noice
there are 2 things that can cause that, memory failure, or mother board, cheeper route to go would be replace your memory first, and see if that corrects the problem, if not then, check anything new you installed inside such as video card, lan cards, of something like that, if that doesn't work you need to have it looked at and possibly the mother board replaced,
Jun 22, 2009 | Dell XPS™ 600 PC Desktop
Beeps
Different PC manufacturers have different BIOS Boot codes.
Read first
http://pcsupport.about.com/od/nonworkingcomponent/ht/beepcodestb.htm
Then read:
http://www.pchell.com/hardware/beepcodes.shtml
http://www.computerhope.com/beep.htm
http://networking.ringofsaturn.com/PC/beep.php
Apple:
https://mediawiki.middlebury.edu/wiki/LIS/Apple_Computer_Beep_Codes
http://www.techbase.iofm.net/tips/applemac/tip1.htm
http://www.user-guides.co.uk/download/apple/applebeep/apple-beep-code.html
Jul 06, 2008 | Gateway GX7022E (RBGX7022E) PC Desktop
Beebing tree times
Louise -
Although the memory may be working okay in another system, the three beeps at post still indicates a memory(RAM) problem. Your motherboard uses AMI BIOS, as indicated by the product specifications on the Asrock website; In the post-error code listing, three beeps is a memory issue.
Check and make sure you have compatible memory for the motherboard; and if possible, test with new or alternate memory sticks.
If new memory doesn't resolve the issue, I would say the RAM slot(s) is damaged, which would require totally replacing the motherboard.
Hope this helps!
-thinstatic
Jun 13, 2008 | Asrock K7VT2 Motherboard
Asrock Motherboard K7S41GX for AMD Sempron/Athlon/Duron (B01029) Logo
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
