Question about Biostar A780L Motherboard w AMD Phenom X3 8850 Processor Bundle
I have a biostar A780L w AMD Phenom x3and when i installed the motherboard It now says I have no drivers now it did come with a cd but the Operating program won't load up because it doesnt detect the drivers or hard drives that was with windows 7also I tried loading windows xp after that and well It doesnt detect anything either the CD it cam with reads as some weird music cd and doesnt work please any help asap thanks so much
map9966
  • 2351 Answers
SOURCE: windows loads on every other boot.
Let's try running a memory test program. http://memtest.org/
Scroll down till you see the three screen shots. Just under them pick you're choice of bootable media to test you're memory.
Download - Pre-Compiled Bootable ISO (.zip)
or
Download - Pre-Compiled package for Floppy (DOS - Win)
Luck!
Mike
Posted on May 15, 2008
wayneard
  • 1901 Answers
SOURCE: Processors fault
Here is the page that lists all CPU's for your MB:
MCP6P-M2 CPU Support
Thanks for using Fixya.
Posted on Apr 07, 2009
  • 108 Answers
SOURCE: sata hdd not detected
Yes, go into the bios and make sure that SATA is turned on. Sometimes with motherboards that have two ide controllers the SATA is turned off by default. Also another thing to check is whether the motherboard is SATA I or SATA II. If it is SATA I then change the jumper on the hard drive to peg back to SATA I. Your new hard drive is SATA II and the motherboard may not support it.
Posted on Jun 10, 2009
  • 20 Answers
SOURCE: On windows xp 64bit no sound Biostar motherboard TA790GX A2+
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. via
aafgsgh1
Posted on Sep 07, 2009
SOURCE: Orignal cd drivers won,t install sound on biostar TA790GX 128M
i want mother bourd support driver from my laptop
Posted on Sep 10, 2009
No display after installing Biostar motherboard
THE DRIVERS MAYBE ? .
THE MONITOR ? .
YOU HAVE TO EXCLUDE ONE THING AFTER ONE OTHER.
Jun 13, 2013 | Biostar Computers & Internet
Need bios update for amd dual core 3.2 or phenom 9600
Hello here is the homepage:
http://www.biostar.com.tw/app/en/mb/introduction.php?S_ID=498#cpu
Only the cpu on the list, will fit the mainboard.
Others will be not be compatible with the mainboard, and a bios upgrade will not help with that.
Good luck
Feb 07, 2013 | Biostar N68S+ Motherboard w AMD Phenom X3...
Will Phenom II x6 95w fit in a biostar n68s3+ even though it says x4?
Rule of thumb, always backwards compatible. -Just posting not a solution. gl
Dec 11, 2012 | Biostar N68S3+ AM3 NVIDIA MCP68S Micro ATX...
BIOSTAR A960G+ AMD PHENOM II x4/ cpu max power 95W/ prepairing to shutdown with in 10 sec....what is the ******* problem in this unit? is it my processor? or my power supply or my new BIOSTAR A960G+ AMD...
Hi '' you have to specify what way your PC is shotting down'' do you mean that when you press power on of your PC and it do shot down just 10 seconds? so it means your PC does not boot , you cannot see letters or words while booting '' pls. keep in touch // thanks
Aug 23, 2012 | Biostar A960G Micro ATX AMD Motherboard
Anyone else having an overheating problem? my pc runs for a while, gets hot and just shuts off. if it's still hot it will shut down during boot sequence. any ideas on how to resolve? biostar mcp6pb...
Put a bigger processor cooler with plenty of thermal paste
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6101294&CatId=2545
and install a case fan.
Sep 16, 2011 | Biostar MCP6PB M2+ Motherboard
Hi, I have a newly installed desktop with Biostar A770E3 motherboard, AMD Phenom II X 4 945 3.0 GHz CPU, XFX GeForce 8600GT video card and Logisys case with 480W power supply. And Corsair 4GB X2 DDR3 RAM....
if you have a different video card try that, seems like the fan should spin on the video card. or pull the video card then reinstall see if that makes a difference beeps or something
Apr 20, 2017 | Biostar A770E3 AM3 AMD 770 ATX AMD...
I got a new motherboard and everything starts up perfect, all fans and the screen shows up, but my keyboard whether its the 8 pin or the USB drives wont work. Its a biostar a780l and the manufacturers...
Make sure the 8 pin is in the purple connector not the blue, if using a USB keyboard plug it into the USB slot directly to the right of the DVI connector. If it still fails, remove the power cord from the PC then remove the battery for 1 minute. All else fails, motherboard is dead.
Ps. Prove both keyboards work on another PC first.
Apr 26, 2011 | Biostar A780L Motherboard w/ AMD Athlon X2...
I just got my Biostar A780L and i put a amd phenom 2 2.8ghz 920 quad core in it and when i try to start it up it sounds like its working but the screen just stays blank, like the monitor doesent even turn...
No noise, no beeps whatsoever?
If no beeps, MBoard may be defective, or RAM might be bad, maybe one of the drives.
You need to d differential diagnosis.
Try removing everything but the CPU and see if it will POST.
If so, add 1 stick RAM, then 2nd stick, then Drive, then ,,,,,, until you find culprit.
If nothing works, would try another "known good" power supply
If that is no go, Mboard bad.
Feb 04, 2011 | Biostar A780L Motherboard w/ AMD Athlon X2...
Processors fault
Apr 07, 2009 | Biostar MCP6P-M2 Motherboard - v6.0,...
Biostar A780L Motherboard w AMD Phenom X3 8850 Processor Bundle Logo
160 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
