Personal fax problem
When i plug my personal fax machine, a word check document always displayed at the window of my fax machine even though there is no document inside of it. I can receive the incoming fax but i cannot send my document, because of that word (check document). Anybody can help me? Thanks
  • jekka1 Dec 26, 2008
    The window of my fax machine says, Check Original but there is no document and it will not let me switch from Fax to Copy because of that word.
    Brother MFC-8220
  • eric moirez May 11, 2010
    what kind of fax machine? Make and model
    Problem Solver:
  • 9 Answers
Its seems as though you may have a sensor problem or dirty rollers which feed in your original document. Try this:
open up the cover where you feed in your original document and clean all feed rollers which are normally rubber rollers and make sure you dry them off.
also check for a little arm sticking out which is a sensor flag and make sure it is not damaged and also that it springs back up when pressed.
Can you please let us know the make and model of fax please.
Hope this helps.
Posted on Jun 14, 2008
The fax is received by the other party but we receive an error code J72. There is no jam
If you are sending the fax using ADF, there may be the document jam, Open the ADF cover check the path for any foreign objects.
Also you can send from platen glass without document jam.
Also this may happen to the other end fax machine, better you do a test copy from ADF and Platen glass. and confirm your fax machine is ok.
Mar 05, 2015 | Panasonic PanaFax UF-8000 Laser Fax
Whenever i send a fax, the machine confirms by viewing 'TRANSMITTING OK' but the addressee receives a blank document
Check the baud rate of your transmissions. Slow them down to the slowest setting and send a test fax to a helpful person. Slowly increase the baud rate (communication data speed) and send the fax test. When the fax doesn't show up on the receive site, then step one baud rate speed back, and save the setting.
It could also be your fax that is faulty, or even the receive sites fax, also being faulty.
To test your copy-head, insert a document into your loading section of the fax and press copy. If the copy prints out fine, then you know the head is reading correctly.
It is also possible that the receiver fax (the other end) has a printhead failure.
Nov 25, 2013 | Canon FAX-JX200
Can not send fax. The receving fax rings but my machine does not respond and send the fax. I can receive ok.
The document does not feed into the machine.
Be sure the document is not wrinkled, and you are putting it in correctly. Check that the document is the right size and not too thick or too thin. (See document types and sizes on page 43).
You cannot receive faxes automatically. Check if "TEL" appears on the right side of the display. In TEL mode, you
cannot receive a fax automatically. Be sure the handset is seated on the cradle properly.
The machine cannot receive faxes manually. Do not hang up the handset before pressing Start/Enter to receive a
The machine does not send anything. Check that the document is loaded face down. Send should show up
in the display after it dials. Check if the machine to which you are sending can receive your fax.
Dec 22, 2010 | HP 1010 Plain Paper Thermal Fax
Work Center Pro 575 always gets paper jams
If a document jam occurs during a transmission, the message "DOCUMENT JAM" is displayed. If this occurs, follow the procedure below. It is recommended that a duplicate from a copier, of the jammed document be used to reduce the chance of a jam when resending the document.
See Chapter 3, "Loading Documents" for document specifications and recommendations which may help avoid paper jams.
Note: The power can be left ON when clearing a paper jam.
Typical Causes of Document Jams
Recommended Procedure
The document is fed at an angle.
Adjust the Document Guides to the edges of the
The document paper is too thin or too thick.
Make a duplicate using a copier and use the copy
as the sending document.
Document has tape or pieces of paper taped to it.
Remove the tape or make a duplicate using a copier and use the copy as the sending document.
The Control Panel Cover is not fully closed.
Close the Control Panel Cover fully.
The document is stapled. Remove the staple(s), or make a duplicate using a copier and use the copy as the sending document.
Basic Troubleshooting
1. Remove all documents from the Document Support.
2. Open the Control Panel Cover.
3. Remove the document jam. Remove any pieces of paper, paper clips, or staples that may have caused the jam.
4. Close the Control Panel Cover.
5. Verify the display has returned to the Standby Mode.
Jul 13, 2010 | Xerox WorkCentre Pro 575 Plain Paper Laser...
Warning message being displayed when magicjack is plugged
My Magic Jack was working fine. One day I got some viruses in my computer and I ran setup CD.After that magic jack is not working, it always display "Warning you must plug magic jack into usb".
I tried to chat with tech persons so many times and tried many methods but when they say "now unplug and plug in" , then magic jack home page opened on chating window (always) and stopped chating.
and still I'm getting same 'warning' message.
Oct 23, 2008 | Computers & Internet
Cant't send out any faxes.
Are you using the little cord that came with the printer to hook up your fax. It is a special cord. You cannot just plug a phone line into the fax.
You have to use the little cord, or equivlent. Go to
Apr 07, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Hyperlinking jpg files in Word document
Install/upgrage office 2003 sofware. it comes with Picture & Fax Viewer. office xp and office 2000 doesnt come with Picture & Fax Viewer.
Mar 10, 2008 | Computers & Internet
Techinical glitch?
This unit is not well made at all. I would suggest you exchange it if it is still under warranty. In the future, buy a HP or Epson with extended warranty.
Apr 10, 2007 | Lexmark F4270 Plain Paper Inkjet Fax
110 people viewed this question
