Question about Advueu Technology AMW-F196B
AMW F199B 19 Inch LCD Monitor - No Red
I tryed cleaning the 15 pin plug. What are the possibilities?
Is it the cord is it the board?
Help
  • robertyy May 11, 2010
    Support is at PROMEDIALCD.COM
    TEL: 1888 622 5005.
    COMPANY IS PROMEDIA FOR THE AMW MONITORS.
I just changed PC and and I have a "AMW F199B" monitor that will not produce sounds now. I do not have any of the original software for the monitor. What do I do?
Thanks
Posted on Nov 09, 2008
Dell E1909W The color of the screen changed to red
This could mean a broken, loose, bent pin(s) in the vga connector.
Check it first. Try changing the vga cable if your monitor is a lcd flat. These comes with a detachable cable but not on the crt monitors which is fixed.
If you can find the menu button on the monitor. Go to input configuration. The setting could be on "ypbr" setting which is a component setting just like your dvd player. Set it back to "RGB".
Or it could also be that your monitor board is starting to be damage. Sorry to mention it, but possibilities are many.
Good luck mate.
May 06, 2014 | Dell E1909W 19 inch Monitor
I have model LCM-19v1 SL monitor and I need to know what type of power cord I need for it. and possible a picture
hi,
these are the specs for you monitor
Upgrade your desktop display in size and style with this Westinghouse LCM-19v1 19-inch LCD monitor! Its advanced HD-Grade flat panel technology lets you enjoy crisp, vibrant images while working on spreadsheets, writing email, watching movies, playing games and surfing the web.
Some key features include 1280 x 1024 native resolution, 600:1 contrast ratio, and a fast 21 ms response time. Its thin, sleek and sophisticated design will complement any office. Get yours today!
By law, California shipments of this product are subject to an $8.00
Electronic Waste Recycling Fee
Features/Specifications:
  • Westinghouse LCM-19v1 19-Inch TFT LCD Flat Panel Monitor
  • General Features:
  • Silver Cabinet color
  • 19" diagonal screen size
  • Native/Optimum Resolution: 1280 x 1024 16.7 million colors
  • Compatible Modes: VGA, SVGA, XGA, SXGA
  • Contrast Ratio: 600:1
  • Brightness (Nits): 300 cd/m2
  • Response Time: 21 ms
  • Viewing Angle: 170 degree Horizontal, 170 degree Vertical
  • Built-in stereo speakers
  • Connectors: 3.5 mm stereo mini-jack. VGA-in, DC-in
  • DC Input: 19V - 3.1A
  • EnergyStar compliant
  • Regulatory Approvals:
  • FCC
  • UL
Package Includes:
  • Westinghouse LCM-19v1 19-inch TFT LCD Flat Panel Monitor
  • Power Supply (100-24V 50~60Hz)
  • Power Cord
  • Stand
  • VGA cable
  • Audio cable
  • User's Manual
Additional Information:
  • Requirements:
  • Available power outlet
  • VGA adapter
  • Notes:
  • LCD displays may have cosmetic imperfections that appear as small bright or dark spots. This is common to all LCD displays used in products by all vendor and is not specific to any vendor or brand. Below are the acceptable amounts of "dot defects" for LCD displays that we sell:
  • 17-Inch to 18-Inch:
  • Total Defects: 8
  • Bright or Dark Dots (random): 4
  • Bright or Dark Dots (2 adjacent): 2
  • Bright or Dark Dots (3 adjacent): 0
  • Minimum distance between defects: 15 mm (bright to bright dots); 5 mm (dark to dark dots
for the adapter, already inserted the picture of it
Hope this will help... Your response is very much appreciated....
Jan 20, 2011 | Computers & Internet
Balance CM2019 LCD power cord. it is unique. it's a really small 3 pin.and it's a 15 volt 4.5 amp. radio shack doesn't cary it. no luck for me yet. i tried a universal adapter,and no luck there. any help...
you might try walmart; they carried this monitor for a time... also, amazon did as well. They were a good monitor for the price, altho the couple I saw were not perfect screens.
Dec 11, 2010 | Balance CM2019 19" LCD Monitor
I have a MAG innovision 900p 19" monitor that turns white everytime it is turned on.. I've tried cleaning the dust from the connectors and have tried turning it on and unplugging it. Nothing I can think of...
White screen means that the video signal is not getting from the vga board inside the monitor to the actual lcd screen panel.
It may be a bad vga input board (also called a main board)
OR
It could be simply a bad connection on the wiring harness that connects this board to the lcd panel
Or
it could be a blown fuse on the board on the board that is permanently mounted to the back top of the lcd panel.
I would check the wiring connection to the lcd panel inside the monitor first
Oct 19, 2010 | Mag Innovision LT917S 19 inch Monitor
My 19 inch ViewSonic monitor shows red /voilet
Please check the VGA cable at both ends to make sure there are no bent pins and fit into the socket properly at both ends. Also try this monitor with other PC also since it can be in the video card.
Apr 25, 2010 | ViewSonic VX912 19" LCD Monitor
Mag Innovision LT982s 19 inch flat screen monitor
Often the plug of the power cord and its mate, the jack in the monitor, would have to conform with the region/country of its intended use. Having said this, then it is possible that your particular version is meant for another country but is likewise sold in your country. A picture of the monitor's connector would help narrowing the selection and possible source/supplier. Pls post if able.
Alternately, you could try viewing the different types here, here or here to get the specific part number or model of the AC cord.
Incidentally, most electronics shops/stores sell a variety of power cords, perhaps a visual check would further assist you.
Hope this be of initial help/idea. Pls post back as requested, how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Aug 02, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
Color Problem
In rare instances it is sometimes the 15 pin connector that connects on the computer end. Could be at the monitor end of the same cord, if it is a connector and not hard wired to the inside. Check both possible sides for bent pins.
I once went through an extension cable and had to remove it as it was bad connections and I'd have constant color changes drifting in and out. Sorry, but most likely it is just a cheap monitor on the fritz.
Sep 07, 2007 | X2Gen MG19MY 19" LCD Monitor
No red
Check the pins at the end of the VGA adapter of the monitor (this is the cord that plugs the monitor into the computer). One of these pins may be bent and may not by connecting properly to your video card. You can use a very small flat head screw driver (such as one from an eye-glass repair kit) to bend back into place. If all the pins appear fine, then there may be something wrong internally with the device and it should be sent in for repair.
Sep 23, 2006 | Gateway FPD1530 15" Flat Panel LCD Monitor
Advueu Technology AMW-F196B Logo
924 people viewed this question
Top Advueu Technology Computers & Internet Experts
David Payne
David Payne
Are you an Advueu Technology Computer and Internet Expert? Answer questions, earn points and help others
