Question about GE WHRE5260E Top Load Washer
Water leaking from bottam while in running cycle
  • 6 more comments
  • Anonymous Jun 18, 2008
    water leaking under washing machine
  • Anonymous Jul 13, 2008
    tube want hold water while filling no steps have been taken
  • Anonymous Jul 26, 2008
    leaking water while washing
  • Anonymous Jul 31, 2008
    tried to remove a water pump from a kenmore washer and it wont come off what should i do?
  • Anonymous Oct 04, 2008
    my washer
  • Anonymous Nov 28, 2008
    linking from bottom
  • Anonymous Dec 27, 2008
    the washer is leaking in the washing cycle
  • teharpe2772 Feb 05, 2009
    Please help.
    My washer was leaking from underneath and now it has stop running. The floor was flooded and the still full of water. I am not sure where the leak is coming from. If anyone has any advice please let me know.
    you can email back at teharpe2772@yahoo.com
    Thanks
Water is leaking from the bottam while in cycle
Posted on Oct 09, 2008
Water leaking from under the machine while running. Also will not stop filling in the rinse cycle.
Posted on Jun 24, 2008
  • carolcray Jun 24, 2008
    Sorry, my previous comment was NOT supposed to pop up as a solution. I NEED a solution! Oops!
Output is some blue colour
Do a Cleaning cycle and clean the rollers.
Jan 17, 2014 | Epson L200 All-in-One Inkjet Printer 27...
Scotsman prodigy leaking water
How to work on Scotsman Prodigy Ice Machine
Jan 16, 2014 | Scotsman Kitchen Appliances - Others
Leaking brown liquid
No. - Do not use. - Go to manufacturers site and get a new seal for it.
Dec 01, 2012 | Kitchen Appliances - Others
I own a zanuusi zwd1680w. washer dryer. The problem is when set to drain or if required to drain during a cycle it goes through the motions and hangsup, the water does seem to drain out quite quickly and...
Hi you dont mention any error codes if there problems with draining e20 is displayed any blockage in the pump or drain passage can cause this . however you suggest the draining is ok so this is more likley to be a fault in the water level control. an easy fix would be if you found a blockage in the pressure chamber at the base of 2 x 8mm tubes(from pressure switches) located near the sump hose at the bottam of the drum. undissolved detergent is normally the culprit.jw
Feb 09, 2011 | Zanussi ZWD1680W Front Load Washer / Dryer
Kitchen aid dishwasher-how do I stop water from leaking from the bottam of the door when it is running?
the sealing rubber known as th "membrane" might be worn out. if you have a while using the dishwasher. if its still under warranty do not touch it just notify the retailer where you bought it from.
Dec 26, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
When the water cycle is running there is a white plug by the water inlet that is leaking. When the dishwasher is not in the water cycle it does not leak. When the dishwasher is stopped in the middle of the...
crack in water inlet valve or a pin hole in the hose going from the valve to side of tub spraying water where you see it. You have a holein someting. You need to trace it back to its sourse. When you say "water is running"im guessing thats when its filling with water not just washing.
Oct 30, 2009 | Hotpoint 24 in. HDA3400G Built-in...
Admiral Leaking
Possibly rinsing with cold water, washing with hot.
Check inlet valves for leaks, especially cold (rinse)
Lift the top panel by inserting a flat blade approx 4" from each side at the front to release clips, then top will hinge backwards.
You can see the valves at the rear behind the drum..
You can run the machine with top lifted to see any more leaks.
Also remove front panel via 2 small screws to gain better view.
Jul 12, 2008 | Admiral AW22 Top Load Washer
Leak problem
Ours did same thing after nearly same amount of time.
Run a couple of sanitary cycles without any cloths.
Only use HE detergent.
Problem stopped after this
Oct 08, 2007 | LG WM1815CS Front Load Washer
GE WHRE5260E Top Load Washer Logo
304 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
