Question about Eljer & Patriot& Elongated Toilet Bowl
25 year old toilet, all of a sudden, seems to be shifting and the tank is now angled and one side is touching the wall, nothing seems loose, or wobbly, but it must be moving, since it never was this way before- any ideas about what needs to be done to correct the problem?
  • 42 Answers
The tank to bowl bolts need to be replaced. The tank will need to be removed and new SOLID BRASS BOLTS and the gasket will need to be replaced. When you tighten the new bolts on the
tank, lay a two foot level across the tank with cover removed. Tighten each side a little at a time.
I always tighten the tank down until it just touches the raised rib on the bowl, and no more than that.
You can buy generic tank to bowl kits, but make sure the bolts are solid brass.
Posted on Nov 05, 2010
Testimonial: "thank you very much- i will give it a try this weekend- "
  • 21 Answers
Check toilet flange/wax ring/mounting bolts
Posted on Nov 06, 2010
How do i fix a leak from the cistern to the toilet bowl
There are bolts attaching the tank to the bowl check to see if they are correvtly tightened after you check to see if the gasket is properly seated.
Dec 25, 2014 | Home
How can we stop our 1.5 year old pegasus dual flush toilet from continually running?
Remove the lid from the tank. Verify that the tank is full. Shut off the water to the tank, at the wall. Wait 5 minutes. If the level has fallen in the tank, the flapper valve in the bottom of the tank is the culprit. If the tank remained full, the issue is with either the fill valve assembly or the overflow tube.
--W/D--
Jan 16, 2011 | Foremost Pegasus Series 1940 1-Pc White...
My toilet only leaks when flushed. It seems to be coming from the connection at the tank. The tank is not cracked and a new hose from tank to shut off valve has been installed. The toilet is only 4 years...
If you have 2-part toilet, then tank is attached to bowl with 2 bolts.
Look inside tank and you can see bolts with rubber washers located on either side of flush valve.
The 2 bolts hold tank and bowl together and between tank and bowl is a washer called the spud washer.
So spud washer could be leaking ... or 2 bolts could be leaking.
1) If bolts are leaking, there is usually dripping all the time, and drips are visible on bottoms of bolts
If spud washer is leaking, then tank could leak only when tank is flushed.
2) First thing to try is tightening nuts on the 2 bolts. Nuts may be loose. Tighten nuts a few turns, and check if toilet still leaks.
3) To fix a spud washer, you usually need a new generic one from hardware store.
Newer tanks with 1.6 gallon flush have special sized spud washer.
geno_3245_105.jpgTank is upside down and spud washer is fit over flush valve
If you cannot find new spud washer, re-use old one and smear retorseal on it during re-assembly to make sure it seals. Rectoseal is good for many home plumbing repairs. More about that in a moment.
4) To take apart tank: Disconnect supply line to tank. Empty water out of tank. Remove nuts from bolts. Lift tank off. Wash out tank with hose. Make sure there is no sand or sediment left in bottom that might clog up flush holes located inside bowl after tank is re-assembled.
5) Remove old spud washer, and put new one on. Do a google-image search for 'spud washer' if you need more photos. New spud washer fits over flush valve. That's it. And then reassemble tank.
If you want to apply rectorseal to washer, put washer on as shown in photo above. Then smear-or-gawm rectorseal over area of washer that sits on bowl. Rectorseal will make sure there is no more leaking.
Nov 24, 2010 | Bemis 1200 Slow Elongated Toilet Seat,...
Water fills tank slowly
Check your angle stop ==valve underneath close to the wall see if it's open all the way if it is and you still have the same problem then go ahead and shut it off, disconnect it from the toilet and the valve and see if there is anything stuck in the hose (a gasket maybe) if nothing blocks the hose then. Reconnect the hose starting from the valve put a bucket on the other side to catch the water and open the valve as if to clean the hose. After you do that reconnect the hose and try again if still does not work properly then you have to replace the fill valve (the tower looking stuff inside the tank)
if it works for you, don't forget to rate me
thx
May 27, 2010 | Caroma CARAVELLE270ADAW-EL Caravelle...
I installed the tank on the bowl hand tight, but it seems loose
thats a tough call, i used to battle with this when i was out in the field fixing many toilets,...if it don't leak, it's tight enough,..concerning the rocking, i used to place little shims under tank to stop it rocking,....don't force nothing,.and make sure your hand tight is good-n-snugg. good luck, good question, cracklin joe
Jan 04, 2010 | Jacuzzi Bath Era BK37 959 White toilet...
The toilet is only 2 months' old. The water keeps
Remove the top of the water tank.
check to be sure that the flush cover (about in the center of the tank) can close all the way. It seats into a 2 inch hole - and must seat all the way around. If it fails to seat, then the fill valve (on the left side of the tank) will continously let water into the tank.
As a starter experiment, you may try just turning whe water off at the wall shut off. Then inspect the tank to confirm that it is losing water.
If confirmed, then the above solution is correct.
If it is not losing water, then the fill valve is faulty and will need to be replaced (it is allowing water to over flow into the "OverFlow" tube.....
I recommend that you keep the water turned off at the wall until the toilet is needed - and the problem is repaired.
Nov 15, 2009 | Kohler Santa Rosa Compact Elongated Toilet...
I just installed two A/S Flowise Cadet 3 toilets..how tight should the tank be bolted down to keep it from rocking?
The tank should come down until it touches the bowl. You tighten one side a bit and then the other to bring it down evenly. You have to be looking in between the two as you tighten.
Sep 05, 2009 | American Standard Cadet 3 FloWise...
Downstairs toilet won't stop filling, upstairs toilet won't fill
for the upstairs if the valve is fully on there is not much you can do other than replace water service to the house or heaven forbid repipe.Valves usually don't restrict fill volume.But you can take the supply loose from the tank and stick it in a bucket turn the valve on and check the flow.this should narrow it down.Down stairs repair or replace flush valve
Aug 04, 2009 | Home
House of toilet noise
try bendind the brass rod down 1/4 inch in your stack
May 29, 2009 | Pegasus Technologies Two-Piece Round...
What is the diference of 12'' rought or 10''on a installation
if you have a 10" rough in your house you can not install a 12" rough toilet. but if you have a 12" rough in your house you can install a 10" rough you would just have a 2 inch gap between the toilet and the wall.
the rough is measured by measuring the middle of the sewer hole. that your toilett sits on. to the back of the wall this is important because the tank sits behind the toilet. if the tank is too big then the toilet wont fit over the sewer hole.
your house shouldnt have a 10 inch rough unless its about 90 to 100 years old most home's now days go off a 12" to 14" rough.
if you do have an old home you can order any 10" rough toilet at a plumbing supply store. or lowes. they probably wont carry them in stock though because 100 year old houses aren't very common
Nov 15, 2008 | Toto Aquia II Dual Flush Toilet
Eljer & Patriot& Elongated Toilet Bowl  Logo
168 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
