SOURCE: Yamaha FZR 600 not charging correctly with the lights on
I HAD THE SAME ISSUE. CHECK YOUR VOLTAGE OFF O THE MAGNETO, IT SHOULD BE IN THE 25V RANGE. IF THAT CHECKS OUT OK CK THE VOLTAGE IMEDIATLY AFTER THE VOLTAGE REGULATOR, I BET IT IS BELOW 14V. THE FZR IS PRONE TO HAVING THE REGULATOR GO BAD (THE OLDER ONES HAVE NO COOLING FINS AND THEY BURN THEMSELVES UP). THE BEST ONE TO BUY IS THE NEWER VERSION FROM A 1999 FZR, IT HAS COOLING FINS WHICH GREATLY PROLONGS THE LIFE. YOU HAVE TO DO SOME SLIGHT WIRING MODS, BUT NOTHING ANYONE COULDN'T DO. SEARCH FOR FZR REGULATOR UPGRADE AND IT WILL EXPLAIN EVERYTHING! I HOPE THIS HELPS! GOOD LUCK!
SOURCE: 1994 yamaha fzr 600 new battery, won't charge
this sounds like a stator problem. try checking the wiring inside and to the battery and if that is not it you most likely need to replace the stator.
SOURCE: how do we start a yamaha 1998 xl 1200 wave runner
first put a new battery in it. then put your lanyard in the handle bar clip push the start button make sure that you have a life jacket on when your in the water and make sure that u attach the lanyard to your wrist or life jacket
SOURCE: does a yamaha wave runner have to be in the water
no but do not let it run for more than thirty seconds out of water and dont rev over 3 thousand
SOURCE: 95 yamaha wave runner starts
Have you changed the 'fuel filter'. That's where you start.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
