Question about Dell UltraSharp 2407WFP 24" LCD Monitor
Lcd screen completely dark power button steady
Lcd screen completely dark power button steady green when on power supply seems to work front panel buttons seem to work - can cycle through inputs 1-4 usb hub works no 5v from barrel jack (for external speakers)
    Genius:
  • Dell Expert
  • 1,325 Answers
Hello
go to this dell link below -- ..
http://support.dell.com/support/topics/global.aspx/support/dsn/document?docid=361118
if it does not help you resolve the issue, get in contact with Dell support
http://support.dell.com/support/topics/global.aspx/support/dellcare/contact_technical_support?
hoping this served you well
Posted on Nov 05, 2010
I have a sony KDL 46xBR2 when I turn on powers up green light stays on but a dark gray screen no picture or sound
The green light merely indicates that power is getting to your TV. The symptoms you describe point to internal power supply failure
Mar 17, 2013 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Precision T7400 power supply sounding an alarm
Did you open the case on your computer? It may have an open case alarm which is a small switch typically located near the edge of the cover you removed. Make sure the case cover is completely installed, then see if the alarm goes off.
Feb 28, 2013 | Dell POWER SUPPLY Power Supply
HELP! Olevia lt37hvs screen went blank. No Sound, panel buttons wont work. Backlight is only on on half of screen.
if you had audio i wold say its most likely the Tconn or its upper two connections to the Panel itself. But since you dont have any sound either I would assume its either the LVDS cable from the main board to the Tconn or the Main board itself as audio and video are produced on the main board, You can get replacement boards from www.tvrepairworld.com
Aug 12, 2012 | Olevia LT37HVS 37 in. LCD HDTV
Dell228wfp on start up pwr on is green screen
Either the cable is not connected to the proper port or the display-source is not configured properly.Here's what you can try.
  • Ensure that you have connected the VGA/DVI cable in the correct port. If you have an extended graphics card in your computer, use a DVI cable(Digital input) else the VGA would be the only option available.
  • If the cable seems to be plugged at the right place, press the first button from the left on the front panel of your monitor (Button 1 shown in the front view: http://support.dell.com/support/edocs/monitors/E228WFP/En/ug/about.htm#Front_View), once. This toggles the digital mode to analog mode of your monitor, and vice versa.
  • If the first two steps do not work, its not an issue with the monitor. It could be a failing cable or a defective video card, or the system itself is not completing the POST.
Thanks,
Abhishek
Feb 06, 2010 | Dell E228WFP LCD Monitor
The screen went dark and the power button is a steady yellow color instead of a steady green. a loud popping sound was heard before the button went yellow; before that it had been a flashing green button...
pseroy, If you visit YOUTUBE check out the longer video clips of LCD monitor disassembly and repair of the most common type of failure modes that ALL BRANDS have. Whenever posting to this site it would be nice if we could also get a little bit of history-- like age of unit and approx total hours of "on" time. My best guess is that the "switch-mode-power-supply" has finally bit the dirt. Popping sound was the "electrolytic filter capacitors" venting to the atmosphere because they couldn't stand the heat in the unit any longer. In any case a tech should evaluate unit or if it is >3-4 yrs old look to trade in for new. also check web for swollen capacitors in lcd monitors and "cold-cathode-fluorescent-tubes" and their power source which is called an INVERTER circuit. Here is quick and dirty lesson. Monitor SMPS makes dc voltage for inverter (electronic ballast) circuit which makes 800-1200 volts ac to light up the CCFT's. You are dealing with something similar to the new screw-in curlie-Q CFL lightbulbs only their "ballasts" are dirt cheap and are called "converters" AC to AC. Hope this info was of some help. I'm louie12fix on fixya or lmistyrel @ aol .com please rate this response at fixya.
Oct 06, 2009 | Dell E173FPf 17" TFT LCD Flat Panel...
I have a 32 Akai HD TV I found the following problem when I returned from vacation The red light is showing. I press the power button, the green light comes on for a short while and then goes back to red....
Symptoms of a Defective or dying Power supplies on LCD TVs. 1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc. 2. TV not turning ON properly. 3. TV turns OFF by itself. 4. Needs to be unplug to many times to make it work. 5. Humming or high pitch noise heard through speakers or at the back of the TV. I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance.
Jun 12, 2009 | Akai LCT3201TD 32 in. LCD Television
Lcd monitor power light flashing with no img. seems 2 be frozen
The display is in safe mode and you will need to reset the display to get the display out of the safe mode. There are 2 different model revisions. Please choose the method that will match your revision. Depending on the revision of the monitor, one of the following 2 methods should reset it to a normal state. This reset generally requires both hands and it is sometimes easier with another person.
If the serial number begins with an A and/or your power button on the far right (5th button from left):
Method #1
1. Unplug the VGA cable.
2. Remove the power cable from the back of the monitor.
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 3 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
5. If the procedure worked, the green light will go to amber and you should see a "No Signal" message on the screen for a few seconds.
Method #2
4. Keep holding the buttons until the 4th green LED blink; then, let go. The green light should be steady when you release the buttons.
If the serial number begins with a B and/or your power button is in the middle (3rd button from left):
Method #1
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see attached picture) and while continuing to hold the buttons, plug the power cable back in.4. Keep holding the buttons for 5 seconds after the power has been plugged in and then let go. The green light should be steady when you release the buttons.
Method #2
3. Counting the buttons on the front of the panel from left to right as 1 – 5, hold the buttons 2 and 4 down at the same time (see picture above) and while continuing to hold the buttons, plug the power cable back in.
If you have tried the reset a few times and it does not solve your issue, please Ask a Question to submit a request through the system or call 1-866-752-6271 Option 1 to contact technical support.
Mar 02, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
TV blinked out and now it doesnt come on?
Feb 26, 2009 | Akai LCT2715 27 in. LCD Television
Protron 26' t.v
Dec 30, 2008 | Protron PLTV-26 26 in. HD-Ready LCD...
Dell UltraSharp 2407WFP 24" LCD Monitor Logo
153 people viewed this question
Alun Cox
