Question about SanDisk Sansa E280 MP3 Player
Blue line on Sansa 280 screen
I got this 3 days before. My computer was restarted by mistake when the device was connected to it. The player froze for a long time. Then I disconected it from my computer and restarted it. Since then I see a blue horizontal line on the screen. Please help!!
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jun 20, 2008
SanDisk Sansa froze on song screen, wont unfreeze
Make sure the player is fully charged. 1. Connect the player to your computer. 2. Make sure the computer detects the player.
NOTE: If needed, switch the player to MSC mode, 1. Turn device OFF. 2. Slide the Hold switch down to Lock (orange color showing). 3. Press and hold the center button while connecting the device to the PC.then connect it to the PC. Next Be sure the battery is charged 1. Leave the player connected for approximately 2 hours to charge. 2. Disconnect the player from the PC. 3. Verify if you can turn on the player. 4. Reset the player if necessary.
To reset the player: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
If that does not do it, re-seat the battery: Then try and see if it will come on with out the battery hooked to your computer, which I see you have done but did you change modes MSC to MTP . next delete the song it keeps hanging on and re-copy it back on to the player from a different folder or re-rip it from the CD and copy it into a new folder then re-copy to the player.
Feb 02, 2010 | SanDisk Sansa E280 MP3 Player
My view wont do anything, when i turn it on the only thing it does is turn the dial light blue, nohing else, when i plu it in, nothing. the blue light will stay on for however long the battery lasts, is...
Solutions are in order of increasing probability of data loss AND device recovery.
Screen messages are loose approximations
A Soft Reset
1. Hold Power switch up for 5 seconds.
2. Screen displays "Goodbye".
3. Restart
B. Hard Reset
1. Hold Power Switch for 30 seconds
2. Restart
C. Recovery Mode
1. Hold Power Switch for 5 seconds to switch device Off
2. Move switch to Hold
3. Press and hold Home button
4. Connect USB cable to device
5. Screen displays "USB" in small type and "16 MB Format" shows up in My Computer
6. Copy firmware files to "16 MB Format" drive letter
7. Disconnect USB cable
8. Screen displays "Firmware update"
9. Restart device
C. Force Format (This one wipes the data partition. Make sure all needed music/pictures/video exist elsewhere)
3. Press and hold top/North/up of Scroll Wheel
5. Screen displays "Format and lose data"
6. Press right/East on Scroll Wheel to confirm
7. Screen displays "Formatting"
8. Restart device
D. Manufacturing Mode (included for completeness only)
3. Press and hold centre of Scroll Wheel button
5. Windows detects a new hardware device
6. ???
7. ???
8. ???
Dec 27, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
My m3 player froze while charging and now it wont turn on
I held it in the off position while at the same time pressing the menu button....it shut off, then I restarted it. It will repair the media itself.
Jun 26, 2009 | SanDisk Sansa e250 MP3 Player
Can not down load voice recording to computer: Sansa 280.
You can try few simple steps like changing the USB ports, turning off & turning on the mp3 player and then reconnecting it, and then changing the USB mode on device: Menu --> Settings --> USB mode: MSC or MTP
If these don't work, try the steps here: Sansa e250 Not Detected in PC
Feb 01, 2009 | SanDisk Sansa e250 MP3 Player
Mp3 froze
From the Sansa FAQ page at http://www.sansa.com/support/sansa_e200/faqs
09. When I turn on my e200, nothing shows but the blue ring is on, what do I need to do?
Applies to the following Operating Systems:
  1. Windows XP, Vista
The player might have a power glitch. As a result, it does not turn on and is not being detected by the computer.
STEP1 - Reset the player
  1. Hold down the Power button for 20 seconds, then release.
  2. Run the hotfix.
STEP2 - Connect the player to the computer
  1. Connect the device to the computer
  2. Once the device responds, disconnect, and turn it on.
Jan 04, 2009 | SanDisk Sansa e250 MP3 Player
Screen is messed up won't turn off
-Tha Mp3 Doctor
May 23, 2008 | SanDisk Sansa e200 MP3 Player
Sansa wont work
Download the Sansa firmware upgrader and install it first. Then, hold in the volume + button on your Sansa player and connect the Sansa to your computer (while it is in the OFF position). The computer will recognize the player after you continue holding the volume + button for 5-50 seconds. Restart your computer. You will lose all files stored on the Sansa, but it will work again.
Mar 29, 2008 | SanDisk Sansa E280 MP3 Player
Froze
-Tha Mp3 Doctor
Jun 10, 2007 | SanDisk Sansa e250 MP3 Player
Whattt is going on?
-Tha Mp3 Doctor
Feb 16, 2007 | SanDisk Sansa e250 MP3 Player
My sansa e270 is not working
-Tha Mp3 Doctor
Nov 07, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
155 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
